Fluid or Weights???
/ Fluid or Weights??? #41
That surprises me. I thought O'Reilly's was a national auto parts store chain. :confused3:
None around here.
I had to go to the 50 mile search to find the 1 closest O'Reilly's store
/ Fluid or Weights??? #42
Used to be Kragen around here, but a couple of years ago they got bought out by O'Reilly's, an outfit out of Springfield, MO. Interesting note, my grandfather knew the boys that started it back in the 20's.
There's an interesting story right there!!! :)
/ Fluid or Weights??? #43
None around here.
Sounds like they haven't grown East very far.
/ Fluid or Weights??? #46
Did a search for their store locator. All the west and mid west are covered but Maryland and east of there is blank until you get to new Hampshire and Massachusetts . Why the gap from New Jersey to Vermont is anybody's guess.
Store Locator | O'Reilly Auto Parts
/ Fluid or Weights??? #47
In an ideal world . Wheel mounted cast iron weights would be the choice.
Have to disagree with you there. On a JD 5045E you can only put two 95Lb weights on per wheel for a total of 380 on the rear and part of that weigh is above the center of gravity all the time. Plus the weighs make a place for dirt salt and moisture to hide in allowing your rims to rust prematurely. The same tractor with 13.6X28 R1s holds 920 lbs of'Rimguard'/ beet juice and the c.o.g. of that load is all below the COG of the tractor. Just My :2cents:
/ Fluid or Weights??? #48
I have both and I plug tires.
/ Fluid or Weights??? #49
Sorry, but actually, fluid would be the choice. Adds weight numbers that can't be matched by cast iron weights, puts the COG lower, and is much, much cheaper.
/ Fluid or Weights??? #51
Problem is it's not an ideal world.
Center of gravity is a non issue . The center of gravity is changed more by the amount of fuel in the tank. And if the driver is skinny or a fat &$$. The sloshing of liquid ballast is more liable to flip the tractor.I'm not buying the story that only two weights 95lb per rear wheel fits. A set of dry tires with 920lbs of cast ballast will pull more and ride better than the same tires with 920bs of liquid weight.
/ Fluid or Weights??? #52
Center of gravity is a non issue . The center of gravity is changed more by the amount of fuel in the tank. And if the driver is skinny or a fat &$$. The sloshing of liquid ballast is more liable to flip the tractor.I'm not buying the story that only two weights 95lb per rear wheel fits. A set of dry tires with 920lbs of cast ballast will pull more and ride better than the same tires with 92bs of liquid weight.
Hey I don't know for sure as I was just going by JDs build your own site where they have wheel weights and front suitcase weights as an option and there it says two max per side. Who you gonna believe?
/ Fluid or Weights??? #53
On my tractor my 250 lbs in the seat doesn't amount to much nor does the 100 lbs or so of fuel usually in the tank. On the other hand those four inch spacers ain't made out of goose feathers and the ice chains on the tires and the log chains wrapped around the 3PH probably go better then 300 total. Now if I'm on my neighbors L2800 that only weighs 2400 and does not have loaded tires my 250 can put the tire back down after she with insufficient mass to her A@@ has tipped it up with one rear in the air. :laughing:
/ Fluid or Weights??? #54
Just a quick note. Amazon sells both the plug kit and glue stuff. Just ordered then at 37 usd.
/ Fluid or Weights??? #56
b&d
Sloshing of liquid ballast will flip a tractor?????????? Glen your so FUNNY.:D
You should read in operators manual that manufacturer recommends adding liquid ballast
/ Fluid or Weights??? #57
b&d
Point is sloshing is as much of a COG factor as liquid vs cast ballast, zilch.
/ Fluid or Weights??? #58
At 11 pounds per gallon beet juice is probably as thick as maple syrup and not very prone to sloshing.
Sloshing liquid is an issue with tanker trucks. That's why they put baffles in them. There's isn't enough room in a tractor tire or enough speed for the liquid to gain any momentum to have much change in the COG.
/ Fluid or Weights??? #60
Exactly. Maybe a few ounces splash up over the rim, but the majority of it is going to stay down. And assuming it is properly filled to 75%, the vast majority of it is at or below the axle line, so it has lowered the overall COG of the tractor considerably. Width of the track and COG is of the utmost importance to stability on a hill.
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
John Deere Front & Rear Rims (A64119)
John Deere Front &...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
