Backing procedures...RIO question?
/ Backing procedures...RIO question? #21
And drop the mower deck off before the dealer gets the tractor, if the deck isn't needed for service.
Says a lot for learning to service our own equipment.
/ Backing procedures...RIO question? #22
This is very important for owners that may some day take their mower to the dealer for some kind of warranty work or repairs. Any and all safety features will need to be restored prior to them returning the mower to you. Seat switches, RIO switches, mower deck chutes, etc. will all need to be in place. These can be very expensive to restore to proper operation and will certainly cause some unpleasant surprises when you pick up the equipment.
That is one reason to have all "mods" done in such a way as to be easily restored in the unlikely event you need to have some warranty work done.
A very good tip. The first thing I did with my X530 was to remove the deck chute which allowed me to mow a heck of a lot closer and to fit the mower into areas where it would otherwise not fit. Thanks!
/ Backing procedures...RIO question? #28
The riding lawnmower I bought the girls is a JD300 and of course has a RIO feature. The last of the girls is now in the process of moving south following their work so I'm going to have to start mowing two lawns. There will be a jumper in my future.
One thing that does annoy me is seeing a neighbor driving a lawn tractor with a grandchild in his lap. I've read that tragic story too many times to not feel queasy every time I see it.
/ Backing procedures...RIO question? #29
BigBlue
It started when Sears was sued (and lost) not JD, and the other companies followed with RIO's. No JD lawsuit, IIRC.
There may be some local or state laws that require it (such as the left leaning CA laws) but I'm not aware if that is the situation.
Now the dealer insurance companies are involved in requiring that their dealers not allow a machine out their door without all safety devices in working order. That is done to lower the possible claims on the dealer that have to be paid by their insurance. So it is a vicious cycle.
I haven't actually checked but the story that was told was a guy backed over his 3 years old daughter in Cleveland while using a Yardmachine mower. There is a federal ANSI standard that requires the not mow in reverse unless you have a operator override system.
The, lack of a better term, first generation no mow in reverse wouldn't allow the deck to be running period if the mower was in reverse. The next generation which is what we have now, requires that the operator override the reverse system, providing the mower cannot exceed 1 mile per hour in reverse with the blades running..
/ Backing procedures...RIO question? #30
I am glad they haven't put such stupidity on zero turn mowers. Likely because they cant figure out how to keep them as zero turns if they have a reverse lock out since you have to reverse at least one lever to turn or both if making a K turn.
/ Backing procedures...RIO question? #32
I have tractored my boys and others sitting between my legs . They are not going anywhere . As far as RIO that child is going to be severely if not fatally injured before the deck comes into play . People have to be a part of this , a machine only does what it is told .
/ Backing procedures...RIO question? #33
Especially when they are mowing the graveled shoulder with the deck discharge pointing toward the road.
Aaron Z
Just encountered this again over the weekend. Grass and debris flying out onto the highway. I always cringe as I pass them expecting to hear a thump against the side of the car. I figure if you are going to mow with the chute up, make the first few passes along the road with the chute pointed AWAY from the road.
/ Backing procedures...RIO question? #34
As well, there will be rocks and debris thrown even with the discharge chute down... just not as much. I always try to get the windows up when passing mowers.
Rotary cutting mowers are dangerous.
Maybe soon they will be declared too dangerous for us to use. Back to the old reel mowers... wouldn't surprise me one bit, but won't be in my lifetime.
/ Backing procedures...RIO question? #35
Very simple, you set up switches on each handle and when both are pressed the deck shuts off. The reverse switch is a little over kill in my opinion. They should put a toggle switch on the machine that overrides it and resets when the key is cycled so that way if you know you are in the clear you don't have to worry about it but for the folks that like that option it's there.
/ Backing procedures...RIO question? #36
Thats what Cub Cadet does. Deere however feels that you should have to push the button each and every time.
Aaron Z
/ Backing procedures...RIO question? #37
Actually they have, will shut the deck off if both levers are pulled to the reverse direction. Seen on Troybilt, and Yardman.
/ Backing procedures...RIO question? #38
The first thing I did was jumper the RIO on my JD 130. Sold it to a neighbor a few weeks ago. Told him how I did it. Up to him what to do with the knowledge.
While traveling in Oklahoma a road crew mowing the medium throwing the debris onto the road sent a missile into the drive front fender of my Trailblazer.
Left a sever dent in the fender. Had I been in my Subaru and a couple of feet farther down the road it would have come through the window. Had enough force it would have cause sever harm to me and probably cause me to loose control of the car.
Notified the Highway Patrol and the Officer took the report and said I could file damages to get the vehicle repaired but did nothing with the mower operator. :confused2:
I guess it will take an injury to get something done.
/ Backing procedures...RIO question? #39
It will not be an injury ,a death ?
/ Backing procedures...RIO question? #40
What is that child doing in the the yard , by herself ?
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2012 HEIL 200BBL CRUDE TRAILER W/ PUMP (A63569)
2012 HEIL 200BBL...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
2002 International 9200i Truck (A61307)
2002 International...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
24220 (A56859)
24220 (A56859)
