Property line trail/ track
/ Property line trail/ track
Well, I MAY have encountered a little glitch in my plan. I was at the rental place I've got the SS booked at, and buddy asks me if I have a diesel fuel tank at my place. I told him I planned to use jerry cans... he told me to make sure I had alot of them... hmm. I was thinking $200-$300 for the week. Sat night I'm at a party and chatt up a buddy that runs equipment. He tells me that if could go through $200/ day!!!!! Oh My God... This news I get the same day I got two quotes for my daughter's tree house material that were both 2X what I had thought... and the same week my wife's car gobbled up $1,200.
Asked the Mrs what she'd rather; trail or tree house. She said trail. I'm pretty bumbed out. I had my daughter all pumped for a tree house, and now I have to break it to her that she's not getting one. This year at least...
Anyone know how much fuel this thing, or something similar goes through? I'll post in the Deere section
/ Property line trail/ track #204
I would plan on about a tank a day. The tank is 29 gallons, that's a good sized unit. But it'll depend on how hard you're running it and how many hours you work of course.
/ Property line trail/ track #205
We used to have a Case 1845 skid steer, and it wasn't a tracked unit. What I noticed with that unit is I would hardly ever run at full throttle, with most work at 60-70% power. Full power and I felt like I was on a bucking bronco.
I don't have any hard and fast data, but I do recall that Case sipping fuel when throttled back. Your buddy might be running his machine wide open, while on your rough trails wide open might dislodge your kidneys. Might want to question him on how he runs his machine before panicking.
Ok, those numbers sound a fair bit better then the $200/ day. I'm getting it one way or the other.... I may just have to get done what I can in the first 3, 4, 5 days instead of going all out for the full 7 days. If I can't finish the trail or exhaust the gravel pile before being broke, I'll at least loosen the pile so I don't have to pick axe to keep going.
One good thing is that buddy at the desk said I'm supposed to get 50 hours for the rental, but I could push that to 70. It's based on 10 hour days but the computer doesn't recognize the weekend.
/ Property line trail/ track #208
And, if you are running at 3/4 throttle without working it too hard (ie: moving gravel vs running a flail mower or a mulcher), I would be surprised if it used more than 2GPH, and I would guess that it will be more in the 0.75-1.5GPH range.
Aaron Z
Awesome. Thanks for the info. I'll report back after the first day.
Put another 3 hours of jackhammering in getting ready for the skid steer. Just another couple weeks! I can't wait!
/ Property line trail/ track #211
Yep, we are waiting for the pictures! :D
/ Property line trail/ track #213
So, despite best intentions and planning... sometimes things don't work out the way you'd like...
Friday morning @ 8:30am
So I started by spreading the 15 loads of fill I had for the yard. I was too excited to take "before" pics right away but realized maybe 1/3 of the way through
I also spread 2 tandem loads of class A on the driveway, beside the shed, and at both ends of the trail. De-stumped an area on the far end of my lot in anticipation of a garden next year. I also got to the gravel pile and started to smooth out the trail starting at the pile working my way out. 7.5 hours on day one. 90L of diesel at about $95
Day 2 started off badly. Couldn't make it up the 2nd hill heading out to the gravel pit. Tried for a while... slipped on stumps... started to dig big ruts and was getting close to getting hung up... wasn't looking good. Came inside and thought about it for a while... then it came to me that my neighbor wanted me to take a tandem load of 6"-12" stone from his place. I started shunting a couple loads... probably 6-8 before I tried making it up, and did. Off to the gravel pit! Started making trips as I intended smoothing trail as I went. Ran into a neighbor so stopped for a bit to shoot the **** and show off the machine. Next thing he's looking at it and says that one of the tracks looks funny. It's closer to the machine then the other. Huh. Sure enough, it's off. Called the rental place; no don't move it, we'll send someone out. Buddy shows up. I brought his tools with my atv and trailer.... first thing he says, and continues to say; this isn't what the machine's meant for. At thing point I'm freaking. How much are they going to charge me to have this guy come out and fix this!?!? 4-5 hours later, we get the darn thing back on. Great. Back at it I go... maybe 1/3 the way through the "connector" trail... then this;
Don't see it? How about this;
Went to turn around... and it was much steeper then I thought. Slid for a ways... scared the heck out of me. Messed around for a while... I'd set up a chain to a nearby tree, so that when I curled the bucket it would pull me ahead, but once I'd get close to out, it would slide back. Called it a day and went to dinner with my wife... but then started txting around... found two guys to come out with their jeeps.
Set them up one anchored to the other, with the lead winching with a snatch block on that tree that was across from the machine... man it didn't even stress at all. Just popped right up. I parked it and contemplated returning it monday morning. Probably put in 2.5 hours.
Day 3 started very well! Made it up the hill no prob. With returning it early in mind I decided to loosen up the gravel pile so that hand shoveling it later will be that much easier. As you can imagine, having to pick axe before shoveling adds 50% difficulty to the process. Here what I did;
Straight down the middle!
Made piles off to the sides
Funny to have trees falling off the top
Once I ran out of room to pile loose gravel I started shunting to the trail again. Things are going great and I'm 2/3 the way though the connector trail. I'm thinking I'll make my trail (which was the goal) by day 4 and have 4 days to build it... although I probably won't have enough time to finish it all. I txted my buddy to come take some video of me at the pit for my friends on TBN... but nope... went to turn around and; clunk clunk clunk. Threw the other track. That decided it! She's going back early. Called the rental place, but the tech on call was already somewhere and wouldn't be able to make it at all that day (sunday). They didn't want me to drive it out for fear it could completely come off. Got 4.9 hours in.
Monday morning around 10 (They open at 7) I called and convinced the guy I normally deal with that I could drive it to my house. I did, no prob. Come get it and fix it there. Today I went first thing to square up with them. Lucky for me I got buddy that I normally deal with... now keep in mind that I'm not sure if I'll be getting charged with the repairs... or for multiple days... or what. Long story short; I got charged for the single day rental. Still ended up being $600, but could have been alot worse.
Here she is after day one;
Pics of the track off before they came to get it;
Both sets of teeth should be inside the bogey wheel
Pics of the yard from the 2nd floor
So, that's it. I've been saving and dreaming about this for over a year... I must say I was pretty devastated... but I'm just gonna pull up my boot straps and carry on. I tried to take and short cut and it didn't work out. My little dump trailer and shovel shall carry on. :)
/ Property line trail/ track #217
I think you got a lot done. Love this project.
/ Property line trail/ track #218
Glad it didn't cost you anymore than that. Looks good what you got done. And that pile should be easier to work with. Just back your trailer in and shovel down from the top. A couple sheets of plywood should keep it going in the trailer and not under it.
/ Property line trail/ track #219
Is that typical rubber track behavior on rocky ground? Or a problem with this particular machine?
Bruce
/ Property line trail/ track #220
I love your thread and pictures, I've been following it for a while. Wish I lived close to you, I'd be over to help!
2022 Keystone RV Coleman Camper Trailer, VIN # 4YDTCMN20NH931920 (A65563)
2022 Keystone RV...
2025 Kearney 7'x14' Trailer (A64127)
2025 Kearney...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
