Advise on broken CX300
/ Advise on broken CX300 #1
Dan Hunter
Enid, OK
2012 John Deere 3720 eHydro
I'm pretty sure I broke my FEL this weekend. Specifically, I believe the weld that holds the end plate on the left mounting frame has failed. I noticed some unusual movement on the mast and upon inspection found I could put a finger INSIDE the mounting frame.
I've never had the unit off but it seems simple as described in the manual. Once the FEL is off, I'm assuming the end plate will still be in the mast. I'm thinking I can remove the mounting frame and have the end plate welded back on.
Anyone see a problem with this approach?
MIJI
/ Advise on broken CX300 #2
Not following your description. Maybe pics will help.
If welds are broken, then it would be apparent (IMO).
The video won't download but I can feel a sharp edge that I believe is the failed weld and again I can reach into the tube of the mounting frame which would indicate that AT LEAST the weld of the endplate failed.
/ Advise on broken CX300 #4
Put the video on youtube and link to the youtube url. Or just take pics.... thinking we can find some good help here to answer your questions and help you come to a good solution.
End plate missing so I'll be installing a new mount next week. Mast seems fine.
/ Advise on broken CX300 #6
Thanks for the pics. I get the "picture" now. Good to get a new mount.
Puzzled that it broke, but maybe you know what caused that to happen. Something more than regular use, I suspect.
But if not an event that you think could have caused it, I'd double check that the right and left side mounts were dealer-installed correctly. There is, I believe, a difference and IIRC that difference can be subtle enough that the binding that results may be passed off as normal.
See if the new part comes with the installation instructions and double check that the original install was done correctly.
My limited experience with welding read is that the welds weren't hot enough and didn't get good penetration. On the other hand, it has most of its hours with a grapple up front and, yeah it works for a living.
Oh, and the mounts are correctly installed.
/ Advise on broken CX300 #8
Those welds are defective. No ifs, and, or buts about it. There is zero penetration to the tube.
You might have some luck with JD on those.
/ Advise on broken CX300 #9
+1 to this -- there is zero penetration of those welds. How old is your loader? If it's not ancient, then I would definitely let JD know about this. There's no way that weld is up to ANY manufacturers spec.
/ Advise on broken CX300 #10
They appear to be very cold welds...especially in the end view (3rd) picture...no penetration in the end cap. Definitely a factory defect and I hope you take this to Deere. All repair costs should be borne by Deere.
On the way to work, I dropped the mount off with my salesman with which I have a pleasant acquaintance at the local JD store. He's going to work with service to see if JD will cover the cost of the part and acknowledged the obvious - no penetration on the welds...defective part.
New part in hand though I still haven't heard if JD will step up on this.
/ Advise on broken CX300 #14
Regardless, you will need the new part as the old one doesn't look serviceable.
I think JD will step up, :thumbsup:
/ Advise on broken CX300 #15
I do too...and I hope they put out a service bulletin as well as determine the root cause. If this was robotically welded...or even manually welded, there could be quite a few of those components in service.
Installation was a snap. Since is the only time I've removed the FEL I went ahead and set the lock assembly tight to the mast per the manual. It was delivered with about 3/4" of gap. It ran so much quieter without the slop. Five hours of seat time with no problems.
/ Advise on broken CX300 #17
Did Deer ever man up and refund you for at LEAST the part?
I went by this week to talk to the shop boss. He indicated that they'd yet to get back but would likely offer half the cost. I'll post the final result. I love my tractor but am not impressed with John Deere of late but then I think the experience is not unusual of late.
