Advise on broken CX300
   / Advise on broken CX300
On the way to work, I dropped the mount off with my salesman with which I have a pleasant acquaintance at the local JD store. He's going to work with service to see if JD will cover the cost of the part and acknowledged the obvious - no penetration on the welds...defective part.
New part in hand though I still haven't heard if JD will step up on this.
   / Advise on broken CX300 #14
Regardless, you will need the new part as the old one doesn't look serviceable.
I think JD will step up, :thumbsup:
   / Advise on broken CX300 #15
I do too...and I hope they put out a service bulletin as well as determine the root cause. If this was robotically welded...or even manually welded, there could be quite a few of those components in service.
Installation was a snap. Since is the only time I've removed the FEL I went ahead and set the lock assembly tight to the mast per the manual. It was delivered with about 3/4" of gap. It ran so much quieter without the slop. Five hours of seat time with no problems.
   / Advise on broken CX300 #17
Did Deer ever man up and refund you for at LEAST the part?
I went by this week to talk to the shop boss. He indicated that they'd yet to get back but would likely offer half the cost. I'll post the final result. I love my tractor but am not impressed with John Deere of late but then I think the experience is not unusual of late.
   / Advise on broken CX300 #19
+1 to this -- there is zero penetration of those welds. How old is your loader? If it's not ancient, then I would definitely let JD know about this. There's no way that weld is up to ANY manufacturers spec.
I agree. Bad weld.
(UNUSED) WESTERNDORF 4200 BRUSH CRUSHER GRAPPLE (A52708)
(UNUSED)...
2020 DRAGON ESP...
1779 (A58375)
1779 (A58375)
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
