Timing Belts: time limit spec
/ Timing Belts: time limit spec #41
What year CR-V did you replace the timing belt? My friend has a 2005 model with a timing chain and it is still humming along at 280k+.
I think some of the newer direct injected vehicles wear out timing chains due to oil dilution/lack of lubrication.
Can't remember but I will find out. That was only the second belt replaced and it has just shy of 300k on it. CJ
/ Timing Belts: time limit spec #43
Older Civics are spec'd by Honda as having a 7 year time limit on the Timing Belt.
Just curious what other interference-engine owners are seeing in their applications....
Rgds, D.
A few years ago had a customer come in with a Civic that according to the customer ( made a funny sound and wouldn't re start no matter how long they cranked it over)
I did a compression test - 0 psi on every cylinder.
Pulled the cam belt cover off and the belt was still on but missing several teeth. after head removal it was actually cheaper to buy a used head, because every valve was bent...
I would be nervous going 100k on a belt on an interference engine.
I see it as cheap insurance to change them a little early.
Almost no other item can do such massive damage in such short order.
I like my non interference- timing chained engines in this respect.
People's ignorance about Tbelts does work to the manufacturers advantage.
Might have been a Continental Tbelt kit a friend just put into his wife's car recently. A nice bright sticker was supplied, with engine appropriate adhesive on it. Great reminder, and good info for a subsequent buyer, if the belt change info is right there, when you open the hood.
Rgds, D.
/ Timing Belts: time limit spec #45
I just had the timing belt, water pump, idlers, cam seals, and belt tensioner replaced on my son's hyundai tiburon for $350 parts and labor. His manual stated interval was 60,000 miles.
That seems like a reasonable price, all-in.
Rgds, D.
/ Timing Belts: time limit spec #47
It is a 2001. The rust will get it before it breaks down! CJ
The Glass-Half-Full version of us living in the salt-belt ! :laughing:
Rgds, D.
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
2019 WESTERN GLOBAL DOUBLE WALLED FUEL TANK (A64279)
2019 WESTERN...
(1) 16"X26'7"LO-1 1/2" THICK CULVERTER PIPE (A64281)
(1) 16"X26'7"LO-1...
(INOP) 2012 POLARIS RANGER 800EFI CREW RTV (A64280)
(INOP) 2012...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
