Grapple build on a bucket, Center or ends?
/ Grapple build on a bucket, Center or ends? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
If one were to build a "simple"( read: a single double acting cylinder) grapple upper clamping jaw, onto an existing bucket, is there a layout or operational advantage to "a pair of teeth near the center of the bucket", or "a pair of teeth one at each end of the bucket"?
This is for "light duty" slash moving, and an occasional tree trunk relocation with a compact compact tractor.
No heavy lifting, no all day work sessions, no digging rocks and roots from their hiding holes ;-)
But I'm sure a grapple would be called on to help move a rock or two from time to time, this is Vermont! ;-)
/ Grapple build on a bucket, Center or ends? #2
My set-up works very well for all around work. Crooked logs are not a problem with multiple tangs though I have heard it said they would be. I think multiple tangs are much better for brush. At least in VT they are :D
Edit:
For rocks you want more than one tine also
gg
/ Grapple build on a bucket, Center or ends? #3
I went with centered and found it works fine for all my uses.Also a tooth bar makes it more versatile.
/ Grapple build on a bucket, Center or ends? #4
that is just a silly place to take a nap.
*like the grapple
/ Grapple build on a bucket, Center or ends? #5
Center is closer coupled therefore stronger and can be X braced easily. Difference in debris/log diameter over the length of bucket matters less. Jaw is less in the way when maneuvering. [Probably] less weight.
New Holland 3930 (A60462)
New Holland 3930...
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
Miller Millermatic 212 Auto-Set MIG welder (A61307)
Miller Millermatic...
Case-IH 370 Steiger (A57148)
Case-IH 370...
KJ K1119 11'x19' Carport (A60463)
KJ K1119 11'x19'...
2014 BMW X1 S Drive 28I SUV (A61569)
2014 BMW X1 S...
