Ford NAA balance point
   / Ford NAA balance point #1
MarlinSlayer
Collierville, TN
Ford Jubilee!
I finally went up to the farm and got my non-running NAA up on the trailer with what turned out to be a defective winch. When I bought the tractor, the previous owner loaded it up on the trailer, and I can't remember where on the trailer it sat. I'm going to transport it tomorrow, and via eyeball, it looks like the centerpoint of weight, looks like it is near the front of the main tires. For now, I have the tractor lined up so that the leading edge of the rear tires is between the axles of the double axle trailer.
How do you load your tractor with reference to the centerpoint between the axles?
   / Ford NAA balance point #3
look at the trailer tounge when it's on the tow vehicle. you want some tounge weight.. but not enough to excessively squat the rear and make the front end aim high.
Thanks Guys! Got it home now. Now I can put some brakes on that trailer...still surprised anyone makes a double axle trailer without brakes....Mine did fine, and I took it slow...(Towing RV's even with brakes, makes you more aware to anticipate the momentum behind you).
That lineup worked like a champ. I'll take a picture and post it later
   / Ford NAA balance point #5
new tandem with no brakes on even 1 axle? wow.. where from ? mexico?
   / Ford NAA balance point #7
still.. was it rated at under 5000#? I didn't think anyone could make 5001# trailers sans brakes anymore?
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
