Fluid or Weights???
/ Fluid or Weights??? #61
I can tell you with Rim guard beet juice when you start out at a highway gear it takes about a couple of revolutions for the centrifugal force to spread the liquid evenly around the perimeter of the tire. so you get a couple of whoop whoops and then it evens right out.
/ Fluid or Weights??? #62
That scenario sounds as if fluid is not filled to the recommended 75% fill.
/ Fluid or Weights??? #63
Point is sloshing is as much of a COG factor as liquid vs cast ballast, zilch.
I'm sure glad you're employed at a NUCLEAR PLANT in Canada and not in Texas if you actually believe that BS.
/ Fluid or Weights??? #64
Nahh it is just viscous enough to cling to the sidewalls and get dragged up and to the top before falling back down. Once you get up to speed the force pushes the fluid out to the outside of the tire, leaving the 25% void centered around the axle.
/ Fluid or Weights??? #65
Problem is it's not an ideal world.
Center of gravity is a non issue . The center of gravity is changed more by the amount of fuel in the tank. And if the driver is skinny or a fat &$$. The sloshing of liquid ballast is more liable to flip the tractor.I'm not buying the story that only two weights 95lb per rear wheel fits. A set of dry tires with 920lbs of cast ballast will pull more and ride better than the same tires with 92bs of liquid weight.
Your paragraph is simply inaccurate. To think fuel in the tank will have a larger impact on COG than tire weight is kinda na?e. And to think the driver has a greater impact than a weighted tire is even more na?e. Sloshing liguid ballast would not have a measurable effect in flipping a tractor until it already starts the roll, then of course, it's significance is irrelevant. Lastly, how did you decide that equal liquid ballast/cast weights would result in a better pull for the cast weight tire??
The cost difference alone outweighs (sorry) any advantage cast weights may have. So, I added 1500lbs to my tractor for around $200 using fluid. 1500lb of cast weights would have cost me in the neighborhood of $1500 at my Kubota dealer. :confused3:
Cast weight=$1.00 p/lb. Fluid weight=.13 cents p/lb.
/ Fluid or Weights??? #66
Exactly. Maybe a few ounces splash up over the rim, but the majority of it is going to stay down. And assuming it is properly filled to 75%, the vast majority of it is at or below the axle line, so it has lowered the overall COG of the tractor considerably. Width of the track and COG is of the utmost importance to stability on a hill.
This point right here is generally overlooked in these discussions.
Cast weight always, always has 50% of it's weight above the axle center line. Fluid weight never does. The percentage below the axle line varies depending on how full the tire/wheel is. Less full, more weight below axle center line. If flipping is your concern use fluid with your tires half full.
/ Fluid or Weights??? #67
Funny story about this phenomenon. In my kid years we had small Fords with fluid filled tires. When roading my brother and I always coasted down the hills. You learned real quick how fast that tractor could coast before the fluid would start "riding over the hump". You go past that speed and that little tractor would literally jump clear off the ground. You'll only do that ONCE. :)
/ Fluid or Weights??? #68
All good points, but I keep going back to the initial concern about tire repairs. My brother and I have experience with all forms of ballast and have plugged endless numbers of tires, my brother began his professional career as a tractor mechanic at the age of seventeen. When we began clearing our farm, we had to put tire sealant in everything that went in our woods or we were plugging thorns several times a day. For our uses, fluid in the tires simply did not work.
We now have about nine tractors and a backhoe and use combinations of fluid, nothing, cast centers, weights and combinations. We no longer have the thorns, but if we did, we would go back to what worked for us best initially which was not fluid filled tires and sealant, great now, but not so much otherwise. I can't think of anything more unstable on a slope than a flat.
/ Fluid or Weights??? #70
So I missed a zero while thumbing the message on my phone............ The fact is that if all other parameters are identical. A dry tire with 500lbs of cast weight will pull more than the same tire with liquid ballast.
/ Fluid or Weights??? #71
How much does the fuel and driver weight? How much higher is the fuel and driver than the tires? There will be more effect on center of gravity on a small to medium sized tractor with the fuel load and driver's weight. Than if the tires are dry with cast or the tires are liquid ballasted to the same weight.
/ Fluid or Weights??? #72
I don't have a beef with any of that as long as you keep those wicked thorns down in Missouri where they belong. The rest of us who don't compact landfills or drive over hot coals on a daily basis or over cactus patches do all right with fluid filed tires.
May you never have another flat!
/ Fluid or Weights??? #73
The cast weights are always worth $1500, the liquid ballast is a liability. Servicing a tire leak on a dry tire is much simpler and cheaper than a wet tire. CaCl ballasted tires will eventually corrode the rim .
/ Fluid or Weights??? #74
Deere , Titan and Firestone all claim that liquid ballast stiffens tractor tires. What has more more traction, a stiff or flexible tire? Power hop clearly makes the point.
Removing the liquid ballast and adding cast ballast softens the tire increases traction.
How to control power hop: MFWD and 4WD Tractors : Mechanical Front-Wheel Drive (MFWD) and 4WD Tractors may jump or bounce during field operation, creating an uncomfortable ride and loss of traction.
Field Power Hop on Four Wheel Drive Tractors | Firestone Agricultural Tire
/ Fluid or Weights??? #76
Note that both bulletins are about large tractors with dual or even triple tires on all four corners. Not many here need to worry about how many sections a day you can till.
/ Fluid or Weights??? #77
Maybe the other posters have a similar problem as you and their wife won't let them buy the $1500 weights! Here you go getting up on your anti CaCl SOAPBOX!
/ Fluid or Weights??? #78
I knew you had missed a zero by mistake and did not even mention that.
Explain how you arrive at the point that a cast weight tire will outpull a liquid filled tire of the same weight??
/ Fluid or Weights??? #79
That might be so on my JD2210 SCUT. Not so much on anything bigger. And my Utility class tractor has the fuel tank under the driver's feet. But I don't think it's a valid enough point to enter into this discussion. I weigh 180 lbs, my M9540 holds 26 gallons of fuel which would weigh in the neighborhood of 200lbs. Insignificant when compared to the 1500lbs of fluid and 250lbs of tire weight that it carries.
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A61574)
2008 21 Ft...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61573)
2010 Ari Hetra...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
(6) SHANK RIPPER BEDDER W/AUTOMATIC SHANK TRIP (A64280)
(6) SHANK RIPPER...
2017 Subaru Forrester (A62613)
2017 Subaru...
Lockers (A62613)
Lockers (A62613)
