Could you measure your B or L filter assembly for me?
   / Could you measure your B or L filter assembly for me? #11
I have that filter to convert my BX25 when it gets warmer. If it ever gets warmer!
Bottom of bulb to top of mounting flange - 4.420"
Bottom of bulb to highest point (OAL) - 4.435"
Do you have a P/N for this assembly. Thanks!
Not to high jack the thread, but I'll be interested to see where and how you mount it on your BX.
Me to.... Iv purchased a slightly larger inline NAPA Gold filter #3324 that looks small enuf to substitute in next change in the BX. Both D and L are a little more - maybe itll give ~ twice the filter area. I have hi hopes.
larry
   / Could you measure your B or L filter assembly for me? #16
Roger,
I measured the filter assembly, height only. From the top of the higest point of the base to the bottom of the bowl is 4 11/16. Hope this is the information you sought.
Resondent # 79 I suppose
Smilinjak
Roger,
Smilinjak
Thanks, I need something under 5'' for where I plan on mounting it.
   / Could you measure your B or L filter assembly for me? #18
The 3972 is the factory filter for the BX.
The 3927 IS NOT EQUIVALENT to the BX factory filter, the 3972/33972 is PLASTIC MESH with a 50 MICRON RATING where the Kubota BX filter is water blocking paper.
This is why I do not trust the WIX cross lists.
David Kb7uns
1994 FORD F450-SUPER DUTY FLATBED (A51222)
1994 FORD...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
71061 (A49346)
71061 (A49346)
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
3 pt Rolling Basket & Harrow (A50514)
3 pt Rolling...
2003 Honda ATV (A50324)
2003 Honda ATV...
