Help! Learning to weld
/ Help! Learning to weld #41
... ... I will also try to test it at a friends place to see if there is something weird with my supply.[/QUOTE said:
For starters, I like this idea the best.
/ Help! Learning to weld #42
I originally tried doing this, I hooked each probe one to each hot and plugged the cord in as far as I could, I only read 60V across them, the switch was on if I remember. I just assumed this was because they prongs were not making a good enough connection, could this be an issue?
reading 60V when you expect 240V is real strange. If a poor connection is causing that kind of voltage drop, it would be smoking a bit.
Something not quite right here... yeah that's an understatement...:cool2:
Pete
/ Help! Learning to weld #44
I have trouble shooted (shot?) thousands of circuits. It is not uncommon for the simplest of things to be our undoing! Sometimes the relationship of one part is not fully understood to the next part. Why do batteries, starters and alternators seem, all to often fail in some sort of conspired fashion?
Why do my test leads fail while in the middle of such chaos? Or my (Stupid) Fluke meter times out and the display goes blank (to save the 9 volt battery life)!
The sad thing is, all too often when you get things going (as you will) you never in the end really know what the true, initial cause was! And that means, the educational value of the painfull experience is highly deminished!
/ Help! Learning to weld #45
Have we established whether the on/off switch is good yet?
/ Help! Learning to weld #47
I am wondering if everything is wired right and the shops says it works sooo. Without meaning anything smart. Is it possible that you are putting the rod in the holder backwards. Meaning that your trying to strike the arc with the bare end. If not start with the holder and touch the ground. Arc or no arc. Start from there and work back to the machine.
I have myself and seen other guys do it. Stick the rod in the holder and clamp it on the flux. No amount of beating on the workpiece will get an arc.
/ Help! Learning to weld #48
well I see both hot wires from the outlet connecting to a single incoming wire. In other words there's two outlets connected on with one incoming wire so is three wires under one wire nut. There's no way in the world you can have 240 that way I'm not sure how you're reading it. is this connected to a 2 pole or doublr breaker or a single breaker. maybe there's something in that picture I'm not seen
it is clearly NOT wired that way. The lead that is tied together is the ground, which is tied to the box, so there is a wire nut there. The two hot leads come straight in from the conduit to the outlet as they should.
Okay so I tested the welder a my friends house, and it works fine... So the issue is with the power in my garage. How can I tell if the outlet is single phase? I wondering if that is the issue because the welder says input: single phase.
I will try the light bulb suggestion when I get home to see if it can handle a load. Other than that I may have to can an electrician.
Thanks for all of your suggestions!
/ Help! Learning to weld #50
so, in post #16 you say you measured 245V between the 2 hot wires on the outlet, when you had the box open.
in post # 36 you measured only 60V between the 2 hot terminals of the welder plug when plugged into the outlet.
sounds like that narrows it down to the outlet/receptacle itself ??? Like I said earlier, if there is a bad connection somewhere that is causing that much of a voltage drop when the welder is plugged in/turned on, I would expect to see some smoke and or overheating of said bad connection.
can you confirm that the reading of 60V is only when the welder is turned on, and it should read 240V when the welder is turned off.
Pete
/ Help! Learning to weld #51
Attach a bulb across one leg of the circuit while the welder's plugged in, see if the light goes out when you turn on the welder. Then try same on the other leg. This might suggest which lag is unable to supply power.
I had to change a stove outlet recently, and was quite surprised to notice that all three of the screw connections on the back of the outlet were less than finger-tight - loose actually. And clearly it had been that way for years. You might check all screws. Also in the panel, check the screw tightness on the supply breakers.
/ Help! Learning to weld #52
Okay so I tested the welder a my friends house, and it works fine... So the issue is with the power in my garage. How can I tell if the outlet is single phase? I wondering if that is the issue because the welder says input: single phase. <snip>
Good to hear it works!
Like I wrote - it's EXTREMELY RARE to be dual or two phase anywhere except Philadelphia, and it's also rare for residential to have three phase. If you do have three phase count yourself lucky, many of us would give our eyeteeth for three phase.
/ Help! Learning to weld #53
you have single phase.
i agree that its looking like an issue with receptacle. if it works fine at friends house, and not at yours theres as issue with outlet.
when you plug it it, is it hard to plug in, or does it easily plug in?
the terminals might be oxidized. yoiu can always buy a new receptacle at home depot fo $10 and give that a try
GOT IT!!!! Haha after closer inspection of the outlet I noticed that the contact for the left side was really far back in the outlet. The left prong on the welder cord was not making contact with the left side so in effect it was only getting 120V. I got a new receptacle and she fired right up!
/ Help! Learning to weld #55
Great news. Now that you have successfully turned the welder on, the rest is easy!!! Now just weld!
I'm a beginner too. Get ready to be humbled!
/ Help! Learning to weld #56
Great! Glad you found it. Those kind of problems can drive you mad.
I had a friend that built a new house, and his clothes dryer quit drying. I thought that was odd, so I checked the outlet. One hot leg was dead. Checked at the breaker, both hot.
Some where between the two, someone had severed one of the hot wires. I taped off the breaker and called his electrician to come and rewire the outlet. He couldn't believe what I was telling him untill he saw it for himself.
I still want to cut into the walls to see how it happened.
/ Help! Learning to weld #57
If you had removed the receptacle and plugged in the welder, taking a resistance reading off the terminals of the receptacle, as I suggested, you would have discovered the fault. Just saying for educational purposes.
GLAD you solved your problem. No one had to die, nothing got burned down!
/ Help! Learning to weld #58
Dont' ever tell anyone on this site that you tried welding with 110v power. Folks can't handle that for some reason. Sodo can explain.
/ Help! Learning to weld #59
Didn't work very well now did it":D
/ Help! Learning to weld #60
"in effect it was only getting 120V"
In the interest of even more ejumication :D, you didn't even have 120 volts if it was wired correctly - 240 volt wired plugs (3 prong) have two hot wires 120 volts and 180 degrees out of phase, and an equipment GROUND - no neutral. So even though you had 120 volts at one contact, there was no return path so no current could flow.
An equipment ground is supposed to be ONLY connected to the chassis/frame of the equipment so an internal wiring problem cannot cause the outer parts of the device to be live.
Newer stuff, especially with a motor of some type and/or electronics, uses a 4 prong plug - it has the same 3 wires as a 3 prong, with an added neutral so 120 volt power can be had and still meet code. On those units, the neutral is only connected as a return for any 120 volt components, and the ground is only connected to the frame.
I know it seems weird at first, but even though BOTH the ground and neutral attach to the same buss bar in your panel, the ground is NEVER supposed to carry current unless there is a problem - but a neutral will carry just as much current as the hot wire since it is the return.
HTH... Steve
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61573)
2019 East...
PULL TYPE DIRT PAN (A63291)
PULL TYPE DIRT PAN...
2020 Solar Tech Silent Advisor S/A Solar Towable Radar Trailer (A61572)
2020 Solar Tech...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
