Tractor Sizing Help with a Kubota purchase
   / Help with a Kubota purchase #1
FatTireFarm
Butler, Ohio
None
Hello, I'm new to the forum but have read many threads about buying the right size tractor. I must admit, the more I read, the more confused I've become. I'm looking to buy our first tractor to manage the 20 acres we just purchased. The property has five acres to finish mow and the rest is wooded. We won't be "farming" the land but plan to till our own garden, maintain 100 yards of gravel drive, plow snow, move mulch, build trails, etc... I'm not planning to mow the yard with the tractor, I'll probably use a ZTR, so MMM is not a requirement. I would like to add a backhoe someday. I know it's a luxury but one I'd like to have. I've been looking at tractors in the B and L class of Kubota. I've been reading a lot about the new tier 4 problems and would really like to avoid it. At the same time, I understand the pre tier 4 L3200 and L3800 have jerky 3 point hitch problems. I really like the B2650 but worry about it having the guts to do the things we need it to do. I don't want to drive into the dirt pile for the first time only to find out the tractor doesn't have enough power to fill the loader. I've read that hp only determines the speed that you can do work but I have nothing to compare that to. The other option I've looked at is the new L2501. It weighs more than the B2650 but has slightly less hp. I wish a BX25 would do the trick but I know I need more ground clearance in the woods. Most people on these forums seem to advise more hp, more hp but that takes me into the tier 4 unknown. Budget vs hp is also a concern. If anyone has any advise on the B2650 vs L2501 vs ???, please let me know.
   / Help with a Kubota purchase #2
We bought an L3800 one year ago and so far so good... 65 acres of Christmas trees with some pasture... the backhoe is OK... a little on the smaller side... I have a Deere 110 with an awesome backhoe at the other property and wanted to avoid moving it back and forth...
I also have a BX23 which has been great... first problem in 10 years is a sloppy loader joystick... you are right... things that make it an awesome mower like lower ground clearance and smaller tires work against you in the woods...
   / Help with a Kubota purchase #3
A couple off points if you haven't already considered them. The smaller B's are awesome little machines to be sure, but the heavy work really demands equipment designed for that kind of work. Building trails in the woods, for example, inevitably means moving, digging stumps or rocks and other work that demand some power and heft. In my mind that calls for something in the 40+ horsepower range and appropriate attachments. If you're thinking that kind of activity is or will be on your agenda, plan you purchases accordingly. That aside, it's still better to go a bit larger than you first anticipate because the work to be done always seems to grow rather than shrink.
I know that puts you squarely into that Tier 4 dilemma and you'll have to figure that out from what others are saying. There are those that say "Wait til it gets sorted out" and those that have bought Tier 4 and have no problems. There's also the odd chance you can find a truly nice used rig that solves the emission problem and fits your budget.
Good luck in your search.
   / Help with a Kubota purchase #4
:welcome:
To TBN FatTireFarm. I went into the dealer looking at the B2650 with even less acres. The dealer said he would sell me anything I wanted, but he could not recommend it for my needs. He suggested a L series and even recommended a L4600. I compromised and took a L3200. It has done everything I have asked it too, but now I wished I had listened and went with the L4600. I just can't imagine how upset I would have been if I had stuck to my original option.
   / Help with a Kubota purchase #5
My brother would have been in the same boat... he was so impresses with what my little BX23 has accomplished... moved hundreds of yards of material built trails... etc... over 10 years... he wanted one and liked the price.
Stressed it would be a mistake for his acreage and what he wanted to do... and that is how the L3800 joined the fleet.
He was intimidated by the L at the Dealer because it looked so big... not nearly so big out on the ranch/tree farm.
His 12 year old son is a natural with the L... careful, precise with a good hand for loader and backhoe work...
Thanks for the feedback. This forum is awesome. It's great to learn from others experiences when I have none of my own! I was really thinking I'd end up with the B2650 but now I think I'll have to reconsider. Fortunately, I have some time. There aren't any pressing needs for the tractor yet. I'd like to find something by this or next Spring though. Perhaps I'll know more about the tier 4 stuff by then.
The only dealers close by are Kubota and JD. Does anyone know if JD is having tier 4 problems like Kubota? I really like Orange due to it's reputation and it all being made by the same folks versus pieced together like JD. Not to mention Orange is usually cheaper than green. That being said, I'd be open to consider JD if they have a 30-40hp machine that's trouble free.
Lastly, our "farm" is more for play than work. So I foresee many short uses of the tractor rather than long days running at PTO speed. Does that make the DPF even less desirable/more prone to problems?
Thanks again!
Ultrarunner,
Have you had the jerky 3 point issue with you L3800?
   / Help with a Kubota purchase #8
It could be smoother... not that it is a problem... use the 3-point 80% of the time.
Another question...I've assumed I would buy an HST tractor but have read a little about GST. Better or worse? Dependability and maintenance?
   / Help with a Kubota purchase #10
Welcome, I suspect you will like it here and find a great deal of info. :welcome:To share my experience, I have a "hobby" farm as well and could not see having anything less than something in the L series. My father has a B and it is great but would not satisfy the uses I have. I recently upgraded from a gear shift L2250 to an HST L3901 :dance1:. I, like you, had concerns about the Tier IV piece, but after my research and the deals that were available at the time....I pulled the trigger. Could not be more pleased. The jerky 3 point is gone and the HST is a dream. Cannot see myself going back to a gear drive. I am also of the mindset to buy a bit more tractor than you think you need. Case in point, my L2250 did the job, but the L3901 has more HP and the increase is a welcomed addition and experience. Best of luck.
Deerslayer,
How long have you had the 3901? Does the tractor regen regularly or sporadically? What happens if you shut it down in the middle of a regen?
   / Help with a Kubota purchase #12
Deerslayer,
I have only had it for a few weeks, so not enough hours on it to have it regen. But there are others on TBN who have not had any issues with the regen so hopefully they will chime in. It is not regular intervals; my understanding is that it will regen when it needs to based upon how much particulate collects in the DPF which is based upon how the tractor is used. Higher rpms=hotter=less particulate=less frequent regens. Figures I recall seeing here from others were like between 25 and 50 hours.
Like anything else, there are pros and cons to everything. I have also noticed that the engine runs much quieter than my L2250 and there is no appreciable exhaust smoke or smell(neither which bothered me before anyway)
If you haven't done so already, I would suggest you go to a dealer and try out an L and a B and see what you think. But beware...its kinda like going to look at a prospective puppy. Once you see it, you want to take it home with you.:D
   / Help with a Kubota purchase #13
That's why the successful dealers have a LOT of stock onhand. My nearby Kubota dealer currently has 25-30 new Kubotas on the lot and he's in a very low population area.
   / Help with a Kubota purchase #14
Hi, I picked up a new L2501 little over a month ago and I am loving it. Plenty of power for what I do and I like the extra ground clearance and the loader. I have had a blast so far. :D No jerky hydraulics or any problems so far, at 10.5 hours.
Gwstang,
What kind of chores have you done or are planning to do with the L2501?
   / Help with a Kubota purchase #16
Clearing off trails and taking care of my lengthy driveway with a 6' boxblade. Using a 5' finishing mower for the front fields (about 4 acres) then bush hogging the trails and other fields (about 10 acres). I have 71 acres total and lots of tornado damage from an EF4 back in 2011 and my old Ford 8N does not have an FEL (or 4 wheel drive) and I need to be able to get to the back side of the property for more work. I chose the smaller L2501 over the larger models because I can use the finishing mower around the house without destroying the lawn. My wife use to jump up and down when I would cut the lawn with the old 8N, as turning around would leave ruts. I like the R4 tires. I rebuilt the engine on the old Ford and it is still a good machine....but, The new tractor gets "sat" on a whole lot more now. Boy, if you want to see a red-head really get excited...just "accidentally" run over some of her bushes or roses with a mower. Sicked the danged chihuahuas on me :eek:
Ok, so I think I've found a good used 2012 L3800. I haven't seen it in person but plan to this weekend. It only has 70 hours on it and looks clean in the pictures. Does anyone know of a checklist that I can use to go over the tractor with? I wish I had someone with me who knows what to look for but it'll probably be just me. I'd like to know what problem areas to look for and how best to "test" the tractor. Any input would be appreciated!
   / Help with a Kubota purchase #18
Could be a good find there. It should have received the initial 50 hour service, so ask to see the paperwork. Being that new and with such low hours it should be in excellent condition with minimal cosmetic wear. Check for any fluid leaks (engine, hoses, seals, etc...) Is it gear or HST? If gear, drive it through all the gears. If the owner can put an implement on the rear for you; raise and lower slowly to see if you will be able to live with the jerkiness (many can). Try out all directional functions of the FEL. Run the PTO. Engage and disengage the 4WD. Test each brake individually. Check all light functioning. Check zerk fittings to see if they have been greased.
I always like to at least ask why the person is selling it being so new. Find out if it still has any warranty left on it. I suspect others will chime in, but these are a few ideas. Good luck and let us know how you make out. Does the asking price seem reasonable as a starting point?
   / Help with a Kubota purchase #19
It looks like you are looking at the L series - That is a good thing...
I have less land than you, and a small orchard. I started with the B series with a loader. After two years I had only 96 hours on the tractor, and that was all from mowing. The bucket was to small to do a lot with and can only lift around 500lbs. I found I took off the loader and never really made use of the B for much more than mowing... Tried tilling with it, low ground clearance required the removal of the MMM to do anything int he garden, and the 26 HP was fantastic as a mower, but int he garden, all that HP was wasted as the little B would just spin the tires. The brake pedal was above the hydro control, so there was no way to do precise work with the loader... etc..
I have since sold the B and bought a 35HP tractor. I made my first payment on it last week, and have already put 26 hours on it. With the weight it puts the HP to the ground, unlike the little B spinning the tires and diggin itself a hole. I was able to till the garden grade the drive way, plant more trees, and having a proper sized bucket that can lift 2000lbs, as well as the quick attachment system sure makes planting and watering the new trees a joy. I went with a finish cut mower to do the mowing(about 4 acres), 6 feet at a pass makes the yard work go fast. In fact you may want to reconsider mowing the large portion of your yard with a finish cut mower, keep the ZT for the close up work.
I am not bashing orange, or the B - it was a great tool, it started every time, and never gave me any issues at all. It was the first tractor I bought, and I made a mistake by going to small for my needs, good thing about the orange, I did not lose money on the tractor swap.
My suggestion is buy more tractor than you need, having a tractor that is a little bit larger is a much easier problem to live with than having a tractor that is just to dang small to get the job done.
   / Help with a Kubota purchase #20
We've settled in on an L3400, same as the L3800 with a bit less hp, and so far I am finding it a good compromise between size/weight and ease of getting around without destroying the ground. Soil compaction was a big issue with my wife, but on the other hand, another 1000 lbs of tractor on a little bigger frame would obviously be a plus for some functions. If you buy it at a fair price, you should be able to resell it and move on once you have more experience with you needs without taking much of a hit, at least that's been my experience so far. The L3800 is a handy machine for a lot of tasks, but small for others...
I didn't notice it mentioned, but look for a SSQA loader bucket- you'll be glad to have it. Rear remotes are handy, and I think you'll prefer HST if you do much loader work. Then there's the open station vs. cab issue, but since you'll be in the woods, maybe freezing your butt off in the winter is your fate?
One other thing to check is the functioning of the safety interlocks and hydraulics... lots of guys will just use the loader to lift the front of the tractor off the ground to demonstrate "strength" which is guess is valid. As Deerslayer mentioned, check the 3 point hitch with a heavy weight on it- the jerkiness problem doesn't show up without weight, and only when trying to slowly lower does it "jerk", which is not a problem for some folks, but is for others.
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2005 WESTERN STAR DUMP TRUCK (A60430)
2005 WESTERN STAR...
2012 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2012 GENIE...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2022 FREIGHTLINER M2 BOX TRUCK (A59905)
2022 FREIGHTLINER...
