Buying Advice First Tractor - Which way to go?
   / First Tractor - Which way to go? #11
You can definitely get all the tractor you need for under 15k. I'm not trying to push a make on you just using my example as my budget was under 15k. I just bought a 2010 Mahindra 4035 (40hp) 4WD with front end loader. 722hrs. It's a ton of tracor for the $$. $12,700. Found it on ebay. Looking is half the fun. Good luck.
   / First Tractor - Which way to go? #12
For 15k you might be able to get your hands on Yanmar SX3100 which is the same as the JD2720 but about 5k less. An EX3200 would work also. You can run 5' wide implements no problem. I use mine to upkeep a 1200' driveway. Mow 2 acres all summer long with the 60" Mid mount mower. Remove snow all winter long and i think you know how much snow we had the past few years. Small enough to fit in tight spots and has plenty of power. At first i was scared about using it to mow the lawn thinking it was to heavy but i have not had any issues yet. Just make sure you don't try sharp turns in 4wd on the lawn. Really wet spots may leave R4 imprints. I have had it for over 2 years now and am very pleased. I can't believe how little fuel it uses. I think your probably not to far from BIG Boy Toys which would be the Northeast Ct dealer. If you can find the Blk/Yellow C.C. Yanmars you can get alot of tractor for the money. They also came with a 5yr warranty. Now i am bias because that is what i own but that is also the reason why i can comment on them. I am sure many other brands are great but at the time i was shopping, i was looking for the biggest bang for my money. On a recent search on craigslist i believe i saw a low hour EX3200 for just around 13k. The EX3200 is next size up from SX3100. Have fun shopping and take your time there are deals to be had.:drink:
   / First Tractor - Which way to go? #13
You can absolutely buy a tractor that will meet many of your needs for less than $15,000. A used Kubota B series or small L series (or any other reputable brand) with a FEL can be had for $15,000 or less. Now, you're not going to lift 2,000 pound logs with the FEL on one of them, but you can drag good size logs out and cut them up into smaller chunks.
Compared to not having a tractor at all, you will think you've died and gone to heaven with a small tractor (even with the inherent limitations of a small tractor). And if you buy used, you can use it for a few years and trade up to something bigger without taking a beating.
IF you can get a decent bargain you WILL be able to lift 2,000 lb logs.
Pictured first is my Kubota M4700 w/ 2 rear remotes purchased for $11.5K plus tax etc. bought about the date on the picture. FEL is an LA 1001. Kubota used to rate their FEL's based on kilogram lift capacity, thus my M4700 is rated to lift a ton.
420439d1428709305-first-tractor-way-go-8x6sam_0798-jpg
/edit its 50HP
Pictured second is a great condition L4630 Barlow's was going to sell me for about $17K WITH shipping AND a engine oil and filter and hydraulic filters change.
420440d1428709507-first-tractor-way-go-photo-3-jpg
So the bargains are there.
Your first basic machine should be; diesel,3,000lbs,4WD,power steering,Front End Loader(FEL),independent PTO.
Lots out there in your price range.Check with all your local dealers(also check out the dealers themselves).
Look and see what brands are popular in your area.Plan on using a lawnmower for the grass.
Or heavier.
Also check out Messick's and Barlow's.
I am a nubie looking at whether it is time for a "first-time" tractor. I know very little about "farming" per se, but have been here and running our operation "tractorless" for 15 years, so I definitely have a good sense of the kind of things I need to do.
I live on a ~100 acres of hilly land in Northeastern CT. ~15 acres of the property are fields which (for the time being) are hayed by a farmer down the street. The rest is woods with a few crude path/roads running through it. We heat with wood, get a bunch of snow, want to garden on a "fairly grand" scale, and would like to move lots of heavy things like rocks, abandoned equipment left in the woods, etc. We currently use a walk-behind brushmower, and would love it if that could become a thing of the past - particularly if we could fight back the multiflora rose and autumn olive that encroach on the fields if not held in check. In the ideal world, we could also use it to mow the lawn, but I am concerned that a tractor that is "delicate" enough for the lawn is not going to fare well in the woods. On the flip side, a monsterous tractor will not do well in our woods. Its wet, rocky, and uneven.
To date we have used a beat-up farm truck to do most of these jobs. It's not pretty, but it has been OK and remarkably cheap. With the kids getting older, we have less time to mess with this. A little speed would go a long way to making things easier.
A problem is that I can't spend $20k-$30k on tractor right now. We'll probably have that kind of money to spend on a tractor someday, but it isn't now and not likely to be in the next 10 years. We have the house, and the kids, and other stuff. I could probably spend $10k-$20k, but would rather be <$15k. I don't know that that tractor exists. (I like to think I am somewhat realistic)
On the new/used argument, I am reasonably good at fixing things, but I don't need another "project." I have a house that is one of those.
Options that have been suggested to me are;
1. Buy a smaller new tractor, have the farmer do the heavy lifting for now, buy a bigger tractor later
2. Buy a bigger used tractor now.
3. Wait and buy a bigger new tractor when you have the money
4. Get an old 2WD tractor as an "intro machine"
5. Hire out the work to locals with machines of their own.
I would appreciate any insight people could offer on these approaches or maybe even one I have not listed. I would like to get started - more importantly my wife would like to get started, so I could benefit from making a decision on this soon.
Thanks,
Steve
Go with #2.
A good used tractor may still cost extra $$. I've had to replace about 4 hoses ($100?) and the front tires ($600).
LIVE on this board, Iron Planet, Tractor House, Craigs List, auctions and ebay until you KNOW the difference in value to you between a 40HP Jinma and a 40HP John Deere.
Get your price point nailed down and don't forget you WILL need attachments to take advantage of your tractor. A tractor is BASICALLY an engine, on wheels. It's when you add a FEL,a rotary cutter, a plow, a trailer, pallet forks etc. it becomes more useful.
Figure out your CRITICAL parameters. It seems price point is one.
Other examples are:
Dimensions - Do you HAVE to get in a narrow barn or have a bunch of narrow gates? I've a trailer that max dimension is 78" between the wheel wells, I had to run my tires to be narrower.
Lift capacity - many people HAVE to lift round bales. If your round bales usually weigh 1,500 lbs you'll want to match that. I had to be able to lift a ton to put it on my sawmill. I had planned on using the 3 point.
I highly recommend Public Service auctions for example at Public Surplus: Auction #1078910 was a 1990 Ford 2120 (40HP, 4WD, ~2,000 hrs) in pretty good condition which went for $8,400. These are tractors used by local governments and are often well maintained and underused for their age.
   / First Tractor - Which way to go? #14
My :2cents:
It sounds as if you have done a lot of research already and have a good idea of what your parameters are.
Plus this site will do a bang up job of giving quality advice and self correcting erroneous, (plus the occasional factionalism that will always happen when 2 or more individuals are involved).
Dead on that a tractor large enough to do your big lifting is too big for the lawn, and a tractor right for the lawn will be too small for the big lifting.
I am in complete agreement with Jeff9366 about 2WD on hills and the others about 4wd being a requirement.
Depending on the hills I would check into a ROPS with seatbelt.
One thread common to this site is if one can, especially financially, always go bigger.
As I mentioned, this site is a gold-mine, (Platinum? Sure, easily), with help. Use it. And if you encounter issues you will probably find the answer here.
Good luck in the search and you will love the "seat-time"!
   / First Tractor - Which way to go? #15
Other examples are:
Way better than my :2cents:
Probably a dollar's worth comparatively.
   / First Tractor - Which way to go? #16
Mason, i just sent you some info in a PM.
   / First Tractor - Which way to go? #17
There are not many 2-WD tractors sold new, so there are few available used. Absolutely useless on hills. Unsafe on hills as you only have braking on the rear wheels, when weight shifts forward as you go downhill you have close to ZERO braking.
You are not supposed to be going down steep hills forward, Its an Unsafe practice even with a 4 wheel drive machine. Going down in reverse is the sensible thing to do as it keeps the bulk of the weight on the rear tires.
   / First Tractor - Which way to go? #18
There are not many 2-WD tractors sold new, so there are few available used. Absolutely useless on hills. Unsafe on hills as you only have braking on the rear wheels, when weight shifts forward as you go downhill you have close to ZERO braking.<snip>
There are a lot of 2WD tractors available used. My local county just sold 6 of them. Five were 1989/90 JD 2155's with about 2,000 hours (being replaced simply because they were getting in new tractors)
attachment.php
They went for a little over $5K each.
When I search for tractors in Mississippi there are a lot of 2WD on Craigs list.
   / First Tractor - Which way to go? #19
I agree on a nice used 30-40hp, 4wd with loader. Try to get as close to 40hp as you can with your budget. Big enough to do some pretty serious work but can still use around your home without tearing your yard apart. I have found dealer support is just as important as the brand. I would check with locals that own tractors on who they use and recommend. I have a great local Deere dealer. Nothing is ever a problem with them. I have a 3320 (33hp), 3720 (44hp) deere and L2350 (25hp) Kubota. All are 4wd with loaders. I am amazed at what each will do. I have a belly mower on the 3720. I use a lawnmower around the house and 3720 to mow a large flat part of my yard, planting trees, moving edger bricks, etc. I keep the 3320 & L2350 at a farm and use it for a little of everything. The Deeres are identical and Kubota is about same size. You can tell the hp difference between them. That is why I would try to find one with the higher hp if you find a model/series you like. I expect you can find something you will really enjoy within your price range if you look around a bit. Happy hunting!!
   / First Tractor - Which way to go? #20
Sounds like you have more tractors than you know what to do with. Why so many so close in size?
2002 TRAVIS BODY & TRAILER, INC. 48 END DUMP TRAILER (A58214)
2002 TRAVIS BODY &...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
