new to me 186d
/ new to me 186d #1
denm74
Member
Nova Scotia
Kubota B2620, G1700
picked up my first Yanmar tractor. It is a 186D and it needs almost everything done to it, :). First thing I started to fix was the 4wd engaging lever, got the assembly off and freed up the lever. While it is off I am obviously gonna change fluid, does anyone know what it is suppose to use and the filter number
/ new to me 186d #2
On pg.144 Parts Fredricks is showing a pic. of the strainer cover and O/Ring. IP-4300
/ new to me 186d #4
not sure of a filter number but its an american tractor Carquest or napa will list it in thier computer or you can go online for Wix and find thier filter number.
fluid needs to meet jd303 spec which pretty much any universal trator/hydraulic fluid will, which is what you want.
/ new to me 186d
tractor shows 813 hrs, guessing 1813 hours atleast before tach cable broke, located some filters for transmission and engine, I see some guys are using dextron 3 so I should have some of that on the shelf some where
/ new to me 186d #6
Here's the basic fluid & Specs.. With only 2.1 gal. Hyd. I believe the Pickup Screen or the Strainer needs to be checked and cleaned also. My ym2000 holds 4Gal.. When I was Serving it there wasn't any use trying to clean it. It was so bad I had to replace it.
Used Yanmar ym186
/ new to me 186d
got the strainer cleaned, it actually didn't look too bad. going to top up the fluid and give it a try tomorrow to make sure everything works ok
/ new to me 186d #8
yea you can use trans fluid. Its better for cold weather. quicker response and dont have a warm up time on it like hydraulic fluid.
/ new to me 186d #9
First thing I started to fix was the 4wd engaging lever, got the assembly off and freed up the lever. While it is off I am obviously gonna change fluid, does anyone know ... filter number
Welcome!
For that hydraulic filter and other stuff that really has to match Yanmar spec, I order from Hoye.
I have a question - my YM186D shift lever is stiff. What did you have to do to free up the lever?
You are going to love that tractor. When I finally found one with loader and power steering I bought my second YM186D.
/ new to me 186d
Welcome!
for my tractor I took the front half of the 4wd engagement housing off and cleaned the splined shaft and mine worked great after that. Fresh fluid change, engine oil change, set the valves and she works great now. Still have lots to do but now I can put it to work once the snow finally melts
/ new to me 186d #11
Congrats on the tractor......they are good little units. I've been running trans. fluid in mine for years.....works well. I would recommend changing out all of your fluids.......then you know what you got. Hoye is a great place for parts.....good folks. Have fun....enjoy.
/ new to me 186d
Getting lots of bugs worked out of the tractor and lots left to go. Wondering now about the tire size, it has 31x15.5 -15 on rear and 6 - 12 on front, you can definitely feel a little binding when in 4wd. checked front axle over and everything seems fine. Is this the right size tire combination for turfs?
/ new to me 186d #13
Page out of parts manual.
/ new to me 186d
seems the 6-12 front is right but doesn't give a rear tire size to match
/ new to me 186d
seen that one but it is for ag tires, believe I found it in another post it should have bigger front tires to go with the large rears
/ new to me 186d #17
Description:
18 hp.3 cylinder diesel 4wd. tractor,9x3 transmission with 60" mower deck drives off the rear pto,20.5x8-10 front,31x15.5-15 rear turf tires, front weight, 771 original hours
Turf Tires!
/ new to me 186d
Description:
Turf Tires!
thanks, that is what I was looking for :thumbsup:
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2013 Moritz Trailer (A63116)
2013 Moritz...
