New XR4046HC!! Finally got one!!!
   / New XR4046HC!! Finally got one!!! #11
Is the backhoe built by LS?
Did you get a hydraulic thumb on it?
Would like to see a picture of the BH ...please.
Man, That is a nice machine!!
Yes, the backhoe is built by LS.
I did not get the hydraulic thumb.
Here's a couple of pictures of the backhoe.
   / New XR4046HC!! Finally got one!!! #13
Thanks...
Saaaweeet! Even the dog and cat are admiring it.
   / New XR4046HC!! Finally got one!!! #14
That's the tractor I was gonna buy but I found a good deal on the used Kubota I bought. Great looking photos! LS should give you a discount for the use of those photos!
If you break any Tie Rod Brackets, have your dealer service tech call mine at Haney Equipment (256) 323-5850... I went through (4) of them before they realized that the factory didn't install stop bolts on LH side.
Thanks Matt P
   / New XR4046HC!! Finally got one!!! #16
Nice looking tractor and property.
Also, I believe that the loader and BH are both built by Amerequip.
Enjoy the new rig!
   / New XR4046HC!! Finally got one!!! #17
LOL! It didn't take you long to lose your SMV sign. I have the same issue with my XR3032H with backhoe. It didn't take me long to lose my SMV sign on my backhoe. In fact, I'm still looking for it.
There is another SMV bracket on my tractor just behind the backhoe seat. There may be one on your tractor too so you can at least move the sign for a while to keep up with it. I found mine a bit too late.
   / New XR4046HC!! Finally got one!!! #18
Hi Matt P, I broke my second left tie rod bracket on my xr4046. Mine has stop bolts on the left side but not the right side. Did they drill and tap and put bolts in for the right side steering? It would make sense to me to have the stops on both sides. Having stops on only one side would put twice the pressure on the tie rods. Thanks for your help, John
   / New XR4046HC!! Finally got one!!! #19
hey Matt P I see you are close to me I live in Athens. I couldnt get haney right on price so I had to goto Columbia Lynch tractor to buy mine. Its nice to hear haney does good with service. I will try to take mine there if needed.
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
John Deere 6125R (A60462)
John Deere 6125R...
2014 Ford Fusion SE Sedan (A59231)
2014 Ford Fusion...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
