Quickie log-drag, (paper-thin MIG weld)
/ Quickie log-drag, (paper-thin MIG weld)
Haha Dan that sounds like a challenge! It should be arranged such that it's a long weld in shear. Welded from both sides (and wrapping the ends) it's pretty easy to make it stronger than the chain. A 3/8" plate with a 1 1/2" hole, and two slots ( like the planet Saturn ) would do it too.
Lots of ways to put that together, and I will certainly get a few of those setup. Thankful that Terry thought of mentioning it, I will definitely put some of these in my toyboxes.
Here's another simple unit ( called a "clevis claw") that you could pin to a link, and less likely to get lost.
What about just carrying a single grab hook and positively attach it to the chain where needed? Same idea as the clevis claw above, but a simple grab hook. Where you replace the cotter pin with a spring clip, or just bend the cotter such that it acts like a spring clip. Of course those small parts can be lost out in the woods.
Or if you want another 'link' can use an eye grab hook and this double clevis link
Lots of devices available, heres a bunch of them from Grainger
Or, pull the pins holding them together and hook the two clevises together. You will need to replace the pins with a grade8 bolt that is just long enough to have the "shoulder" for the whole clevis area.
One bolt thru all four clevis holes, thats a good way. Using a nyloc too. May have to grind the clevises a little but yep that's an easy way to do it. or Clevis hook and eye hook together - not sure if these actually fit but I will find out this morning at the store.
/ Quickie log-drag, (paper-thin MIG weld) #53
One bolt thru all four clevis holes, thats a good way. Using a nyloc too. May have to grind the clevises a little but yep that's an easy way to do it. or Clevis hook and eye hook together - not sure if these actually fit but I will find out this morning at the store. <img src="http://www.tractorbynet.com/forums/files/welding/422710-quickie-log-drag-paper-thin-h5-16_med-jpg"/> <img src="http://www.tractorbynet.com/forums/files/welding/422709-quickie-log-drag-paper-thin-eye-grab-hook-aisi-316-a"/>
I tried it that way originally and it will work,but for me, I found the flexibility with the few links in between made it a little more "user friendly".
(And I'm not a very friendly user:(. )
Terry
/ Quickie log-drag, (paper-thin MIG weld) #54
I like this idea best so far.
The "Sodo-saturn link".
I have some chains that the links don't give you enough room to attach anything except at the ends, so that cool clevis claw wouldn't work.
Agreed you want to be able to turn the 2nd grab hook any which way to engage. In cases where you want to pull up all the chain tension you need to be able to rotate it any which way. Terry your original is a good way!
I like that the saturn unit:D can slip in a back pocket, 'cept my wife will kill me when it goes thru the wash.
/ Quickie log-drag, (paper-thin MIG weld) #56
But the trouble with the Saturn plate is you have to take time to stuff all the excess chain thru it. I think the original may be the best and quickest.
/ Quickie log-drag, (paper-thin MIG weld) #57
You guys are needlessly over-complicating this -
bungee cords are nearly ALWAYS the right length
:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:
/ Quickie log-drag, (paper-thin MIG weld) #58
I thought everyone knew about chain shorteners. :)
I walked out the the tractor shed to take inventory.
The one on the right was factory made.
Bruce
PS: The third one may not qualify, but is good for hooking something besides a chain to a chain.
/ Quickie log-drag, (paper-thin MIG weld) #59
Bruce
Nope, but I do now!. I bought the stuff and made one today. I had to buy a foot of chain they would not sell any less.:eek: I made him cut me 3 links though.:)
Grab hooks (3/8" size $3.99 for 2) atHarbor Freight. With 1 foot of chain you can make a couple shorteners.
The 1/4"size $3.49/2 will "grab" 3/8 chain (pay attention to your loads!!) but the clevis only fits up to 5/16" chain.
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
2019 Ford Transit Connect XL Cargo Van (A59230)
2019 Ford Transit...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2017 FORD F-150XL CREW CAB TRUCK (A59823)
2017 FORD F-150XL...
