super55
- Joined
- Jan 27, 2012
- Messages
- 968
- Location
- Great North of Michigan
- Tractor
- Oliver Super55, John Deere 4310, John Deere 4400, Kubota L2500 (had),
For the amount of mowing you got a 52" 25 hp gasser would be minimum a 72" would most likely suit you better. Unfortunately 3-4k most likely isn't going to get you what you need for the amount of mowing you are going to do. If you were looking at new probably the bad boy mowers would get you as close as possible to your listed price range. They are incredibly stout mowers.
Buying a used commercial grade mower is another option. They usually have industrial gas/diesel engines in them but just remember all the hours on that engine are hard hours. I worked lawn care for years and every time that thing came off the trailer and mowing it was going at full throttle to get maximum hydraulic flow and blade speed. So if you find one with a thousand hours on it just remember that 1k hours was at wide open throttle. The other things to look over is the spindle bearings for the blades and the mower deck itself. A welded steel deck will give you twice the life over a stamped steel deck due to parts of it getting squished thinner from the press mold. This is usually in the curves of the deck right where rocks and sand will wear away at it.
Is there a lot of trees you need to maneuver around throughout the whole 4 acres? If it isn't too wet could you put a large finish mower on your kubota to handle the majority of the mowing and than use a ZT for the specialty areas such as around trees and the slopes? The reason I ask is because years ago when I worked lawn care we had a 5 acre field to mow on an occasional basis. It was faster for us to bring the large tractor out and mow it with a 7 foot finish mower and than have another guy come out with a ZT and a weed whip and go drive around tree to tree and touch up. That way the ZT wasn't getting overtaxed and the finish mower didn't have to get close. Plus it wasn't the smoothest terrain and trying to mow it full tilt with the smaller tires of the ZT just rattled you and the equipment to pieces.
