cast iron cookware care
/ cast iron cookware care #21
Interesting thread. I have used my needle scaler on a $3.00 Lodge dutch oven that I bought at a yard sale. It did a good initial cleaning and got the heavy rust off. After a few more steps I heated it outside with my Red Dragon torch to prep seasoning... I can hear some of you shouting in disbelief from here.
No disbelief here, I've used a cup brush before I knew any better! I didn't think it mattered, but I've since learned better...
I have some good CI, I just refuse to scratch it up or warp or crack it from misuse...
SR
/ cast iron cookware care #22
During the prep did you spit on it??
/ cast iron cookware care #23
Like seeing these CI threads, there are a good number of them over the years & I usually try to correct some of the issues people do to it. I like rendered fat for treating my pans, way it was done 150 years ago and good enough for me.
I have one Imperial CI Pan that was originally Ceramic Coated but had chipped. I rescued it from the dump, Bead Blasted it seasoned it (it has 10" wood handle) so seasoning is different. Have to USE it to season it best way is to deep fry some chicken or ? after wiping & heating a few times with lard/bacon grease or fav grease. Always scrape off any stuck on bit with SS spatula under water and heat & spray or wipe after heating to dry.
M
/ cast iron cookware care #24
Intense heat WILL warp CI, and every once in a le, a piece will crack too... I've seen it happen...
Needle scaler scratches the heck out of CI, that's NOT the way I'd treat any of my good CI!
The guy in the vid I posted, has it right!
SR
No argument, but the old folks about here would sometimes burn out CI pans. They would place them on the ground, stack wood around them and build a fire allowing the CI to be heated and burnt out by the coals. After allowing them to cool, they would reseason.
I have done this myself with no warping or cracking. Now, I just sand blast them which is easier and work just as good.
/ cast iron cookware care #25
I threw one in the wood stove and burned a fire on It for a few days. About the same as the oven self cleaning cycle.
/ cast iron cookware care #26
I've always used warm water and a little salt to scrub my cast iron, then put them over a stove burner to dry them.
I also re-season mine about once a year, not a big job nor a long job, but that way I know they're always good to go.
That's what I do, I hit the pan with water whiles its still hot, then use kosher salt and a rag, dry, re-oil, and let sit on a warm stove top to dry thoroughly.
/ cast iron cookware care #27
I do this as well. The spatula tip needs to be flat, not curved. I then wipe it under water with a rag or paper towel to clean it up. Then dry it, warm it on the range to completely dry it. I then melt some coconut oil on it to lube it up, then store it.
Tonight's use of cast iron is Brussels sprouts with olive oil and prosciutto under the broiler on a Wagner shallow skillet. And pork chops in a #7 Griswold skillet.
/ cast iron cookware care #28
I was told you never use soap on cast iron. Iron is porous and will absrb the soap, distorting the flavor of the food. I tske it you have not had these issues? I use a nylon brush and hot water only.
Iron is not porous like a sponge but has a lot of tiny little pits so a couple of minutes in boiling water will have it rinced clean.
Important thing is to take them strait out of the boiling water or heat to dry.
It will only rust in the presence of water so dry then coat with your favourite oil.
If it is rusty and not covered with caked on fats then electrolsys is the only way to go.
If it has a lot of cooking rime them lye first then electrolsys.
20 % to 30 % by weight lye to water and always lye into water never the other way round
/ cast iron cookware care #29
Isn't it easier not to use soap than have to boil it off after you have cleaned the skillet?
/ cast iron cookware care #30
I have not experienced flavor changes.
I am very careful about food safety. I have a friend in Iowa with a multi-year crust in his 12" cast iron skillet he is very proud of. He claims pan is perfectly sanitary. His wife, a nurse practitioner, will not eat food cooked in this "seasoned" skillet.
Well, it is his pan. I wash my cookware with hot water and detergent after cooking.
The FLAX OIL treatment lasts a long time. I applied Flax Oil to my hot pans, let it sit a minute, then wiped excess out with a paper towel, repeat. Maybe five applications over a period of use.
I treated several pans. I still have four ounces of Flax Oil in the eight ounce container. Once I a great while I renew the coating, if that is the correct word.
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2012 Freightliner Cascadia (A61307)
2012 Freightliner...
Club Car (A59231)
Club Car (A59231)
New/Unused CFG Industrial QK18R Mini Excavator (A61166)
New/Unused CFG...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
