Man Lift ideas
   / Man Lift ideas
Around here, you can rent a manlift (towbehind 35' unit) for ~$160/day. Pull that behind the tractor with a ball on the 3 point hitch and you don't have to disconnect it to set the outriggers.
Aaron Z
The daily rate is the same here and I have rented one several times. My Sthil pole saw is not extendable and I find myself about 6-8 feet short of where I want to be with it. It is more about having something I can attach and use without making a 40 mile round trip to pick it up, then another one to return it. If I can find a used 275 gallon pallet tank, it looks like it would work well. I found one online for $199.00, but shipping was another $120.00.
   / Man Lift ideas #12
Aaron Z
I've heard complaints around here that they ask what and where you are using it, and won't rent it if not to be used on a paved, level surface.
Bruce
   / Man Lift ideas #13
Your local Craigslist probably has them for around $50 and up. Damaged tank ones are usually half that.
Search for
IBC
or
tote
or
275 gallon
Bruce
   / Man Lift ideas #14
No such questions around here. Now, they do have a sign up saying that there is a cleaning surcharge if you bring it back dirty.
Aaron Z
   / Man Lift ideas
Bruce
Good call Bruce, there are several listed locally for $50 and up. I'm calling them now.
   / Man Lift ideas #17
I picked up my two for $50/ea. at a flea market. Then my neighbor, who manages a sewer plant told me he has trouble getting rid of them!
   / Man Lift ideas #18
One of the farmers in my area converted one into a chemical tank to feed his big agg sprayer. He hauls it up front on the forks and has a hose run back to the smaller sprayer tank. He seems to cover a lot of ground with it, I'm sure there are other uses too.
   / Man Lift ideas #19
I'd be happy to come get a trailer full from him.
   / Man Lift ideas #20
My first attempt was taking a solid pallet, putting a plywood deck on it and some short side pieces. I had it secured to the forks
This was a couple years ago. Worked fine, but a little dicey
This winter I made a convertible single or double deck man lift plat form.
Completed with slots for the forks. Again, to use it, simple secure it to the forks assembly using chain and binder, poly ropes or straps
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2020 DRAGON ESP...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
2023 Kubota L6060HST Compact Utility Tractor (A56435)
2023 Kubota...
