Alien Invasion - I want my pond back !
   / Alien Invasion - I want my pond back ! #121
The MS361 is awsome!!!:thumbsup::D
The ms361?
   / Alien Invasion - I want my pond back ! #122
I refer you to Post #72 where Eric states:
Perhaps I should have explained earlier that I had to get the water up a small hill, across the top and down the other side before gravity would become my friend. For the first 100 yds it is on a constant rise.
You better be in really good shape to make the football field-long trek up that slope numerous times while wrestling with a pipe. :laughing:
But seriously, if you managed to fill the far end down slope pipe with water one slug at a time without an EMS call, once you start to fill the uphill running pond end, you have a gravity problem. The water in the pipe will have enough head to flow out when you dip the open end into the water. It's like you are expecting water to run uphill in order to fill the pipe.
If the pipe was a bit flexible and somewhat durable, it could be flooded end to end in the pond, close a valve at each end and drag one end over the rise with a tractor.
You don't have to fill the uphill running pond end.... :cool2:
   / Alien Invasion - I want my pond back ! #123
After seeing this thread, I decided to try to siphon out a small pond to clean it. I used a broken flower pot as a filter, and a garden hose. There was a big hill behind the pond, so it wasn't a hard job. It had been going for a while when I took the picture. The pond was full when I started.
   / Alien Invasion - I want my pond back ! #124
Here's a nice video of a guy starting a siphon with solid pipe, a tee at the top, a shutoff valve at the discharge end, no valve at the inlet, and a 5 gallon bucket to fill the downhill side of the pipe. You don't have to fill the uphill side!
https://www.youtube.com/watch?v=8rgpRJ1xCeM
   / Alien Invasion - I want my pond back ! #125
It depends. If the downhill side runs out of water before the uphill side fills, you will have nothing but water running back into the pond that made it partway uphill. He may have explained that in the video but listening to those is torture for my hearing.
   / Alien Invasion - I want my pond back ! #126
A bigger siphon would do the trick.
   / Alien Invasion - I want my pond back ! #127
It doesn't depend. I don't think you understand how siphons work.
   / Alien Invasion - I want my pond back ! #128
Yeah, I saw that video, too. Pretty neat. :thumbsup:
Several folks mentioned putting an upturn at the end to prevent air bubbles from percolating up the pipe to the top and killing the siphon, but with that amount of flow, it would seem pretty hard for any air bubbles to fight that stream.
   / Alien Invasion - I want my pond back ! #129
It depends what is the length of each leg. If the pond side is long relative to downhill side you have to fill both.
   / Alien Invasion - I want my pond back ! #130
Even my 50 foot garden hose sucking out of this crap didn't get air bubbles. It sucked until it ran out of water.
   / Alien Invasion - I want my pond back ! #132
Best examples I can find are these:
Downhill side always has to be longer than uphill side because siphons work by gravity and stored potential gravitational energy.
   / Alien Invasion - I want my pond back ! #133
Moss, that is interesting - I just thought one side had to be lower not necessary longer, the chain example clarifies that.
   / Alien Invasion - I want my pond back ! #134
Downflow in the lower leg has to suck any air/water from the upper leg faster than the bubbles can rise to the high point to get full flow. The Youtuber had ~35'(?) of fall, smooth pipe, and a total dynamic head <100'.
OP has 45' fall but more than double the run/TDH, more volume to get moving and most likely a slower flow rate due to the latter. (bubbles impede flow 'til discharged) Diameter and pipe walls (smooth vs corrugated, etc) have to be considered. Siphoning is never as simple as just the difference ('fall') between source level and output height.
btw, The OP's bucket reminds of having a jar of fluid at the end of a bleeder hose when bleeding brakes or a hydraulic clutch.
txdon, its the length of each effective leg vs total tube length on either side of the high point that provides the siphoning action. Extra pipe length on either side adds inertia and pipe friction, and they do matter to rate of flow.
   / Alien Invasion - I want my pond back ! #135
It is the water--under the pull of gravity--in the downhill side that will pull the pond side water up the pipe. If the downhill side is not long enough (contains enough water) to pull the pond water over the top of the rise and far enough down the downhill side to have the mass required to continue lifting the pond water, the siphon will fail. It does depend, just like the example you posted later.
   / Alien Invasion - I want my pond back ! #136
We already talked about filling the downhill side with enough water to compensate for the length of the uphill side.
   / Alien Invasion - I want my pond back ! #137
Yeah, that's about as good a visual I could find. Pretty much everyone has had a piece of rope, Christmas lights, extension cord, string, etc... in their hands at some time and have seen how if you drape it over something and one side has more than the other, it pulls it down on its own. Siphon works the same way.
The downhill side always has to be longer than the uphill side AND the discharge always has to be lower than the inlet. If its not, it will try to flow the wrong way.
   / Alien Invasion - I want my pond back ! #138
Well described.
Ignores differing slopes and pipe sizes. In large tubes on a slope the water will not necessarily flow as a slug, but as a stream. Water coming over the hi point with an air bubble ahead can go into this mode thwarting the start of siphon.
Chains have nothing analogous to air voids or bubbles in fluid. Fluids next to air in a large tube can seek their own level allowing air above the flow. The downhill side does not have to be longer, only to outlet at a lower level.
,,,larry
   / Alien Invasion - I want my pond back ! #139
Well described.Fluids next to air in a large tube can seek their own level allowing air above the flow. The downhill side does not have to be longer, only to outlet at a lower level.
,,,larry
The volume of the downhill side has to be the same or preferably greater than the pond side. If it is not the case you have to fill both sides.
   / Alien Invasion - I want my pond back ! #140
Well described.
,,,larry
So you're saying a 10' long downhill pipe with an outlet 1" below the inlet of a 100' long uphill pipe will work?
excavator trenching bucket- one bucket per lot (A56438)
excavator...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
2016 Nissan Altima 2.5 Sedan (A59231)
2016 Nissan Altima...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2013 CATERPILLAR 308E CR EXCAVATOR (A60429)
2013 CATERPILLAR...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
