ETA Subsoiler
/ ETA Subsoiler #61
That thing is seriously messed up. It doesn't look like it has a shear pin? I don't know how heavy mine is yet because I haven't used it but hopefully I'll shear a bolt off before doing damage like that. It has just two bolts in the upright 4X1 and hinges on the top bolt, shearing the bottom one off if something is too solid in the ground. At least that's the idea.
/ ETA Subsoiler #62
Dose anybody make a top link that is spring loaded so that a middle buster or even a bottom plow would become at least a partial trip implement? It might work faster then draft control and save a lot of damaged parts on both tractor and tool.
Yes.
It is a Hydraulink.
It would be helpful but not a panacea in this situation.
/ ETA Subsoiler
It does, but from the looks of it, how it must have hit that rock, it appears it transferred all my forward motion into a sideways twisting action on that beam putting the pressures on the lift frame rather than the shear bolt. From my understanding the shear bolt they supplied is a grade 2.
/ ETA Subsoiler #64
I'm wondering how long my unit is going to last after seeing yours. Your tractor is more than twice as big as mine though, maybe that will help me out.
/ ETA Subsoiler
I honestly think you have no worries. My tractor far exceeds the normal weight of the "compact" class of tractors and is well into the weight range of full sized utility tractors. Someone smarter than me told me:
3/4th inch a36 steel has a yield strength of no less than 250 million pascals... yield strength is the amount of force it can take in bending and snap back to its original shape... you at minimum exceeded 250 million pascals... 250 MPa to ft lbs is 5,221,358 lbs/ft^2 or 36,259 psi
Not really sure how to equate all that into my real world experiences, but it indicates to me that I had an unbelievable amount of tractive force going on and likely is not the normal operating environment. I figured with others being used on up to 60HP tractors, I'd be fine with only 40. Horsepower is only part of the equation. You can actually buy tractors with 60HP that weigh less than mine. While they have more power, they can't plant it on the ground as well as I do...
/ ETA Subsoiler #66
Hi Sysop,
Amen to that- I just caught up on your thread and even though I was already amazed at what you had done to that big piece of metal, reading the force numbers involved rocked me back on my heels even more!
Amazing....
I have to echo others' thoughts and/or questions about why the shear pin/bolt didn't give way before that huge piece'o steel bent...
Thanks for sharing your trials and tribulations as well as your customer service experience with us all.
Thomas.
PS: BTW, the HP listings on those other Sub Soilers read as MINIMUMs
/ ETA Subsoiler #67
Yes.
It is a Hydraulink.
Darn! Somebody always beats me to it! At $230 plus shipping for a cat 2 they ain't cheap.
I still like the spring surrounding sliding box tube over inch square bar design I was doodling with last night. Hadn't got through limit stops and adjust ability but I had some ideas.
Back to the drawing board.:grumpy:
/ ETA Subsoiler
I think I came in along side the rock in question and most of the forces were pushing the subsoiler to the side putting all the stress sideways against the lift frame rather than pushing back against the shear bolt. I wouldn't be surprised if when I take it apart I find the shear bolt damaged also.
I'll know more this fall if I have time to uncover it with the backhoe. I'll include pictures here whenever I do...
/ ETA Subsoiler #69
"Backhoe"?
Bend that plate back straight and dig it out with the subsoiler. Karma should be a witch!
/ ETA Subsoiler
That is what I originally thought you said you bent.
that is the main 3/4"x6" x48" ripper.
I wonder if ETA deviated from the original old design.
they told me their main 48" ripper shank is A36.
Just got off the phone with Travis at EverythingAttachments setting up the shipment of a replacement beam, he told me that in talking to Ted he was pretty sure Ted said it is actually A516.
I talked to my really smart friend and he said A516 has a slight yield advantage over A36 (5.4M versus 5.2M lbs/ft at .75") but that it's main benefit is a touch of Manganese for better corrosion resistance.
/ ETA Subsoiler
New part arrived yesterday from ETA (thanks guys!) and I took the old one apart, the shearbolt wouldn't come out. Once I got it out, it had sheared about half way before the side pressures became so great it created the bend. Soon as I locate another grade 2 I'm back in business.
832642 (A61166)
832642 (A61166)
2012 Peerless CH-43-2A T/A Frac Blender Trailer (A60352)
2012 Peerless...
2014 HEIL CRUDE TRAILER (A60736)
2014 HEIL CRUDE...
832641 (A61166)
832641 (A61166)
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
207272 (A52708)
207272 (A52708)
