Planting trees
/ Planting trees #1
bdog
Elite Member
Texas
John Deere 6130M
I am going to be planting some trees. Probably trees in the 15 gallon range.
We have no rocks here but our ground is hard. Really hard. A three point PHD will barely dig a hole it just spins and spins without down pressure.
Anyway I have a hydraulic loader / skid steer auger and in the past used that to plant trees and have done ok but I wonder about how well the roots penetrate that hard ground.
I now have a backhoe and I am wondering if it would be beneficial to dig a much larger hole maybe five foot in diameter and five foot deep and maybe mix some fertilizer / manure / etc with the dirt and then place the dirt back in the hole and plant the tree? Seems like it would really help the tree get established but I have never seen anyone do this before. I watched a professional landscaper plant some trees with a backhoe and they just dug the holes barely big enough for the tree. I don't know if it was because that is all that is necessary or if they were just trying to do it as fast as possible.
/ Planting trees #2
I have heard of a saying that you are better off planting a ¢50 tree in a $5 hole than the other way around.
/ Planting trees #3
do it the way you said, landscaper was in a hurry
/ Planting trees #4
A schoolmate of mine owns a large successful nursery and when I told him I was plating trees with a BH his concern was to not let the bucket "polish" the sides of the hole and to either use the teeth or a shovel to break up the sides.
The only thing I would suggest is don't go so deep (width is ok), just excavate slightly deeper than crown planting depth and you can amend that a little before you set the tree.
/ Planting trees #5
Everything I have read said it is better to dig a wider hole. Break up the large clumps of soil , but do not amend it.
/ Planting trees #6
I would dig a wide hole. Just don't dig a deep hole. The dirt needs to just cover the root ball.
/ Planting trees #7
I have dug a lot of holes with a backhoe for customers to plant trees. In hard clay soil dig it a min. of 12" deeper than necessary and put some loose soil back in to the right depth. Doing this and plenty of water and you'll have 100% success rate.
/ Planting trees #8
I agree with everyone above, wide, not deep. Most of the root system of a tree spreads out wide to give the tree a good base and cover as much ground as it can to suck in fresh rains and such. A tree that needs to shoot roots deep to find water won't do good over the long term and is easier for wind to bend to the point of breaking.
/ Planting trees
I know that as far as setting the depth of the tree. My concern was the hard compacted ground beneath the root ball inhibiting root growth. I was thinking of digging the hole much deeper then filling it with loose soil then planting the tree so the roots can get through easier.
/ Planting trees #10
We planted a bunch of pine trees using my front end loader to dig the holes. In our case I think it was a mistake. The large soft holes attracted pocket gophers which ate and undermined the tree roots.
Dave
/ Planting trees #11
Your hole should be wide, but not overly deep. You want to plant the tree so it sets a bit above the soil level. NOT below the soil level. Another thing is to take it out of the pot. CUT down the sides, make three or four cuts down. Splay open the roots and discard some of them. The tree is rootbound by sitting a in a pot. If you just take it out of the pot and plant it, the roots will not grow out as the way they should and will eventually strangle itself. When you have it planted, mulch the area, say a foot and half or two feet in each direction. So, figure on a four foot mulch pattern. You should mulch it with very well composted mulch material. Not Beauty bark, A very good mulch is well composted straw and manure mix, not fresh stuff. Another good mulch is composted wood chipper chips. Stuff that has been broken down and cooked for a year or two.
You don't want to mulch with fresh manure. Or fresh wood chips. If you are planting where livestock or deer will browse it or rub against it, take round pipe or fenceposts with the bottom chevron removed. But three or four of those in the ground and then wrap fence around it and secure the fence to the posts. The reason for removing the chevrons is that at some point you will want to remove the posts. With the chevrons you will do major root damage when removing the posts. Straight posts will be just fine
Water it in at first. Keep it watered but not wet all the time. The layer of mulch will help retain moisture and further decompose. Don't fertilize. First year is important for slow, natural growth. Keep the mulch two or three inches AWAY from the base of the tree so as not to crowd the base and the bark
/ Planting trees #12
I agree with most of what is said here, but with the ground being as hard as you say I would suggest that you do dig the hole a bit deep, then refill and pack it down with your body weight. This will give some loose soil for the young roots to go down....and you do want them going down and not just side to side so the tree is well established. One of the reasons I bought the BX25 was for the backhoe to plant apple trees. I currently have around 50 apple trees with more arriving this week....I will be in your same boat here this weekend it looks like....I am getting 75 more that I will need to plant.
/ Planting trees #13
Rarely mentioned, but worth considering. If there are similar types of trees in your area/on your property (exact species work the best) - take some soil from underneath an established tree (from around the roots works the best) and spread it around the root ball of the trees you are planting. This will ensure that the required micro fauna/symbiotic fungi, etc, that work with the tree's roots to pass nutrients along will be in the soil and will greatly aid the tree becoming established/grow well. Lots of studies to back this up/a tree's roots need symbiotic fauna in order to more effectively supply nutrients, etc, to the above ground structures.
/ Planting trees #15
Dig a big wide hole but no deeper and maybe even a couple inches shy of how deep the tree was in container/root ball. NEVER ever amend or add fertilizer to the hole. You'll just created a big cup to drown the tree roots in water once you get some. Trees do not need fertilizer. You can cause all sorts of extra tender growth that insects (or animals) will feast upon. The leaves from the tree in the fall will provide some natural fertilizer (by the worms coming in and working on the fallen leaves).
If you can, use lots of water during planting. Ideal would be to actually fill the hole with water before putting the tree roots and dirt back in. Get muddy.
Ralph
/ Planting trees #16
Where do you get your apple trees & what size are they? I have just been buying a few at a time to plant & would like to be able to buy in bulk.
/ Planting trees #17
I have had pretty good luck transplanting blue-spruce up to 10 feet tall with the front loader of my 43 hp, JD 4120 "CUT". It has the heavy-duty JD bucket. That bucket is strong enough to support forks or my custom "tree scoop", bolted directly to the bottom. My tree scoop is simply a piece of 12" wide x 3" deep x 36" long x 1/4" thk, heavy duty c-channel. I bolt that under the center of the bucket and it protrudes about 2 ft in front. It lets you dig narrower holes much like you can get with a back-hoe, using the front loader. I usually dig a hole a little larger than the expected size of the "root-ball" of the tree I am moving with the narrow c-channel scoop. Next, I drive up to an un-disturbed tree and stab the scoop under it, put a strap or chain around the back of the trunk, attached to the upper bucket hooks, and curl the bucket back to lift it out. Then I drive over to the hole, lower the tree in, then back-fill with a shovel. It don't take long to move a bunch of trees this way. I have moved hundreds that way over the last 5 years or so, and only ever lost one. I usually have the bush-hog on the back of the tractor for ballast when doing this, and my rears are calcium-filled. For me this works nearly as well or better than a tree-spade or backhoe, and didn't cost me a dime, as I had the c-channel laying in my scrap pile behind the barn. I have also used the scoop to transplant apple trees up to 5" caliper.
A few years ago, I had a long row of blue-spruce averaging about 8 ft tall, starting to crowd each other a bit so I put an add in craigslist to sell every other one for $50 "you dig" or $100 "I dig". A rich fella showed up with a big flat-bed trailer and I had that thing loaded with the tree-scoop in under an hour. That was some of the fastest cash I ever made, and all 15 or so of those trees are still doing real well after he planted them at his place with a rented backhoe. He was a happy customer and I was a happy seller, as it should be, and no back-breaking labor was involved in the deal.
One other little trick for apple trees, especially if you transplant them at the wrong time of year (any month without an "r" in it), is to bury some dead raccoons or fish around them. I had one I moved in late May looking a little poorly the next year and loosing lots of leaves, but it perked right up with 2 raccoons and about a dozen smallmouth bass that I treated it to that July.
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2013 Freightliner...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
