Quick Hitch and Lifting Shrubs
/ Quick Hitch and Lifting Shrubs #1
cmcramer
Member
Oswego, NY
none
The Land Pride Quick Hitch on my Kubota L2501 works great and I do not want to take it off (I'm only half handy) But I do want to use the 3 point hitch and a chain to lift some shrubs out of the ground, and maybe lift some small logs as I drag them out of my woodlot. What's the best (safest) way to attach a logging chain to the QuickHitch? Should I add a 'horizontal draw bar' that somehow fastens into the QuickHitch? Thanks!
/ Quick Hitch and Lifting Shrubs #2
I would hook it up the same way I would if I didn't have the QH on the tractor..
/ Quick Hitch and Lifting Shrubs #3
For skidding logs I use a choker chain attached to my FEL . I keep the logs nestled in the bucket and lift them just an inch or so off the ground and keep them low and slow as I back to my yard. If you have a qa FEL you can jet a stump bucket that would be great for digging and moving shrubs.
Sent from my iPhone using TractorByNet
/ Quick Hitch and Lifting Shrubs #4
Which means a drawbar, yes. Don't forget the bushings when you get the drawbar.
2006 7X12 Lark S/A Enclosed Cargo Trailer (A66738)
2006 7X12 Lark S/A...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
Unused 2023 Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023...
PORTA POTTY (A68842)
PORTA POTTY (A67714)
