MX5200 Engine Problem
/ MX5200 Engine Problem
Got home today and my MX5200 was back. All good !!! Just have to stop at the dealer to get Info on the update that was done.
/ MX5200 Engine Problem #103
That's good you finally have your tractor back. Can you post some pictures of the new parts?
It was a complete new motor long block, turbo, computor and exhaust system. And the new update to the venting system. I will have to check at the dealer to know what the update was.
/ MX5200 Engine Problem #105
Poor guy, now you have go thru the break-in all over. I don't remember how many hours you had on your tractor, if in fact you stated, but a new engine might almost be worth it?
/ MX5200 Engine Problem #106
When your problem happened did you see something similar to this? It's my M135GX in early January. They replaced the turbo and DPF but the engine was knocking like it had no oil pressure at all by the time I got it shut down when it started smoking, lost power, and warning lights began flashing.
/ MX5200 Engine Problem #107
Kubota needs to figure this stuff out fast.
Well I check at the dealer to see what the update kit was that Kubotacame up with . It is a small canaster filter that is plumbed into the block venting system. Kubota's update was to rap it in a aluminiun rapper to radiate heat from the motor after it is running. I WOULD SAY MINE WAS BLOCKED WHEN IT START IT, BECAUSE IT HAPPENED IN THE FIRST 5 MIN FROM STARTING IT !! Just my experience with my issue was that the venting canister was freezen solid and blocked the venting system and caused the block to build pressure and push the engine oil up into the intake. My thinking is that the update will maybe help after the engine is warm and running in the cold climate to melt the moisture in the canister. In my opinion let it vent before the canister like in the old school motors !!! Let it breathe and pollute so it will survive !!!!
/ MX5200 Engine Problem #109
Maybe their thought is that the heat under day to day operation will evaporate the moisture so it does not build up to the point it could freeze and block venting in the first place.
Maybe that is there theory . I hope it is a fix !!
/ MX5200 Engine Problem #111
MHarryE, that sure looks like the same problem we've been talking about. Did you check out the thread that sixdogs mentioned earlier? .... in message #101 I think it was? That thread is running with approximently the same symtoms and concerns as this one, but the machine is an M5100 - which almost certainly preceeds Tier IV.
rScotty
/ MX5200 Engine Problem #112
MHarryE, that sure looks like the same problem we've been talking about. Did you check out the thread that sixdogs mentioned earlier? .... in message #101 I think it was? That thread is running with approximently the same symtoms and concerns as this one, but the machine is an M5100 - which almost certainly preceeds Tier IV. rScotty
Yes, I've checked it out. Dealer showed the kit available for one tractor series - they had others for other models. The thing is that Kubota says they have not had any problems with tractors having the 6.1 liter engine like mine and no kit is available although they would help me fit up the closest size if I wanted to. Instead it is spring. Tractor is running fine. Kubota people I talked with were really nice and answered all my questions. If Kubota foes develop a kit in the future I will be looking for them to supply one for mine.
East Texas Gooseneck Trailer (A65563)
East Texas...
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
John Deere 302A 50HP Loader Utility Tractor (A61572)
John Deere 302A...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2019 BOBCAT E50 EXCAVATOR (A64279)
2019 BOBCAT E50...
BUSH HOG 2720 BATWING ROTARY MOWER (A64280)
BUSH HOG 2720...
