Shade chart for MIG auto helmet guidance needed
   / Shade chart for MIG auto helmet guidance needed #12
Actually I found that reading glasses was the best upgrade I made. Wearing them under your helmet was 'eye opening'. :D Even if you get the light brightness setting 'right' for you, having a sharp image makes a heck of a difference! I encourage you elder gentlemen to try it if you haven't.
   / Shade chart for MIG auto helmet guidance needed #13
"Elder gentlemen" :D :D :D. Thanks for the advice, Mr. Diplomat.
Terry
   / Shade chart for MIG auto helmet guidance needed #14
Yes the readers were an eye opener. I still avoid using them however because it is one more step as you are always taking off your helmit. In the shop environment, they can easily get squashed as well. I wish I could get a reading lense for my mask!
   / Shade chart for MIG auto helmet guidance needed #15
You can. We call them cheaters.
You can get them at most LWS .
   / Shade chart for MIG auto helmet guidance needed #16
Beware that some auto dark hoods wont accept cheater lens behind the AD lens. There just isn't enough room for the spring clip to hold them. Now problem with the old Hobart or Lincoln hoods designed for the hard glass dark lens.
   / Shade chart for MIG auto helmet guidance needed #17
That's a good point. On my cheap hoods, I have been able to cut down the cheater lense to fit. Others I've just taped them in.
   / Shade chart for MIG auto helmet guidance needed #18
I had to do the same for my Lincoln Viking hood. Spent the first 15 minutes trying to figure out what I was doing wrong.
It's a wonder I didn't break anything.
Terry
   / Shade chart for MIG auto helmet guidance needed #19
Just as others stated, It is a personal preference. However, If you weld and once you stop, lift your helmet and try to focus on something but there is a white spot on whatever the object is you are focusing on, you need to go a shade darker.
   / Shade chart for MIG auto helmet guidance needed #20
I thought cheaters meant readers. Do they come in the same numbers as readers?
This would be GREAT! No more putting the readers off to one side, just to have to remember where that was.
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
John Deere Frontier Quick Attach Pallet Forks (A59814)
John Deere...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
iDrive TDS-2010H...
KOMATSU PC228USLC-3 EXCAVATOR (A60429)
KOMATSU...
