food plot and soil improvement.
/ food plot and soil improvement.
Lets start with pictures of the ground you choose to work on from both the east and west. The before pictures.
I'll post mine as soon as the snow is gone.
/ food plot and soil improvement. #13
Oh no you are not.!! Over most of my land you can take a straight crow bar and apply a half dozen strokes into the same hole and reach bedrock.
I can beat that. :D In some parts of my field, you can sweep the dust off and be standing on ledge.
Eddie is right, it takes time for lime to leach into the soil and do its thing. With too acidic soil, the fertilizer goes to waste because the roots cannot take it up as well. I've found that just spreading lime and no fertilizer will green up the grass around my apple trees.
I think I have two options. Buy a 3pt pto driven spreader and put pelletized lime in it, or maybe buy bulk powdered lime from the Farmer's Union store and shovel. The spreader would be less work, but pelletized bagged lime is more expensive. But, I can use the spreader for seeding and fertilizer too.
These come in different bin capacities.
Fertilizer Spreader, Fertilizer Spreaders, Seed Spreader | Agri Supply, 34140
/ food plot and soil improvement. #14
I have some pics.
This is a nasty area.
The foreground wasn't cleaned up yet, where I'm standing is very ledgey. Back against the trees to the right is pretty much cleaned up. That is one of the better stretches of ground in the field.
You really need to contact your Ag Extension and get some soil sample sacks and send them in for analysis. In my area, the soil tends to be acidic and require anywhere from half a ton of lime per acre, to 2 tons per acre. You will put on the form what you plan to grow, and they will tell you what to mix of fertilizer to use and how much.
In my case, it takes several months for the results to show. I amend my soil this time of the year to get a good food plot in the fall.
You must realize that there is about two planets difference between Texas and Vermont. But the Gobments the same and we have taken advantage of any real service they have offered over the years,
/ food plot and soil improvement. #16
Look into Biochar if the plan is long term. Results tend not to be in the first season or two but then seem to much better and longer lasting according to current research. As usual more fibre and humus in the soil encourages microbes and worms, which in turn aids the roots to take up the nutrients. Your green manure idea makes a lot of sense provided you chop it before it seeds. Something like comfry is long lasting as a green manure and goes deep to retrieve nutrients, maybe a strip at the side and spread the foliage once cut.
/ food plot and soil improvement. #17
The key to soil health is what lives in it, the organisms and micro-organisms. The key to keeping the organisms healthy and happy is minimal to no tillage/plowing. Check the QDMA forums and search for threads by user "crimson n camo" titled "Testing in Progress".
/ food plot and soil improvement. #18
How deep is your topsoil? If it's 8" or less, I'd use an offset disc (two axles in a V-configuration) instead of a moldboard plow for primary tillage and a tandem disc (4 axles in an X-configuration) with a drag harrow attached for secondary tillage. Apply the fertilizer before doing the secondary tillage. You can find used pull-type discs at reasonable prices.
Get your soil tested before paying big bucks for fertilizers. Remove the guesswork.
Good luck.
We have a soil test kit around here somewhere but without even testing it I know it will call for more lime then I am willing to pay for this year. the point of the green manure crop is to reduce or eliminate the need of commercial fertilizer. I will test it to know where I'm starting at and again later to check progress.
Times like this I miss that manure pile out behind the barn. But at the time I didn't appreciate it much as I was building it one shovel full at a time.
That is the debate point. To till or Not to till that is the question. :rolleyes: The notill organic farmers use a lot of hand labor and the commercial no till farmers use a lot of chemicals. Some are now using cover crops with less chemicals with good results. I don't see rolling in a green manure crop as harmful tillage but purist would disagree.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
HEAVYEQUIPMENT TIRES (A60736)
HEAVYEQUIPMENT...
SCAN TO RECEIVE TEXT UPDATES (A62129)
SCAN TO RECEIVE...
