Alien Invasion - I want my pond back !
   / Alien Invasion - I want my pond back ! #111
Errrrriic, its been two days and some hours, where are you?
They do still count time in days,hours,minutes, seconds etc. in the metric arena, do they?
Has anyone ever looked up a "jiffy"?
from Wiki,
The earliest technical usage for jiffy was defined by Gilbert Newton Lewis (1875–1946). He proposed a unit of time called the "jiffy" which was equal to the time it takes light to travel one centimeter in a vacuum (approximately 33.3564 picoseconds).[2] It has since been redefined for different measurements depending on the field of study.[3]
   / Alien Invasion - I want my pond back ! #112
You bend a 5-6' U in the end of the pipe, dip the opening down into the water from one side and start tipping it up and out. That'll fill 3-4 feet of pipe. Stand up and walk it up the hill until its higher than the top of the hill and drop the lower end of the U. The water will run down the pipe and stop at the half way point because in our previous discussion, you brought both ends up to the top of the hill. Then repeat that process until you get enough water in the hose to overcome the rise. Since you're only lifting 5' of water each time, its about 7 pounds at the most each time. Then drop one end into the pond and drag the other end back down the hill to the drainage area. That water sitting in the half way point won't move until you straighten the half way point, so the hose is empty until then. You'll only be pulling half the hose down the hill. It will be light as a feather at first and only increase in weight to a max of 135 pounds towards the end Once you straighten the half way point, that slug of water in the hose will fall down the hill and pull water through the hose up and over the hill. Piece of cake.
Eh, maybe. Not on Eric's long hill, you won't have the endurance. :laughing:
   / Alien Invasion - I want my pond back ! #113
Kyle, see post #89 = He'll be back on Friday.
And, yes, time in the UK is the same... in fact, it's where it starts! (GMT) :)
... or is it the international date line?
   / Alien Invasion - I want my pond back ! #114
Oh, I still function well. Can't think worth a hoot, but still strong physically. :cool2:
   / Alien Invasion - I want my pond back ! #115
Im getting about 9kGal/inch. 14000 is a factor of ten so thats a typo. :confused2: ... anyway, around 6GPM for an inch a day. - - As mentioned earlier, replenishment will increase as it drops because hes draining saturated ground around. Evaporation loss will decrease as well.
Not sure of depth, but head will decrease as it empties.
I used imperial gallons.
   / Alien Invasion - I want my pond back ! #116
I refer you to Post #72 where Eric states:
Perhaps I should have explained earlier that I had to get the water up a small hill, across the top and down the other side before gravity would become my friend. For the first 100 yds it is on a constant rise.
You better be in really good shape to make the football field-long trek up that slope numerous times while wrestling with a pipe. :laughing:
But seriously, if you managed to fill the far end down slope pipe with water one slug at a time without an EMS call, once you start to fill the uphill running pond end, you have a gravity problem. The water in the pipe will have enough head to flow out when you dip the open end into the water. It's like you are expecting water to run uphill in order to fill the pipe.
If the pipe was a bit flexible and somewhat durable, it could be flooded end to end in the pond, close a valve at each end and drag one end over the rise with a tractor.
   / Alien Invasion - I want my pond back ! #117
This is better than that pallet thread!
This is 1000% better than that pallet thread!
May it rest quietly in peace!
Are yall talking about that stupid thread about what these pallets were doing in a farmers field and everyone was guessing? I havent been on here as much in the last few years but even i read some of that thread!!:eek:
   / Alien Invasion - I want my pond back ! #118
I'm going to go ahead and surmise that this 10 year odyssey has ended with or will end in an afternoon with one of theseView attachment 426366
I would of just rented one of those from the get go and not wasted all my preciuous weekends doing all of this...but thats me.
The MS361 is awsome!!!:thumbsup::D
   / Alien Invasion - I want my pond back ! #119
The pallet thread was devoted to discussing the purpose and merits of pallets stacked in an otherwise empty field, and served as nothing more than a HUGE waste of time. It's sole claim to fame is that once in a while someone will revive it, setting in motion a whole new set of "they were put there by aliens", "they only breed when nobody's looking" and "we already covered that" responses. Be thankful it didn't turn up in the search!:shocked::laughing:
yep i remember the alien idea....same thread i was thinking about. I got into it a few pages and was like is this person really serious about this question then the responses were as fun as anything.
   / Alien Invasion - I want my pond back ! #120
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2013 Nissan Juke SUV (A59231)
2013 Nissan Juke...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
John Deere 3025E (A53317)
John Deere 3025E...
