Your most used/valuable attachment?
/ Your most used/valuable attachment? #1
Ibow
Hudsonville, MI
John Deere 2520
Besides your bucket/loader, what's your most useful attachment? I've got a 2520 and am thinking about adding another attachment to the "arsenal". I currently have a bucket and backhoe but was thinking about something else.
My plan is to eventually do a little light landscaping and excavating for a little business after I retire this summer. Don't need to make a living, just a little gas and "go out to eat on Saturday night" money.
/ Your most used/valuable attachment? #3
Quick-attach brush fork with removeable stick rakes. Raking a lot, picking up rocks.
417756d1427075248-your-most-used-valuable-attachment-brushforkb2710stickrakesnormal2-jpg
I raked up piles of vegetation, backed the brushhog over the piles and reduced them to mulch, then pushed the piles of mulch off into the bushes.
417754d1427075248-your-most-used-valuable-attachment-brushforkb2710stickrakesbackwards1-jpg
Here's the build page for the stick rakes on my old BX24 (sold). Here's the build page for the quick-release, it quickly bloated with other folks' tine problems. So I can see this is a concern! I was jazzed about my quick release arrangement but nobody cared. To me it's just about the best feature of the brush fork, how easy it goes on and off.
With regard to tines,,,,,,,, my tines are 1 x 2 x .120wall steel tube, 47 inches long, weight 68 lbs. But there are 5 of them, and the outer two are vulnerable - can take a beating if you're sloppy. It's a balance of light weight and "suitable" strength for a "882lbs" FEL . 4 feet is a foot too long but I know how strong they are and can deal with the extra foot. At some point I will add doublers near the tine root and it will be OK. But for the general public (without my experience bending tines & straightening them !! ) I would recommend - use 36 inch length, or reinforce the tines at the root or both. This is all for a compact tractor, 882 lbs capacity. A bigger tractor will need bigger tines.
Using brush fork to put a snowmobile on a shelf for after winter. Note that LA402 loader is rated 882 lbs but with 588 lbs on the FEL (as in this pic) I had to build the shelf height at 50 inches because LA402 was not capable to lift 588 lbs the full 66 inches.
417765d1427079088-your-most-used-valuable-attachment-skidoo-shelf16-jpg
/ Your most used/valuable attachment? #4
Box blade and front forks.
/ Your most used/valuable attachment? #6
I know this will not go with your set -up but as far as making money you want a tiller and a small bush hog. Some of the bank foreclosed properties just about require a big mower to get the place in shape for regular mowing. Get the word out commercial pays slower but better for your time.
/ Your most used/valuable attachment? #7
Between the forks and the bucket, wouldn't do without either one. Have the forks on more than the bucket and move a lot of pallets, brush piles, logs, dig out rocks/boulders, stumps, and reach up into trees to break off dead limbs. Many uses.
/ Your most used/valuable attachment? #8
I have a box blade for my Ford 6000...want one for my 2305 JD...great tool
/ Your most used/valuable attachment? #9
my 4 wheeler is just about as important useful attachment tool as any. one that can pull, haul, tote, check the cows, hay ready to bale, check fences, saves me a lot of steps, hunt,fish, on and on and on..easy on easy off 1 tool that does it all.
/ Your most used/valuable attachment? #10
Sure the 4 wheeler is useful....but not an attachment
/ Your most used/valuable attachment? #12
It didn't take us long to realize that we used pallet forks more then a bucket.
Harley rock rake, like magic!
A grapple. Kick myself for not getting one sooner!
Trying to build a version of a "Flip Screen Bucket" Life will be complete should this be realized!
Thanks so much for all the very helpful replies and the picts as well.
Sodo, wow. Very creative. Thanks for posting the picts and the info as to how you came up with your very clever attachment.
Lots of good suggestions here. Thanks!
/ Your most used/valuable attachment? #14
Without a doubt..............my backhoe.
The forks and the grapple are nice. The grader blade for the backhoe's bucket is great to use in fine grading.
hugs, Brandi
Thanks Brandi. Do you have a pict of the grader blade for your backhoe?
/ Your most used/valuable attachment? #17
I'm attachment poor at this time but I will overcome this deficiency. :D
But for now based on hours of use it has to be the snow plow. In use five months of the year doing "Has to be done" work.
Indeed VTSnowedin, everyone who's had a snow plow or blower has gotten some use out of them the past couple of years for sure. Ours is just about gone now in West MI. (thankfully)
/ Your most used/valuable attachment? #19
The "least used" but valuable to me is the wing plow I built for the JD 4300. This winter only used it once, but it was available, quick to mount, and easy to store. And the snowplow berm was quickly moved back making room for more snow.
Very clever beenthere. Thanks.
