Seriously considering PT . . .but
/ Seriously considering PT . . .but #1
Digger 258
Northern VA
Bolens / Iseki G152 & PT-425
Just retired from the Marine Corps and am seriously considering picking up a PT for the 5 acres I have just settled on. I have little to no experience with tractors and other equipment heavier than hand tools, so I realize my frame of reference needs refinement. I picked up an old garden tractor (a really cool Bolens 1225) to carry me over until I make a long term investment and have really figured out what I need. I am wickedly attracted to the PTs because of their apparent versatility for what I need to do. I have my eye on a used 1430, but it has the 3 pin connection. This brings my first question: What can I NOT do with a 3 pin set up? Which attachments won't work? Should I avoid the 3 pin connection or modify it to take an aux PTO?
Here's what I need to do around my property in no particular order:
- Split and move lots of firewood
- Dig about 1000' of french drain
- Trench 800' to run power and water to the barn (3 feet deep according to code)
- Bore holes for footers (to make stairs up into the barn)
- Move lots of mulch, gravel and topsoil
- Maintain 1000' gravel driveway
- Clear snow
- Handle heavy stuff from the truck or trailer (55 gal drums, feed, pallet of cement, etc)
- String fence
My property is relatively flat, but really muddy when it rains, so hills are not an issue, while traction is - yet I would like to avoid tearing up the lawn too much . . .
I'd prefer to have one versatile piece of equipment instead of investing in multiples, which is what attracts me to PT, and of course since I sunk my life savings into this property, I am now happily cash strapped - which has me considering used PTs.
I'm also thinking of making the 5 hour drive to the factory, but I'm afraid what I will convince myself that I need!
I've been lurking in this forum for a few weeks now and I appreciate the well informed ideas here. I really appreciate all of your opinions and experience as it relates to my needs.
Semper Fidelis
/ Seriously considering PT . . .but #2
I am not familiar with the 3 pin setup, but I bought a 1430 about a year and a half ago to help maintain an apple orchard and clean up after horses. I use it to mow, haul brush, power a log splitter, clear snow, load manure, and move many other things. I went with the ag or bar tires and purchased the grapple bucket, 9 cubic foot bucket, and the brush mower. The attachments are cheaper than comparable skid steer attachments, but still expensive. I would love a stump grinder, but can't justify the price. If you are only going to dig a trench once or not very frequently, it would be much cheaper to rent a trencher or have someone dig it.
strong points
Very capable commercial quality machine. The loader is much stronger and pushes into material much better than a compact tractor. The ag tires make a big difference.
Very little turf damage. It will leave marks if I drive it on very wet grass, but normally I can turn as sharp as I want without leaving a trace.
Very good fuel consumption. It uses less fuel than a 30 hp Kabota
Very easy to maintain. It's the easiest machine I've worked on. There are covers that can be removed to give easy access to nearly everything.
Much easier to climb in and out of than a skid steer
Overall operation position is very good, but seat could use more padding.
Engine starts very well in winter. It started last winter when it was -7. I added diesel fuel anti-gel supplement, but didn't use a heater.
weak points
You need to like to tinker. There is no dealer network and I don't think QC at PT is the best. I've had to repair a few broken wires and replace the throttle cable. These are all easy repairs, but it would be inconvenient and possibly expensive to take it somewhere. Nearly all the parts are off the shelf so it shouldn't be hard to get a service center to repair it if there's something I can't do.
Bill
Thanks Bill. I should have added that I much prefer to tinker on things myself, and while I recognize I have absolutely no experience with hydraulics, there is probably no better way to learn than to plop right in the middle of a hydraulic system. It sounds like you have a pretty versatile machine on your hands, and I am discovering that it's the tasks that I have not even forseen yet that I need to be ready to handle. I was looking hard at the compact TLB lineups, but there is something in my genes that prefers a swiss army knife to a scalpel, and though they are shiny with nifty catalogs, I'm hesitant to spend so much $$$ on a TLB that won't most of what I need. Would really like to learn more about that 3 pin setup and what I can't attach to it.
Thanks!
Dan
/ Seriously considering PT . . .but #4
Retired Navy here
I have a 1445 with 3pt type hook up.
I have a large number of attachments.
If you don't have any 3pt attachments, then just make an adapter to fit the new attachments.
They sell the connecting plates, and all you have to do is to weld on some 3pt connection points.
Thanks JJ. If I understand this right, on the newer models, the "quick attach" is hydraulically driven, and that hydraulic circuit also powers some attachments. I assume on the 3-pin set up, since it is a manual attach, there is one less hydraulic circuit, which means something doesn't get power. Am I anywhere close in my estimate?
And I don't want to confuse a 3 point hitch on the rear of a conventional tractor with the PT 3-pin attachment, because they are completely different things right?. Just goes to show that I have a whole lot to learn. . .
/ Seriously considering PT . . .but #6
It seems like a very versatile machine with lots of attachments. However, if you want to just rent an attachment for short term work (ex: digging a trench once) it would probably be easier to rent an attachment to go on a conventional type tractor than the PT1430.
There are also attachments available on craigslist for conventional tractors that come in much lower than new price.
Plus it you ever want to do some sort of vegetable garden it looks to me like the PT1430 does not have the ground clearance needed to get too deep into the soil before it might become mired in that mud you have.
Aim High!
/ Seriously considering PT . . .but #7
The hyd part of the attachment is just for the locking pins.
You should have another circuit for the PTO.
My PTO valve is a variable speed control, whereas most of the PTO controls are solenoid operated and full on.
I can vary the speed on my PTO.
A three point reference is just for the older PT.
I have made an adapter plate for my skid steer to use my PT attachments. So it is a skid steer to PT three point adapter.
Ok, that makes sense. So using a trencher or a mini hoe would be no problem on the older 3 pin PTs? If that's the case I might be jumping on one sooner than I thought . . .
/ Seriously considering PT . . .but #9
PTO GPM should be about 12, and 2500 psi.
/ Seriously considering PT . . .but #10
Welcome Digger 258,
Of the list of tasks you mention, the one that stands out to me where the PT is not ideal is maintaining that long driveway... That task is well-suited to a box blade being dragged (as you drive forward on an Ag tractor). With a PT, you'd have to drag the box blade while driving in reverse.
Hope this helps,
/ Seriously considering PT . . .but #11
First, Welcome to TBN! :thumbsup:
Second, call Terry at Power Trac and ask specifically about the 3 pin implement hook-up VS the quick attach and what implements will and will not work on it, and if adapters are available. If the unit has only a MAIN PTO circuit, that will power a trencher, but it won't power a mini-hoe. You need the AUX PTO to power the mini-hoe, power-angle snow plow, grapple bucket, etc... here's how it works...
The MAIN PTO is a pump that pushes high pressure fluid at a high flow rate in one direction and has a built in motor spool valve that allows hydraulic motors to keep spinning once you shut off the power to them. Best example: mower decks. If you were to shut off the circuit to a mower deck, the weight of the blades keeps them turning for a while while the motor spins down in speed. If it were just and on/off valve, the motor would BANG to a stop. You don't use the MAIN PTO to power hydraulic cylinders on attachments(typically), although you could route it to a log splitter if you need high flow.
The AUX PTO is also a high pressure pump, but at a much lower rate, and it feeds the steering valve, through a power beyond port on the steering valve, to the Front End Loader valve, which may or may not have a 3rd valve called the AUX PTO valve, then back to the hydraulic tank. This is typically located by the operator's right knee. The AUX PTO valve is a directional valve, forward or backwards, that controls hydraulic cylinders, not motors. If the unit has a quick attach feature, it operates the cylinder that opens and closes the quick attach tangs. Once you lock an implement like a mini-hoe in place, you disconnect the AUX PTO hoses to the quick attach and connect them to the mini-hoe cylinder. The AUX PTO valve now controls the cylinder on the mini-hoe to curl or dump it. When you're done using it, you disconnect the hoses from the hoe and hook them back up to the quick attach so you can open the quick attach tangs and change implements. It takes all of 30 seconds to get off the tractor, swap hoses, and get back on.
So, for the most part, MAIN PTO is for hydraulic motors, AUX PTO is for hydraulic cylinders.
Does that make sense?
/ Seriously considering PT . . .but #12
Aim High!
I agree with renting more specialized equipment for one-time jobs. For example, digging out a foundation or a 1 time 1000' trench might be better accomplished with a mini-excavator over a couple days with a weekend rental rate of about $300.
As for ground clearance in a garden... a PT with a tiller in a garden is about as good as it gets! :) There won't be any ground clearance issues. I frequently take my smaller PT425 through very intense, thick brush and woods, over fallen trees and branches and rarely get hung up. Because it articulates left and right and also oscillates between the sections, there's a better chance of keeping all four tires on the ground than a standard tractor.
MossRoad, thanks for breaking it down "barney style" for me - I understand perfectly as you describe it. I will most certainly call Terry at PT, and will try to schedule a trip to Tazewell (where I suspect I am sure to get hooked). I am sure that my trenching will not be a one time deal, rather just the beginning of a bunch of other lines I will have to run, so I am pretty set on a trencher and a backhoe. I cannot decide if the mini-hoe or the actual back hoe is the way to go, I have many digging projects lined up, and knowing myself, I am the kind of person who wants to buy something once and keep it forever. I guess if I really need a mini-hoe, the natural conclusion is that a 3 pin PT won't do for me, I will need one with the aux PTO. I'll keep looking and learning!
/ Seriously considering PT . . .but #14
I like to own as well. However, after slapping myself a few times, more times than not, it makes sense to rent for the odd jobs. I've rented a small tracked excavator to put in a small barn foundation. I took a two-day weekend rate rental hoping to complete the task in 48 hours. However, I finished the trenching in about 2 hours, pulled a bunch of small trees, dug out a bunch of bushes and ran out of things to do in 4 hours and returned it the same day for a sizable refund. It was a couple hundred bucks total. Job done. No implement to sit in the corner of the garage for years at a time between needs. More money for toys I can use more often! :thumbsup: :laughing:
/ Seriously considering PT . . .but #15
I don't know your skills, but you can build some of those hyd implements.
Surplus sells a lot of large cu in hyd motors for things like trenchers, stump grinders, hyd auger, etc.
If you have the 3pt set up, you can build the attachments plates for any implement you desire.
You can use things like hyd chainsaws, hyd pole pruner, hyd jacks, hyd well driller, hyd tree saw,etc.
All my implements are 3pt. I probably have the only dozer blade with hyd angle using the aux hyd.
J.J. I don't know anything about Hydraulics yet, but I really want to learn, and I just know I am going to keep running into tasks where I'll say "I wonder if I can make a tool for that . . ." I probably should start doing some reading on how Hydro systems work in the first place. I still framing the problem to determine if a PT is a good, flexible starting point for what I need to get done and you all have been most helpful. I have the wicked problem where the more I look a t PTs, the more attractive they become and the more I want one. Never owned a tractor before though, so I feel like I should gather as many opinions as I can handle.
/ Seriously considering PT . . .but #17
The trencher can be used for other things than trenching. It can be used to breakup the ground and then use the bucket to take the soil away. I used it to dig a small pond. Also your neighbors will love having you dig trenches for them. Approximately 2/3 of my trenching has been for others. This might be considered a negative.
A small pond done with a trencher and bucket? I never would have thought of that! Part of my problem is that I can only tackle the jobs at home in small chunks of time because that silly thing called work gets in the way, so rental units aren't ideal. I guess my most pressing need is to dig lots of trenches for utilities and lots of drainage, next is footings for a deck . . . If the collateral damage is a call to help my neighbors maybe I should do their trenches first until I fully learn how to use the implements? That's pretty neighborly, right?
I've got till June, when I take off the uniform for good, to make a decision so I'm gonna keep searching for used PTs in the meantime.
/ Seriously considering PT . . .but #19
By small I mean about 20 feet across. About 3 feet deep. A gold fish pond. Trenching is not difficult to learn.
/ Seriously considering PT . . .but #20
Download this PDF to your PC and read it. The Army field manual for hydraulics....
http://www.derijcke.com/dl/manual.pdf
2015 John Deere 8295R (A64119)
2015 John Deere...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2012 VICON ROTOFLOW RO-C SPREADER (A63291)
2012 VICON...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
Caterpillar 330/330L Excavator Parts and Service Manuals (A63117)
Caterpillar...
