MX brush guard
/ MX brush guard #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
My MX4800 came with a "brush guard" that hinges out to open the hood. However, it's just a frame with no protection for smaller stuff like brush. The grill screen is plastic and I've already cracked it. I'm consideconsidering welding in some expanded metal mesh.
How much do you think mesh would block the headlights? Do you think it will reflect lots of light back at me at night and be blinding? Has anyone moded their guards for small material protection?
/ MX brush guard #4
I did about 4k worth of damage on my L45 when a stick went thru my 1/8" expanded metal brush guard and did not stop till it hit the fan blade. After repairs, I found an old bend dozer front guard at a equipment dealer, paid scrap price for it, shaped it on a press to fit the guard, welded it on, and painted it Kubota orange. It is 1/4" thick, now I do not sweat the small stuff or large stuff for that matter.
If you get expanded metal in 3/16 or thicker (better yet get perforated metal), it should work fine, the smaller stuff is too hard to weld well enough to hold for novice welder like me, I kept melting the expanded metal. I would also add cross bracing behind the metal every 6" which would make a great place to weld the metal too.
/ MX brush guard
Can you post a pic? Would be very helpful.
/ MX brush guard
You mean it punched a hole in the mesh?
Any idea on the gauge metal. 1/8" refers to the hole size correct?
I know 3/4" is often 13ga but can be 16ga. So I'm thinking 1/8" mesh is fairly flimsy?
/ MX brush guard #7
3/16 or thicker is for the thickness of the metal not hole size. Hole size is whatever you are comfortable with. If you do a search, there are many examples of guards. I would not be afraid to use plate steel if you have some around, the tractor will get plenty of air from the sides.
/ MX brush guard
Did a search and didn't much. Hence the post. Thanks for the reply and i will search again
/ MX brush guard #9
Try using grill guard and brush guard, you will in at least a dozen threads.
/ MX brush guard
Weird. I got an email saying Ovrszd had posted on this thread but now there is nothing here. I also thought someone had posted a picture. Now the only responses I see are from KubotaToy.
Does anyone else see anything more on this thread? I have looked from my phone and desktop.
/ MX brush guard #11
I probly did that. My computer or the site was acting up. I tried to post some pics of guards but they wouldn't show up so I deleted the posts. Can't get them to post right today either. I'll try again later. Sorry for the confusion.
/ MX brush guard
Thanks! KubToy said you have a previous thread with you mods. Any idea of the title. Could not find it.
/ MX brush guard #13
/ MX brush guard #14
If looking for a thread started by a specific member, go to the "Search" icon at the top of the screen. Then scroll down 3 or 4 rows to "User Name". Type in the name you are searching for and then to the right there is a dropdown where you can select what you are looking for. It'll be on "find latest post". Click on the drop down arrow and select "Find threads started by user". Select that and then to the right click on "Search Now".
It will list every thread started by that user. The Search function has many options, just gotta wade thru them and use it to your advantage.
I'll try to get some pics posted on this thread when I can get it to work. :)
/ MX brush guard
Roger that. I wish the phone app had those search functions. Also wish it provided members profile info like the web page does.
/ MX brush guard #16
This is what I did after hearing the horror stories....
/ MX brush guard
<img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/428191-mx-brush-guard-20150513_133919_resized-jpg"/><img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/428192-mx-brush-guard-20150513_133940_resized-jpg"/>
Did you do any reinforcement to the bottom flap. If not, any problems with grappled brush bending it? The fact that the grill articulates makes the bottom part tricky.
/ MX brush guard #18
Here's a pic of the guard I built on my old L4400. Sorry it's not a very detailed pic. Crude but effective. Non tilting.
/ MX brush guard #19
No it is not reinforced on the bottom although I am sure you could if needed. I don't have a grapple, I am just using forks and a chainsaw to move my tree piles to the burn pit, but no issues using the forks. I have scratched the paint off in a lot of places so I know it is working
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
1996 Sunflower 1543-38 Folding Disk (A63118)
1996 Sunflower...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
