moving mower deck with FEL?
/ moving mower deck with FEL? #1
MattEffinCameron
New England
B2920
stupid question here but is there a good way to move a 60" mower deck around with the FEL (for me specifically this would ba an LA364 on B series?
I am thinking it would be easier to move around from point A to point B (aside from mounting it to the belly) if I could use the loader, and maybe if I was to work on the deck, hanging it from hooks on the loader vertically might make the underside more conveniently accessible....but then I am picturing, especially if carrying ti vertically, that the loader would have to be high in the air for there to be enough space for the deck to hang and this might not be good for moving from point A to point B?
/ moving mower deck with FEL? #2
When I first got my tractor I had to move the tractor with fel, the backhoe and the bush hog at the same time via a ferry trip. No possibility of two trips. The backhoe was mounted, and the bush hog was loaded into the bucket and held in place by a number of straps. Worked fine. Drove about four miles along dirt roads with lots of bouncing and nothing moved.
that hadnt even occured to me...I was thinking of lifting it with a strap...that seems to make more sense though :)
/ moving mower deck with FEL? #4
Lifting with a strap leaves the mower flopping about and it could easily crash into your grill. It is easy to secure the mower inside the bucket so long as you have some bucket hooks. If you don't have bucket hooks (why not???) then perhaps a couple of long chains to loop around the mower and bucket with some ratchet straps to provide tension on the chain should work to secure it.
I just noticed the details in your post. An LA364 doesn't have a whole lot of lift and the mower, in the bucket, sticks out so lift capacity will be even lower with all that weight forward of the pivot points. On the other hand, loaders are spec'd to lift to full height and you really only need to raise the load a couple of feet. Might be close to the loader limit.
The Kioti CK20 loader is probably capable of lifting a couple hundred pounds more than the LA364. Do you know the weight of the mower?
/ moving mower deck with FEL? #5
If you have pallet forks, that's the way I move my 62D 7-Iron deck around when it's not mounted. Pick it up, tilt it back a bit and go... holds it plenty steady when bouncing from place to place and if I have the guild wheels down on the deck, the forks slide right under it without having to tug at it or even get off my seat.
/ moving mower deck with FEL? #6
I move my 60" with the FEL. I lower the bucket to just above the deck then attach two chains to the front and one in the back. This keeps the load low and prevents the MMM from swinging very much over rough terrain.
/ moving mower deck with FEL? #7
Another thought, if the mower fits inside the bucket with the tailwheel sticking out in front of the tractor, you could just use the tailwheel to carry part of the load. Just raise the bucket a foot or so with the bucket slightly "dumped" so some of the weight is on the tailwheel.
guess i forgot to mention, this is a MMM...
Davesl708, any pictures of this?
/ moving mower deck with FEL? #9
guess i forgot to mention, this is a MMM... Davesl708, any pictures of this?
Then it should be light enough to lift even sticking out. If too wide to fit in the bucket, consider picking up a set of light duty clamp on forks. You'll find other uses for forks down the road.
yea, I dont know that I will wind up going this direction but I am currently waiting on some pricing from a few places on a kubota B1658 quick attach and a set of forks that work with that system...if that proves to be unattainable I will check out the clamp-ons. I did just order a piranha toothbar though so that would make using clamp-ons a little more difficult.
/ moving mower deck with FEL? #11
Forks might fit over the toothbar. Also, toothbar is pretty easy to remove (or delay installing).
/ moving mower deck with FEL? #12
I move my deck with my loader every time I move it to hook up or unhook. I took a piece of flat metal 1/4" x 1" x 5" long. drilled a hole in each end and bolted a chain to one end. the other end has h hole that fits the spring loaded pin that attaches the back of the mower deck to the tractor. The spring loaded pin holds it to the deck and the chain hooks in the hooks welded to the top of the bucket. quick and easy fir short distances.
pics!
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A61574)
2022 21ft Scout...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2017 International 4300 Box Truck (A62613)
2017 International...
John Deere 7230 (A62180)
John Deere 7230...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
