Cleaning Vehicle Carpets?
/ Cleaning Vehicle Carpets? #1
Green Power
Nebraska
LS R4047H, Kubota L33400 JD: 5075E 6150M 9230 and 8520
So what does everyone do to get all the mud and dirt out of their vehicles carpets and floormats? I did a search on here but did not see too many results.
/ Cleaning Vehicle Carpets? #2
I have actually pulled mine out and washed with tide, stiff brush, and let them air dry completely! LUTT
Does the tide work pretty well Lutt?
/ Cleaning Vehicle Carpets? #5
I wait until it's dry, then use my Craftsman shop vac to get any dry, loose material out. And then our Hoover Steam Vac that I use on the carpets in the house has a smaller hand held wand that has done a pretty good job in my old Ranger so far.
/ Cleaning Vehicle Carpets? #6
There's carpet under the dirt????:shocked:
I clean it the same as other carpet. Vac, brush, vac, carpet cleaner.
/ Cleaning Vehicle Carpets? #7
how clean do you want it? compressed air works pretty well as long as it's dry. pressure washer does the best, but need to be removed from the truck/car
About as clean as i can get it for $10 and 2-3 hours of work...
I did this on three floormats, really noticed a improvement on two...
/ Cleaning Vehicle Carpets? #10
This advice came from a pro cleaning some house carpets. The regular carpet cleaners and using any kind of soap will live some soap and residue behind. A steamer won't. I bought a small steamer, I think from Griot's Garage, it works really well. Steam and then blot the stain.
/ Cleaning Vehicle Carpets? #11
/ Cleaning Vehicle Carpets? #12
What is wrong with soap left behind? seems like it might work as a "release agent" for the next cleaning. When I plan to do some greasy dirty work myself, I often "pre-soap" my hands by rubbing in either liquid soap or detergent. Works great when it comes time to wash up for supper ;-=)
Soap attracts dirt, like oil attracts dust.
I dont blame you there.
/ Cleaning Vehicle Carpets? #15
Some professional detailers I know also use white wall cleaner that comes in the bulk and cut it down with water so it's not so strong. Put the solution in a spray bottle and scrub within carpet cleaning brush. Of course after throughly vacuuming the carpet. Also throughly vacuum the carpet after you do any shampooing. A lot of people don't realize there is a pad under the carpet that will adorn the moisture. That's why I always pulled my carpets when there that bad so they could air dry. Most car detailers pull the carpets when there that bad for that reason, to allow them to air dry, insulating pad and all. LUTT
/ Cleaning Vehicle Carpets? #16
Woolite mixed in a 1:8 ratio with water
/ Cleaning Vehicle Carpets? #17
Removable floor mats: hose,dish soap, air dry, vacum
Fixed mats: rug shampo, brush, tired arms, wet vacum, vacum when dry, scotsquard.
/ Cleaning Vehicle Carpets? #19
compressed air then a steamer if you have access. pressure washer is the best way, but it requires more work removing them and then air drying
/ Cleaning Vehicle Carpets? #20
I had a really bad stain on my last truck's carpet. Pulled it out and even a power washer wouldn't get it.
Took it to a guy that dyed the stained area to match the rest. Looked like new again.
UNUSED WOLVERINE QUICK COUPLER 2 (A64281)
UNUSED WOLVERINE...
Pallet of Hay Tedder Tires (A64119)
Pallet of Hay...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A59911)
2012 FREIGHTLINER...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
Generator on Trailer (A64119)
Generator on...
