Could you measure your B or L filter assembly for me?
   / Could you measure your B or L filter assembly for me? #11
I have that filter to convert my BX25 when it gets warmer. If it ever gets warmer!
Bottom of bulb to top of mounting flange - 4.420"
Bottom of bulb to highest point (OAL) - 4.435"
Do you have a P/N for this assembly. Thanks!
Not to high jack the thread, but I'll be interested to see where and how you mount it on your BX.
Me to.... Iv purchased a slightly larger inline NAPA Gold filter #3324 that looks small enuf to substitute in next change in the BX. Both D and L are a little more - maybe itll give ~ twice the filter area. I have hi hopes.
larry
   / Could you measure your B or L filter assembly for me? #16
Roger,
I measured the filter assembly, height only. From the top of the higest point of the base to the bottom of the bowl is 4 11/16. Hope this is the information you sought.
Resondent # 79 I suppose
Smilinjak
Roger,
Smilinjak
Thanks, I need something under 5'' for where I plan on mounting it.
   / Could you measure your B or L filter assembly for me? #18
The 3972 is the factory filter for the BX.
The 3927 IS NOT EQUIVALENT to the BX factory filter, the 3972/33972 is PLASTIC MESH with a 50 MICRON RATING where the Kubota BX filter is water blocking paper.
This is why I do not trust the WIX cross lists.
David Kb7uns
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
BE 3 pt Snow Blower (A50514)
BE 3 pt Snow...
1993 Harsh Feed Mixer (A51039)
1993 Harsh Feed...
