1986 case 255 tractor won't start
/ 1986 case 255 tractor won't start #1
Pipeliner542
Indianapolis in
case 555 dozer,Jd 4115,jd 310 tlb, bobcat 610, kubota mini ex.
I have received a case 255 tractor it has a mitsubishi k3e motor. It has been sitting outside unused for two years. I drained what fuel was in it. Flushed tank, installed new hoses and filter to injection pump. injection pump is gravity fed on this model and fuel flows freely to inj. Pump inlet. I installed new battery with a charger hooked to it to keep a full charge. Disconnected injector lines from the injectors on all three cyl. Cranked motor in several 15 to 20 second intervals taking care not to burn out starter. No fuel to injectors. Did this several times nothing. So I unhooked glow plug wires ( They don't work anyway) removed air cleaner and cranked engine giving it a shot of starting fluid. Nothing. motor didn't pop or try to start at all. I didn't have a diesel compression gage but putting my hand over intake hose will suck hand to hose tight enough to leave ring on palm.. only thing that did happen was a few puffs of black smoke and then cleaned out didn't sound like it hit to even try to start. Tried it again same results won't fire on starting fluid. Previous owner said it ran when he parked it. I figured the inj. Pump is bad or it is has air in it. Don't see any other bleeds on it. So the tank is higher than injectors I left lines off overnight figuring it might self bleed the air out but no such luck. The pump has a solenoid on it that pushes in freely. key does nothing to it but if I jump it with 12v it will move in. Does this have to be in or out to run?
I'm gonna try a mity vac on the injector lines and try to draw fuel through the pump maybe it will prime. Anyone got a source for a reasonable replacement or a rebuild?
/ 1986 case 255 tractor won't start #3
To bleed the system you need to do it one injector at a time not open all three.
If it was running and not altered before it sat, it should be just a matter of bleeding the system.
Dave M7040
I'll try that then.. I'm open for any suggestions at this point
No luck I was pulling over 120in of vacuum per injector line and no fuel will flow through pump. I even tried cranking motor while pulling vacuum and still nothing. I also tried holding in elec. Fuel solenoid while cranking under vacuum. No fuel. Also tried cycling throttle while cranking under vacuum nothing. What could be blocking fuel from flowing to all/any of the injectors. It has to be something inside pump at this point. I also can't assume this was running when he parked it so who knows at this point.
/ 1986 case 255 tractor won't start #6
It wouldn't even try to start on either?
/ 1986 case 255 tractor won't start #7
Disclaimer: Be very careful doing this ... Soak a rag in gas, ring it out then cover the air breather with the rag and crank the tractor. DO NOT LET THE RAG SUCK INTO THE AIR BREATHER ... if she fires immediatly pull the rag away ... may have to do this more than once.
Its not a good practice however if its going to crank and run it will.
No did not even try on ether. I seem to have multiple problems. The lack of starting on starting fluid and the fact I can't get fuel through pump. At least if it fired I would pursue a pump rebuild. Not firing im guessing Should be a lack of compression issue. Valves or piston or rings. I'm not a diesel mechanic. just have always been fixing my own equipment so I figured I was missing something. I really need compression numbers I guess. can someone confirm how the fuel shutoff solenoid works on this motor in or out to cut off fuel. It also has manual fuel cutoff attached to cable I'm assuming that it gets pulled out to cut fuel.
I'll try the gas rag... If that doesn't work I'll stuff rag in tank and use to light burn pile. I was hoping if it fired it would get pump working..fingers crossed
From front of motor back 525 520 530
gas rag made it seem like it wanted to start.
oiled cyl. With some 30 wgt. with glow plugs out retested 550 525 550
So compression is good didn't check valve adjustments but they should be close.
/ 1986 case 255 tractor won't start #11
Keep using the gas rag .... may take a few trys ... just don't let it get sucked in.
/ 1986 case 255 tractor won't start #12
Is there any evidence of previous work the the engine? Shiny spots on bolts, bathroom caulk used as a valve cover gasket. You know.... Bubba tracks. This may provide you a clue if someone has tinkered with the engine. If I saw any signs of previous "work" then I might pull the valve cover and check real quick. The fact that you say compression is good says this isn't an issue but might be worth a glance.
The solenoid on the injector pump might be the shutoff solenoid, make sure the shut off lever isn't closed.
Get a manual and go through the bleeding procedure again. Make sure there is good flow to the injector pump.
Check for a clogged screen in the bottom of the tank and that the filter bowl is sealed tight.
/ 1986 case 255 tractor won't start #13
We have one and there's a few safety things to starting it.Range selector has to be in neutral, pto off, and out of gear. There's a red kill lever on the dash that has to be pushed in. Don't push in the clutch when cranking. Ours likes glow plug when engine is cool.
/ 1986 case 255 tractor won't start #14
Don't push clutch while cranking? That's a new one.
Jim
/ 1986 case 255 tractor won't start #15
Don't push clutch while cranking? That's a new one. Jim
If the range selector is in neutral, technically you wouldn't have to disengage the clutch on a gear tractor. The 255 gear tractor does not have a safety on the clutch it is on the range selector, which must be in neutral.
I agree with the previous poster. Get the glow plugs operating. You might try a jumper from the battery to the glow plug contacts. Give them about 20-30 seconds and see if the motor tries to start.
The harness has been a weakness on my 254. The ignition contacts tend to corrode, the glow plug wiring has fallen apart. May have to make a simple starting circuit. If you unplug the safety solenoid on the injector pump this w
/ 1986 case 255 tractor won't start #16
My guess is one or more stuck plungers in the injection pump which is then sticking the rack in the shutoff position. If it has truly been 2 years since it 'ran when he parked it' that is more than enough time for it to gum up. Modern fuels don't take long to shellac up and make things stick. Is there a small square/rectangular access cover on the side of the block right below the injection pump? If you pull it off you can see the linkage connecting to the rack. With the shut off solenoid energized out of the way the rack should move side to side with little effort. If it doesn't move don't force it, the pump will need to come apart and be cleaned up.
As far as not starting on ether, I've had some engines that just don't even with good compression and valves properly adjusted. It would be ideal to hear it run before spending money on the pump, but it just may not happen. Your compression numbers look great so it's a fair guess that the engine is in good shape.
/ 1986 case 255 tractor won't start #17
If the Case set up is anything like the K4F on the Hurlimann, there is a solenoid fuel shut off. Unless that get's opened up (and it might be stuck closed) the engine won't get fuel.
Check for that shut off valve and figure out if it's opening or not before messing with the fuel pump. For that matter, is the lift pump doing anything?
Why it won't start on ether is a mystery with those compression numbers.
