Remote Hydraulic Hoses
/ Remote Hydraulic Hoses #1
8NAcres
Member
Garland, Texas
Kioti DK45S w/ KL451 Loader 1954 Ford NAA 1948 Ford 8N 1939 Ford 9N
Got my new Titan grapple in and now I need to order two hydraulic hoses to run from the rear remotes to the grapple on my 2006 DK45S. I measured the distance needed with a garden hose so I could route it as I will the hydraulic hoses and then measure how long I need. I do have a few questions for those that have done this as I am new to this process.
What is the name of the connectors I need for the rear remotes? The hydraulic shop needs to know this to put the right connectors on the hoses.
I know the grapple hoses are 1/2" Flat Faced Parker Style hoses - but one is male and one is female. Do I need to ensure a specific hose gets hooked to a specific port on the rear of the tractor?
When I measured the length needed - I went from the rear remotes to the middle of the lift arms (to the front, in between the arms). Does this sound right? Came to 17 ft.
What PSI rating should I get for these hoses?
What is the approximate costs I should be paying - the local guy quoted me "about" $150 each hose - that is a tad over $300 for the pair - does this sound about right?
Sorry for the newbie questions - but my previous tractors are antiques and I have never dealt with this before.
/ Remote Hydraulic Hoses #2
PSI-3000 or better.
1/2 iso7241-1 connectors.
Measure from the front cross bar on the FEL to the rear connectors.
/ Remote Hydraulic Hoses #3
add a set of disconnects about 1/2 way under the loader also, so you can remove the loader without having to totally remove all attachment points of the hose kit. i didnt do this originally, and when i needed to remove loader to mow field it was a real PITA. _MG_4950.jpg plow hose.jpg IMG_20150318_141633366.jpg
Hmm - in looking at your pic I see you have your lines terminating to some sort of a plate with the quick connects mounted to that. My layman's idea was just to run the hoses to the front and connect them directly to the grapple hoses - is that wrong?
Also - I got a call back from the hydraulic shop and they said for two hoses, with appropriate male connectors on one end to attach to the rear remote and a male/female to connect to the grapple hoses, at 17 feet, would cost me over $500.00! Maybe I am naïve but that sounds a little steep for two hoses - that is almost the cost of the brand new grapple! Am I off base here or does that sound right? If it is right, I may have to sell my grapple as it won't do me any good sitting around.
/ Remote Hydraulic Hoses #5
You can buy a hose kit from MIE for a lot less than that. Error this link does work.
/ Remote Hydraulic Hoses #6
Check your PM, I think you will like what you read. ;)
/ Remote Hydraulic Hoses #7
PSI-3000 or better.
Are you sure about those ISO numbers? :confused:
Hey, just about ready to work on your box blade ripper bar?
/ Remote Hydraulic Hoses #8
mine cost about $200 for entire kit. you need to shop around.
also check with any local tractor dealers. doesnt need to be kioti. most do hyd hoses.
i get all my hoses from a parker hydraulic hose shop intown.
/ Remote Hydraulic Hoses #9
4 hoses,4 complete sets of couplers and 2 bulkhead mounts?
/ Remote Hydraulic Hoses #10
my dealer installed them for $218.00.
i just recehcked invoice.
i did have to take them off and take to parker to have another set of disconnects added as stated above. i dont have receipt for that work though.
and im sure i got a deal cause i had them installed at time of purchase. but thats all i know
/ Remote Hydraulic Hoses #12
Not really questioning you, just that some where, something is getting left out. That or there are other considerations not being accounted for. No one that is going to stay in business is doing this stuff below cost. Just don't want others to think that they are getting a bad deal when it costs them more than the $200 first mentioned. ;)
/ Remote Hydraulic Hoses #13
yes and yes, be going to the barn next week. my chart shows those #s.
/ Remote Hydraulic Hoses #14
I bought all my 1/2" 3000 PSI hose and fittings at TSC. I think I paid around $200. or a little more. My hoses are 14'. Surplus Center and Discount Hydraulic Hose are a couple other places that can supply what you need.
/ Remote Hydraulic Hoses #16
/ Remote Hydraulic Hoses #17
I got the # from a DHH QDchart. Maybe same same?
Not 100% sure without having one of each in front of me. :ashamed: I just know what I've been selling and that my customers have all been satisfied, everything has worked so far.
Contact me for the hydraulic stuff, I have it all setting here. Just about have mine done. :cool:
/ Remote Hydraulic Hoses #18
Lets see some pics.
/ Remote Hydraulic Hoses #19
All the NAPA's around here will make up hydraulic hoses any length you want...
SR
Zuidberg Front 3pt and PTO Kit (A63117)
Zuidberg Front 3pt...
Chevrolet 2500HD (A63688)
Chevrolet 2500HD...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
3pt 4 Row Bottom Plow (A64119)
3pt 4 Row Bottom...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
