Oil & Fuel Stuck Hydraulic filter
/ Stuck Hydraulic filter #1
indianaEPH
South Central Indiana
Kubota M59
I've been very busy building the new house. The M59 has been a huge help in so many ways.
I hit 400 hours and went to change the hydraulic fluid. All went well, except, I cant get the hydraulic filter off. I've tried varous wrenches but no luck. :confused:I even stripped off one of the lugs on the filter.
Anyone have any suggestions, Please??
Thanks
/ Stuck Hydraulic filter #2
If it is easily accessible you can use a method I have used on a stuck filter.
I drove a large screw driver though the filter body and twisted it free.
May be able to get a pipe wrench on it also.
Worst case would be to cut or tear the body off and use a pipe extractor.
/ Stuck Hydraulic filter #3
A trick I have used on stuck automotive oil filters is to placing a large screw driver up against the filter can at the edge of the flange and whacking the screw driver with a hammer. Angle screw driver so that when you hit it rotates the filter in the direction to unscrew it. Be careful not to hit the flange on the tractor side. You may puncture the filter doing this so you should have the oil drained. Note placement of the screw driver blade in the attached picture where the filter has some strength. Start at a steep angle in lightly tap to get the screw driver to bit into the filter and then go to a shallower angle and give it a hard whack. The screw driver in the picture is 24" long with a 9/16" wide blade. You could use a chisel, but you would want to square of the cutting edge.
/ Stuck Hydraulic filter #4
I remember that Paul Short did a video about a major service on his big Kubota, and spent some time talking about hard-to-remove HST filters, and how to deal with them. Check that video- Youtube under Paul Short, or maybe 4shorts? Okay- I found it for anybody interested. https://www.youtube.com/watch?v=YQeNpsRmFJE
/ Stuck Hydraulic filter #5
I had the exact same problem on an L48.
I used a chain-style pipe wrench and attached a Come-A-Long to the handle and to a place on the rear of the tractor. A few strokes of the Come-A-Long and the filter became loose. Wrap the chain as near to the attachment base as possible. The screwdriver method doesn't give quite enough torque and may just rip out the filter body.
Here is an example of a chain-wrench from Home Depot:
https://www.ridgid.com/us/en/chain-wrenches
/ Stuck Hydraulic filter #6
Ah the wonders of the painted on filter that torqued by a gorilla when built. At least the next time should be easier!
/ Stuck Hydraulic filter #7
That usually happens because the filter was installed dry (and maybe by the factory gorilla with super human strength). Make sure you coat the gasket on the new filter with fresh oil before installing. I have also used the screwdriver through the filter method.
/ Stuck Hydraulic filter #8
I have a large pair of channel locks just for getting stuck filters loose.
/ Stuck Hydraulic filter #9
That gorilla, or his pappy, has been doing the filters on the Kubota assembly line for a long time now. I used GWDixon's come-along technique more than 10 years ago when the 4610 got its first filter swap. I think it's some kind of rite of passage to verify whether one is manly enough to be servicing a Kubota.
/ Stuck Hydraulic filter #10
+1! :thumbsup: Some filters will be pinched nearly flat, ruptured, leaking, by the time they budge, but batting 1.000 for over 35 yrs in my shop(s). Pipe wrench can mean a lot of fiddling/re-adjusting as the tightest ones crush down, and jaws aren't as deep for o'all tool length/weight. Screwdriver method is as reliable, but often messier and/or requiring better access. (angle C-locks in as room permits)
'Arther' still lets me tighten a new filter just enough with a two-handed grip and hands a bit oily. (How'd that get all over me?) Have yet to see one loosen between changes, and only slight dimpling of 'can' when removing any I installed. Be sure the old rubber ring comes off with the filter. (Y'all knew about that.:)) Assembly with two is basis for some hairy start-up stories, like refilling twice, damming/squeegy-ing up an oil lake, teaching G-kids new words ...
/ Stuck Hydraulic filter #11
That Kubota gorilla has a twin working at the Kioti factory. :laughing: The Kioti hydraulic and HST filters are notoriously hard to free up the first time. I use a Vise-grip style chain wrench and a lot of tugging, but a pipe-wrench style chain wrench would be even better as it would give more leverage. I don't recommend driving a screwdriver through the filters. It may or may not work, depending on how stuck the filter is and how strong and long the screwdriver, but either way you'll have to contend with the escaping oil. JMO.
/ Stuck Hydraulic filter #13
Varmint - I think that's what they use at the factory to install them - with a cheater pipe.
I've had good results using these:
As long as any oil is removed from the rubber straps & the surface of the filter, they work very, very well.
/ Stuck Hydraulic filter #14
I tried every specialty tool available with no joy, then found a thread where they recommended taking a razor knife (razor blade) and slicing between the edge of the gasket and the mounting bracket. Next I sprayed the cut edge with WD-40 and let it soak, then scored and sprayed again. Finally it let go ......
/ Stuck Hydraulic filter #15
That method won't work on mine. Some filters are recessed in so you can't get to the gasket. On others like the engine filter you can't get in to the gasket due to other engine parts in the way.
I've used large channel lock pliers, vise grip chain wrench, strap wrench, large pipe wrench, end cap wrench, and a regular filter wrench. If none of them work the large screwdriver (which will make a mess) is my last resort.
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
