rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,462
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
I'm in the process of getting water hooked up to a couple of outbuildings and have a question about installing a check valve.
Here's the setup:
The source is our home water supply, and I believe we have a 1" line coming into the house from the well pump. That is plumbed into a pressure tank which is in the mechanical room in the basement. The line size drops to 3/4" (copper) off the manifold of the pressure tank, which then runs through a filter and into the water softener. 1/2" and 3/4" copper is used throughout the house for distribution.
The outbuildings were previously supplied directly off the pressure tank using 3/4" copper (unfiltered and unsoftened water) but I plan to install valves so that the water supply to the outbuildings can be switched to either softened or unsoftened water as needs dictate.
Ideally, I would have liked to plumb all the way through the filter (possible) and softener (not possible because the inlet and outlet appear to be 3/4") with 1" PVC pipe, so as to not introduce a restriction.
Current plan is to replace the 3/4 supply line inside the house for the outbuildings with 1" PVC to the point where it is about to exit the house through the foundation wall (which is poured, solid concrete) and then switch over to 1" copper.
The (outdoor) supply line to building "A" is 1" poly (100 psi I think) which is buried (at least) 48" and bedded in clean sand. Building "A" is lower than the basement of the house and I'd guess the change in elevation is on the order of 10' to 15'. Length of run (outside of house) is probably 130'.
The (outdoor) supply line to building "B" was put in by Dad. Don't really know all that much about it other than it is 3/4 poly. Probably is not bedded in sand ... but it was functional at one point (10 or so years ago) Don't really know what I'm dealing with on this one until I get it hooked back up and can test it. Building "B" is higher than the basement of the house and I'd guess the change in elevation is on the order of 10' to 20'. Length of run outside the house is probably 300' to 400'.
Plan is to sweat on 1" and 3/4" female pipe fittings onto the (short) piece of 1" copper that passes through the foundation wall and then use brass hose barbs with stainless steel, worm-drive band clamps to secure the poly lines to the buildings to the hose barbs. This "manifold" will be connected and then buried.
I picked up a 1" brass check valve from Tractor Supply to prevent any water from coming back inside the house once it leaves. The valve uses a spring-loaded plunger with a rubber seal to prevent backflow. It came with no instructions.
Since it came from the well section at TSC I'm guessing that it might have been meant to be used with a submersible pump that is placed down into a well.
In that case - in a vertical orientation - the weight of the water in the pipe above would aid (the spring, which is fairly light) in maintaining the seal and preventing any backflow.
My problem is this: I have no real good location to orient it vertically, where the weight of the water above the valve would act to keep it closed ... it's either a horizontal orientation ... or a vertical orientation where the weight of the water above would actually act to hold the valve open.
Been to manufacturer's website (watersourceusa.com) and don't see anything that pertains to the acceptable orientations of the valve.
I suppose the question is: Is installing the check valve in a horizontal orientation acceptable ?
Next question is: Where do I install it ? (inside or out ?)
Seems to me that inside, about 4' away from where the supply pipe to the outbuildings exits the house, would probably be best just in terms of possibly having to service and/or replace it in the future.
Thoughts ?
Here's the setup:
Thoughts ?
