Use tow hook?
/ Use tow hook? #1
Ridge
Can I mount a tow hook on my 7TL loader bucket that has quick attach? I just normally use it for lifting but have used one on my other tractor for pulling trees that I have cut down when they get stuck on another, I like being able to an eye on the tree as not to get injured.
/ Use tow hook? #2
All of my buckets have hooks on them, and every tractor I have owned has had them. I don't see why yours can't have some too! :)
/ Use tow hook? #3
A tow strap on the bucket is not going to hurt the bucket but it could damage the operator if the tow strap breaks and comes flying back at you. If I were to use the FEL to drag an object back while using a chain, (I would only use a chain and not a nylon strap due to the kinetic energy stored in the stretchy material ) I would keep the bucket on the ground in float position or at least very near the ground so any flying straps would be below the operator platform.
As for mechanical failure of the QA system, There is no issue there. It is stronger than any force that the tractor can produce. One does have to make sure that a limb or other object does not hang on the release handle and pull them up. If this happens, you can damage the FEL badly by springing one of the main beams when the bucket comes off one side.
/ Use tow hook?
I only use chains, never fast and have chain tight before really starting to pull. Most of the time it is used to help lift something at home but I do use it to pull down stuck trees after cutting (not big trees) my real concern was the QA if it could hold against the pulling,
Thanks
/ Use tow hook? #5
My only concern would be the FEL arms if you pull too hard with wheels. Hydraulics-only would cut off before any damage can occur. But when being driven by wheels, you can do damage. It's mainly a concern when people over-do it while using the FEL as a bulldozer. But I can see the same issue happening in reverse if pulling from the FEL with a chain. So be careful.
/ Use tow hook? #6
My son just damaged the loader arms pulling down a stuck tree (busted a bolt and put a bend in the support mount). It was on an old Kubota L245DT. I think the tow bar below the PTO is a better option.
Just for your amusement, the one bolt is $85 at the Kubota dealer.
/ Use tow hook? #7
Here is a pic of what I use. Lots of options this way.
/ Use tow hook? #8
this about covers it. The ball hitch can be turned over so hook is on top. I don't use the FEL for anything but lifting and pushing. I haven't used the hook yet, but it's there if I need it.
/ Use tow hook?
I like the 3 point option and will look into those too
/ Use tow hook? #10
Honestly, when pulling with anything you should use a chain AND a strap. Chain to pull, strap to wrap around the chain and catch it should it break... I don't care if it is a huge chain and tiny load, anything can get weak over time and eventually snap. It only needs to happen once to end your life as you know it.
/ Use tow hook? #11
Best idea I've seen for that is a nylon rope woven through the chain links so it doesn't get in the way.
Bruce
/ Use tow hook? #12
Here is a pic of what I use. Lots of options this way. <img src="http://www.tractorbynet.com/forums/files/bobcat-tractors/424598-use-tow-hook-image-3754494685-jpg"/>
Wow, that is perfect for what I need. Just curious, where did you find it?
Is that home made? (I can't weld, I know,, hard to believe.)
/ Use tow hook? #13
Sure you can weld! You may not have a welder, and you may have never tried it, BUT you CAN weld. It is well within your capabilities, and besides that it is fun!
/ Use tow hook? #14
Here are my additions for pulling or lifting. I think good common sense plays a big part in safety. The little Kubota mower is just parked between the loader frames. :D
/ Use tow hook? #15
I bought the adapter at Menards its called a step bumper hitch I think. I have also seen them at Harbor freight they run between 15 and 25 bucks. Every now and then you see the exact same one for about 40 somewhere not sure what they're thinking. Yes I welded mine on but it would be no problem to drill and bolt it also as long as you have a flat surface. I came up with the idea because I was thinking about putting a winch on my tractor and decided I will just go with a hitch mounted winch instead in this will give me another mounting point for it. Another thing that it works out great for is I can pick up three point attachments just by looking the ball underneath the top of the attachment as long as there's a pin in it and roll the bucket back.
/ Use tow hook? #16
Well, I guess I could weld, given some instruction, and a welder. I guess I could also take the bucket off the loader, and take it in somewhere to get welding done. It's all just time and effort..
Tman, is the hook already on the hitch receiver, or did you weld it on also? I need to go by Menards for other stuff already, so I'll be looking for this.
Thanks
Jeff
/ Use tow hook? #17
No I welded the hook on to it but you could just have the hook welded on the hitch first then bolt it to your bucket. Or they make all different kinds of slide in drawbars including some with different kinds of hooks.
/ Use tow hook? #18
/ Use tow hook? #19
I have a QA reciever hitch for the front and a 3pt one (doubles as a hay spear) for the back. The best prices I found were Titan Equipment. They have several sites and sell on ebay. I scored big on the front reciever hitch through one of their many auctions.
I use mine to move my trailers around the lot. Really makes it easy.
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
UNUSED WOLVERINE LAND LEVELER (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
