best zero turn $3000
/ best zero turn $3000 #2
Tagging along... I don't have that much to mow but I got tight spaces, all different slopes and obstacles. Eying the Kubota Z122 myself and the 42in is $3899 a bit more than your target and their 48in is $4500. Sounds like you need a bigger deck than I do. Good luck.
/ best zero turn $3000 #3
Best ZTR for $3k-$4k IMO is a used commercial grade unit. Scag, Exmark, Hustler, Bobcat, Bunton, Toro, etc. Many out there.
/ best zero turn $3000 #4
I wouldn't buy anything from the big box stores, they just aren't the same machines you find at the dealers, and when something goes wrong, they are no help.
I agree, if you can find a used commercial model that isn't worn out you will have a better machine to attack that much grass.
/ best zero turn $3000 #5
Someone needs to come get my Grasshopper 721-D (Kubota diesel powered) with 61" deck for $4,200.00 bucks..... It's low houred, ready to go, and works just fine...
THAT'S the best deal for a good mower I know of, or even heard of for any where near that money...
SR
/ best zero turn $3000 #6
SR
Wow... that does sound like a great deal. What year and how many hours (just curious)?
/ best zero turn $3000 #7
It has around 800 hours on it, I'd have to look and I've owned it about 8 or 9 years... I can't remember the exact year... :(
SR
/ best zero turn $3000 #9
SR, which transmission is in your 721D - the Gemini or the G2?
/ best zero turn $3000 #10
IMO a used commercial machine. Every $3000 new zero turn I have seen is junk. Diesel powered would be nice, but you won't find one for $3000.
/ best zero turn $3000 #11
3K is not enough $ for what you want to buy. You need at least 1.5K more for a good, long lasting, used mower.
/ best zero turn $3000 #13
I very much agree with LD1
I was facing same decision when needing to replace a motor on a ztr( was going to run ~2000.00)
I very much disagree with 4570man....I bought a used Kubota ZD21 diesel for $3500.00(jumped on the deal) with 700 hrs.
been a great mower over the last few yrs with no trouble...getting close to 1000 hrs and i expect this will be the last mower this 62 yr old will ever own.
note: my BIL bought a new JD residential grade and my nefew bought a new (cant rember the brand) ZTR when i got the Kubota.
Both of them are starting to have rouble with them now.
Again i agree With LD1 ...shop and buy good used comerical grade
/ best zero turn $3000 #14
I bought used F2560 diesel for $3500, but $3500 and $3700 is more then $3000. I have seen several diesel machines around $4000.
/ best zero turn $3000 #15
Hustler has recently introduced the Raptor - it's a lighter version of their commercial mowers, and $3k should get you one.
To the OP - you said slopes.... I have ridden a ZT down a few slopes - with no control.... just like a 2WD tractor... once the ZT breaks traction, you are just a passenger, and if there is water at the bottom, your a swimmer, if you can get the seat belt off.
For that reason I mow my 5 acres with a 6' finish mower, and have an old used commercial belt driven walk behind, with a velkie for all the close up work, and slope work - this thing cost me $800, and I am in my 4th year with it, with out any issues.
/ best zero turn $3000 #16
Have you looked at the Bad Boy mowers? I know nothing of them. Just seen a 60 inch cut yesterday for $4995 new. Good price point. While probably not commercial it makes a guy think.
I use a 60" Dixie Chopper. It's a commercial machine and has held up well. Mow about 6 acres with it.
For slopes and ZTR's put a set of bar lug tires on them. Really stops the sliding even on flat ground. Helps them handle mud better to. If by a wet ditch mow across it instead of down the sides. Assuming it's not too deep.
/ best zero turn $3000 #17
I agree, I put new bar lug tires on my Grasshopper 721-D and it made quite a bit of difference...
SR
/ best zero turn $3000 #18
Bar Lug tires - seem very aggressive, and several forums don't recommend them for keeping yards nice.
The forums are dedicated to lawn-care by lawn-care professionals, are stating that using the ZT to make a zero turn with the bar lug tires tears the grass up, and leaves marks even when performing gentle turns on damp, or wet grass.
here is a post from one of the guys on those forums:
I have bar tires on a Super Z.
I got them for mowing on slopes etc. They are shocking at digging up turf! Have to be so carefull when zero turning and turning on slopes inst much better than turf savers. They still slide but also dig up the turf.
Turning them backwards, while a little better with traction, was even worse when doing a zero turn.
Only get them as an absolute last resort.
What are your experiences?
/ best zero turn $3000 #19
I have actually been doing less damage with them. Even when making zero turns. The turf tires in spots would cause me to be sliding and reverse spinning the length of the mower or longer. I have places where I have to make zero turns and its slopes two directions. And not steep. The bar lugs just tear up the foot print of the tire in these places. Even on flat ground my mower wouldn't do a zero turn with turfs. More of a drift. But I try not to do zero turns because I try to keep the inside tire moving even if it's not much. This greatly reduces damage.
/ best zero turn $3000 #20
What is the zt mower for 4 acres with some slope? I have a JD LA145 and looking to speed up the Process.
Thanks.
A $3000 low end residential grade zero turn mower is not going to last long mowing 4 acres IMO.
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
