Flail Mower Caroni TL1900 flail mower
/ Caroni TL1900 flail mower #1
fixitman123
SE NC
John Deere 1010 LS XR4040
I'm a fairly new member to the flail nation. I read on these forums that greasing the flail is very important. The manual calls for ep2 grease. I was wondering what grease would be best to use. There are so many different choices. Would synthetic be best?
/ Caroni TL1900 flail mower #2
I want to welcome you as the newest member of the Flail Mower Nation "where no passports are required".
The EP2 high temperature grease lubricants are fine, please do not use synthetic grease in your flail mower.
Use no more than 6 pumps in the flail mowers rotor bearings at each mowing.
Happy Mowing
Thanks Leonz. Should I use grease with moly or without? Lucas Tacky Red be OK?
/ Caroni TL1900 flail mower #4
Hello Lucas,
Any molybedenum EP2 grease is fine, the Lucas tacky red has to be able to melt well enough to
coat the inner race, rollers and outer race effectively.
The major thing to worry about is the high operating temperature as the rotor at the shaft
weldment is spinning a at around 2,200 rpm +- at the 540 RPM Engine speed for the rear
power take off.
Happy Mowing
Is the 2 in ep2 the thickness? Most greases don't say ep2, but I guess I should go for a grease that states "extreme pressure" and no2? Would mystik jt6 multi purpose be a good choice. Thanks
/ Caroni TL1900 flail mower #6
EP2 grease is an extreme pressure grease is a lithium-soap thickened grease for extreme pressures.
Lithium greases are non corrosive and adhere well to metal.
If you can cross reference the Mystik JT6 with the EP2 and the specs match exactly you should have
no issues.
2014 Mercedes-Benz C300 Sedan (A61569)
2014 Mercedes-Benz...
2018 FREIGHTLINER M2 106 S/A 4X2 CAB & CHASSIS (A59909)
2018 FREIGHTLINER...
2017 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2017 PETERBILT 579...
2013 FORD F350 SUPER DUTY 4x4 CREW CAB PICKUP TRUCK (A59909)
2013 FORD F350...
iDrive TDS-2010H...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
