Quick Hitch and Lifting Shrubs
   / Quick Hitch and Lifting Shrubs #1
cmcramer
Member
Oswego, NY
none
The Land Pride Quick Hitch on my Kubota L2501 works great and I do not want to take it off (I'm only half handy) But I do want to use the 3 point hitch and a chain to lift some shrubs out of the ground, and maybe lift some small logs as I drag them out of my woodlot. What's the best (safest) way to attach a logging chain to the QuickHitch? Should I add a 'horizontal draw bar' that somehow fastens into the QuickHitch? Thanks!
   / Quick Hitch and Lifting Shrubs #2
I would hook it up the same way I would if I didn't have the QH on the tractor..
   / Quick Hitch and Lifting Shrubs #3
For skidding logs I use a choker chain attached to my FEL . I keep the logs nestled in the bucket and lift them just an inch or so off the ground and keep them low and slow as I back to my yard. If you have a qa FEL you can jet a stump bucket that would be great for digging and moving shrubs.
Sent from my iPhone using TractorByNet
   / Quick Hitch and Lifting Shrubs #4
Which means a drawbar, yes. Don't forget the bushings when you get the drawbar.
2020 FREIGHTLINER CASCADIA SLEEPER (A51222)
2020 FREIGHTLINER...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
SET OF (4) TITAN MULTI TRAC C/S TIRES & WHEELS (A51244)
SET OF (4) TITAN...
2000 Genie S-60 60ft Articulating Boom Lift (A50322)
2000 Genie S-60...
International 490 24ft Disc (A52128)
International 490...
