XR4040H loader+ pallet fork lift test - would like comments from LS
   / XR4040H loader+ pallet fork lift test - would like comments from LS
I measure it at both locations
directly from an email from LS( Harvey J Brock)
"2250 PSI is the max. so it is near the upper spec already."
Harvey J Brock
Head of Service
LS Tractor USA
   / XR4040H loader+ pallet fork lift test - would like comments from LS #44
Harvey J Brock
Head of Service
LS Tractor USA
What does your manual say? 2250 psi seems entirely too low.
   / XR4040H loader+ pallet fork lift test - would like comments from LS #45
I agree, what does YOUR manual say hitecredneck1? It should be listed in there.
I called my local LS dealer and he looked in the manual. It did not list a pressure for the X4040H, but he said that the gear version is rated at ~2450PSI.
He gave me the number for LS corporate (252-984-0700) and said to ask for someone in service. I did that and the gentleman who I spoke to said that for the X4040H "The system pressure should be between 2250 and 2450 PSI, but not over 2450PSI"
hitecredneck1: Read your manual and tell us what it says.
Aaron Z
Just found it on, pg 7-4 of Operators Manual System pressure 2466 max. Looks like the frame may also be an issue.
"If you go and start adjusting pressures on loader pressure and bend your engine frame you will void your warranty. "
Ricky Marks, Service Manager
L S Tractor, USA, LLC
6900 Corporation Parkway
Battleboro, NC 27809
   / XR4040H loader+ pallet fork lift test - would like comments from LS #47
tractor is currently at the dealer getting leaks and this issue fixed. Going rerun tests when it comes back.
   / XR4040H loader+ pallet fork lift test - would like comments from LS #49
trade it, you can jump up and down and throw fit and I bet they won't buy it back. how are you doing you test, forks flat lifting straight up, curling forks back then up, many ways of doing it. does loader have two holes for cyclinders one for height and one for load?
True, but all I can do is document and share the test results and methods used. Forks were inserted flat then lifted up. The loader does not have two holes, but the Kubota M6060 does.
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
Electric tri scooter irgc40 (A56859)
Electric tri...
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
