3520H - working with wood
/ 3520H - working with wood #1
Gafn
Gainsville, GA
Branson 3520H
Had my first chance to work with some weight.
What do you think this log weighs?
Until I cut it the 3520 would not lift it...
I have had this tractor 1.5 months and I am very happy with it.
/ 3520H - working with wood #3
I would guess that the log was a lot of weight.. Was it that the rear of the tractor would come off the ground or that the loader just wouldn't lift it at all? The back end of the tractor should have came off the ground if your hydraulics are adjusted properly. Also love your pics of the Dodge Ram and the Branson, best set up you can have.. Love it.. Thanks for the pics.
Using that tool - the log was 27 inches at the base and 24 foot long. - puts it at @ 6000lbs.
The tractor - simply refused to lift it, did not lift the rear tires.
If that weight estimate is correct, with the 3520h at 4000lbs, I was hauling near the max capacity of that trailer.
Thanks for the comments on the Ram, The cummins is a workhorse, and once you build the transmission , and replace the factory flex plate, and torque converter, you can turn up the power, and really haul. Always run a pyrometer so you don't melt your turbo, and just pour the coal to her....
rasorbackq
Please re-read my original post - I stated that the 3520 could not lift the log until I cut it, in fact I had to cut the 24 foot log into 4 - 6 foot long sections to be able to lift it. I dragged the log into position, then tried to lift one end so I could cut it without my chain hitting the ground, and the 3520 could NOT lift it.
/ 3520H - working with wood #7
I have a 4720H and it will not lift 2000lbs so not sure how your 3500 lifted that much weight.
I have found a lot of these loaders are not set to the proper PSI setting on the valve and might need to be re-adjusted. They are suppose to come from the factory at 2450psi, if they are not set to that they will not lift their respected capacity of 2100lbs. Might want to check that.
/ 3520H - working with wood #8
Would make sense why it wouldn't lift it. That's pretty heavy.
/ 3520H - working with wood #9
rasorbackq
Got it. You didn't say in the original post you cut it into 4-6' pieces . Looking at the picture It seemed it was liftable after the one cut in the pic.
Sorry about that - I thought that pics of it cut up on the trailer covered that.
Nope - not lift-able after only one cut - in fact even the 6 foot pieces, stopped the curl function from working.
I could lift without an issue, but could not curl the forks back.
Mr. Bitz may have something about the loaders not being set to the proper PSI - I need to get a test gauge and see where mine is set.
/ 3520H - working with wood #11
Never noticed the cut up logs on the trailer til now.
My loader I was trying to lift 25 bundles of shingles it could nt do it but remove just one bundle and it could , not fast but could do it.
/ 3520H - working with wood #12
I've lifted some logs for my saw mill with my 3510 and had the tractor "Crab Walk" because the rear wheels were almost off of the ground!! If I turned the steering the whole tractor and rear wheels would shift.
I have a 4000 lb Clark Forklift for the real heavy logs.
Generator on Trailer (A64119)
Generator on...
2020 CASE TR340B SKID STEER (A64279)
2020 CASE TR340B...
(2) UNUSED 16.9-24 TIRES ONLY (A64280)
(2) UNUSED 16.9-24...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2018 LEEBOY CHALLENGER 7 SWEEPER (A64279)
2018 LEEBOY...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
