BX 25 Weight / Options Plate
/ BX 25 Weight / Options Plate #1
mud roller
McMurray, Pa
Kubota BX 25D
Howdy all,
Cleaning up the garage sometimes means making things out of all the "stuff".
That's what has happened here, I made a weight plate on which I can hang many things.
It mounts on the backhoe brackets.
Right now I just use it for the weights and chain bucket seen. It can accommodate 5 weights.The weights are filled with melted lead provided by a local tire shop. They weigh about 70 Lbs. apiece.
The weight tubes are topped with Hydraulic cement. The Green is for contrast and Elimination of another can on the shelf. ( I like all colors )
The weights and the chain bucket are secured on the bottom with a 3/8 bolt. The main plate itself is threaded to eliminate a backing nut.
One draw back of course is it can't be on with the hoe.
Now let me look in the Junk pile and build a few more options....
/ BX 25 Weight / Options Plate #2
Very well done! Very ingenious.
/ BX 25 Weight / Options Plate #3
Is there any way to add a 2" receiver that you lift with the 3pth? I would be lost without a trailer ball....even my hoe has provisions for one when it is installed...
I think it could be done, I move most of my trailers on the front end loader with the help of a pallet fork / Hitch adapter.
The main plate sure perhaps also be 3/8 inch.
It is so easy to place trailers when looking forward.
Pic attached.
/ BX 25 Weight / Options Plate #6
Mud roller. What are you using to bend rod and cut out the metal shapes? Thanking you in anticipation.
John
John
Hey there JB,
Well its sort of old fashioned and low tech, I work out of a tiny garage and the driveway (on sunny days) so I have no high tech gear.
I try to work in squares as much as possible but when shaping is required I Mark the shape and cut all the corners I can with a power hack saw, Then finish the shape with a plain old angle grinder.
It takes time but the results can be quite satisfying.
Holes I just cut out with a new hole saw.
As far as bending rod I make a template with some thing easy to bend then using a neighbors large old time heavy vise duplicate the shape as close as possible with a plain old fashioned sledge hammer.
When bending rod I found it useful to mark all rods the same as far as where they will rest in the vise when starting the bend, they can then be fine tuned with a little muscle and beatings.
I am in the process of making a 1/4 inch skid plate with 3/16 shield for the BX transmission and fan area and bending plate (actually quite easy) to do it, I will post shortly.
Thanks and have a great day!!
Sorry for the delay but I have been on the road for awhile working.
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
2004 Mack RD690S Tri-Axle Rolloff Truck (A64194)
2004 Mack RD690S...
2003 40ft. Proclaim T/A Vacuum Tank Trailer (A64194)
2003 40ft...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
