Timing Belts: time limit spec
/ Timing Belts: time limit spec
I sure like not having to worry about changing belt or chain in my 4.9 I6 Ford. One guy at a repair shop did try to sell me a timing belt job one time, at an estimated cost of $1000. I told him, "go right ahead, but I want to see the old belt once you take it off." Never went back to that place.
I like inline 6 designs. That particular Ford had/has a great reputation.
I think the problem with 'em was they lasted too long ! ;)
Rgds, D.
/ Timing Belts: time limit spec #22
Rgds, D.
+1 Once they put FI on that engine you could hardly kill it. I'll take a belt drive or gear drive any day over chain. We just replaced a belt on a CRV that had just shy of 190k on it and it was still in good shape. I have replaced more timing chains than I can count. I can't remember the newer dodge engine in a pickup that has chains driving overhead cams but I will never touch another one of them. CJ
/ Timing Belts: time limit spec #23
What year CR-V did you replace the timing belt? My friend has a 2005 model with a timing chain and it is still humming along at 280k+.
I think some of the newer direct injected vehicles wear out timing chains due to oil dilution/lack of lubrication.
/ Timing Belts: time limit spec #24
After about 11 years and over 130k I finally did my Tundra. To be honest, I'll never change it again. The belt looked fine. I really only did it because I was worried about the water pump (driven off of the T-Belt). I was expecting to see cracks in the rubber but it had none. A coworker had his done on his 2003 Tundra when they changed the frame. It had over 200k on it. The dealer was trying to hustle up extra work. Since the belt was going to be easy to get at they could offer to replace it and the water pump they were offering discounts to do the work. I would say replace the belt with a high quality one, I bought the oem. The only timing belt I have broken was on a 1990 Celica. The AC compressor locked up under warranty and the accessory belt snapped and broke through the T-Belt cover.
My new Toyota has a timing chain that's designed to last the life of the engine. I think it's about 250k. Of course it also uses synthetic oil which should help prevent wear.
/ Timing Belts: time limit spec #26
I changed my V8 2005 Tundra at around 93,000 and noticed it ran and idled much better after the change. I used a Toyota belt and changed the water pumps at the same time.
T-belt driven water pumps can seize. So can Idlers, Tensioners.
Can we possibly load more chambers, in this mechanical version of Russian Roulette ? :rolleyes:
Some manuf. do seem to over-design / under-stress their Tbelt applications.
While I do like chains, I much prefer them short - modern OEM practices of wrapping the chain half-way around the engine compartment, then beating the heck out of your supplier on price don't impress me. GM was getting enough chain-stretch on the Torrent class V6s that they had to do an emission recall.
Aside from bad oil, or DI contamination, another problem source for chains is cheap or defective oil filters. A faulty Anti Drain Back Valve can take too long to build oil pressure at start-up. Bad news, esp. if the cam-chain is hydraulically tensioned.
Rgds, D.
/ Timing Belts: time limit spec #28
Chains are fine...if they are short. All makers are having problems with those LONG DOHC timing chains and their tensioners, some at less miles than belts last.
/ Timing Belts: time limit spec #29
I had one where the tensioner pulley came apart and walked out through the front of the timing cover. The worst part was that it was 2 miles from the shop where it was going to get a timing belt and headgasket change.
Aaron Z
Aaron Z
(Knock wood) I can have that kind of luck.... :duh: that's part of why I don't buy lottery tickets.
A couple of Winters back, I heard a request for assistance on one of our local 2m repeaters. A local ham was heading down our version of an interstate, when his not-that-old TDI died.
Even for Feb. , it was a pretty good cold snap - so when I couldn't raise anyone at his house, I got a tow truck on it's way to him. Not a night you would want to be sitting in a car with a dead engine for long.
(For those of you who don't know older ham radio guys...... they are infamous for not spending money; possible exceptions being 2 way radios, and sometimes vehicles. The dead-TDI owner didn't own a cell phone).
On the radio, he said he thought the engine computer had died, from the way the car shut down.
Saw him a few months later........ as you may have guessed (a few paragraphs ago :laughing:), it was the timing belt that broke.
He hadn't considered that possibility when sitting on the side of the road, as he was something like 700 km below the mileage where the change interval allegedly was.
When you come across incidents like this, it sheds some light on why Honda derates my Civic belt for harsh climates.
Rgds, D.
/ Timing Belts: time limit spec #31
It's not always the obvious cost of the new belt so much as the option to choose when!
I'll have the change done next Tuesday morning and not need the vehicle for a couple of hours -v- **** how do I get home now at this hour and how will I get to xxx early in the morning and get little xxx to school and collected again?
You can bet the chances of it being at the most inopportune moment are pretty high when it pillages your bank balance too.
/ Timing Belts: time limit spec #32
(Knock wood) I can have that kind of luck.... :duh: that's part of why I don't buy lottery tickets. A couple of Winters back, I heard a request for assistance on one of our local 2m repeaters. A local ham was heading down our version of an interstate, when his not-that-old TDI died. Even for Feb. , it was a pretty good cold snap - so when I couldn't raise anyone at his house, I got a tow truck on it's way to him. Not a night you would want to be sitting in a car with a dead engine for long. (For those of you who don't know older ham radio guys...... they are infamous for not spending money; possible exceptions being 2 way radios, and sometimes vehicles. The dead-TDI owner didn't own a cell phone). On the radio, he said he thought the engine computer had died, from the way the car shut down. Saw him a few months later........ as you may have guessed (a few paragraphs ago :laughing:), it was the timing belt that broke. He hadn't considered that possibility when sitting on the side of the road, as he was something like 700 km below the mileage where the change interval allegedly was. When you come across incidents like this, it sheds some light on why Honda derates my Civic belt for harsh climates. Rgds, D.
Our VW Jetta TDI was taken to the dealership for it's 80k service and they installed the belt wrong and bent the valves in the head. That was the beginning of the end and the car had multiple issues after that was "fixed."
Timing matters to the engine, but it can also be a pain for us to manage our time.
Rgds, D.
I hope that you were appropriately compensated for that "service".
While not an easy belt to do, there is no valid excuse for what happened to your car.
VW's belt design does not seem to lend itself well to stretching (pun intended) out the change interval. I've also seen a problem with using after-market water pumps on a TDI. One had a thicker wall casting on the impeller - normally you'd think thicker = stronger.
May be, but the problem was the increased wall thickness of the impeller actually reduced the volume of each individual little bucket cast into the impeller. Modern econo-car water pumps are designed to be low-drag from the get-go, so this after-market pump installed on this tdi produced so little flow through the heater core that you were freezing inside the car in the dead of Winter here.
Once that WP was replaced with an OE one, the car had plenty of heat.
Design margins are getting pretty thin, on some things today.
Rgds, D.
/ Timing Belts: time limit spec #35
I hope that you were appropriately compensated for that "service". While not an easy belt to do, there is no valid excuse for what happened to your car. VW's belt design does not seem to lend itself well to stretching (pun intended) out the change interval. I've also seen a problem with using after-market water pumps on a TDI. One had a thicker wall casting on the impeller - normally you'd think thicker = stronger. May be, but the problem was the increased wall thickness of the impeller actually reduced the volume of each individual little bucket cast into the impeller. Modern econo-car water pumps are designed to be low-drag from the get-go, so this after-market pump installed on this tdi produced so little flow through the heater core that you were freezing inside the car in the dead of Winter here. Once that WP was replaced with an OE one, the car had plenty of heat. Design margins are getting pretty thin, on some things today. Rgds, D.
Dealer installed a remanufactured head while we got to drive an Audi 2000 loaner car.
The Audi would have been fun, for a quick fling.
Doesn't sound like the dealer really fixed the tdi in the end - too bad, as they are decent to drive if maintained well.
Rgds, D.
/ Timing Belts: time limit spec #38
Ford's new 1.0L 3-cylinder Ecoboost engine uses a timing belt that is immersed in oil. This is what Honda has been doing in their GCV series small engines for a while now.
Ford says the belt is good for "life" or every 10 years. Couldn't find any mileage limitation.
In the case of the Tundra, no. The water pump, idler, and tensioner are all driven by the back side of the belt, not the teeth. If one seized the belt would just slip on it. The idler/ tensioners are made from what looks like stainless steel and are very smooth. I would guess either would overheat but the noise would be more than enough for anyone with common sense (yes I know that leaves a lot of people out) to stop to find out why. As for the water pump, if it were to seize I think you would overheat before the belt was damaged enough to break.
I'm not a big fan of either a belt or a chain. Belts break and because of this mfgs set replacement times that are much shorter than needed. What company is going to say 200k when they can say 100k and not have to deal with upset people plus they get the benefit of selling people work they may not of needed. Chains stretch as they wear, that changes your timing. Shorter is better but that isn't always an option. I think GM is the last company to use pushrods. That means a timing chain on a V-8 or V-6 must go to both heads. In the case of my Tundra the timing belt was probably 5' long (I didn't measure it). That's a lot of chain.
Nice design. I hadn't seen a WP driven that way. Toyota does seem to design to keep their Tbelts under-stressed. It would be interesting to see the flow curve for that pump..... obviously it does the job fine, but I'm having trouble seeing really high volume being moved w/o a tooth drive...... looks like even pickup truck engine WPs are getting designed for lower drag too.... makes sense.
Agreed on the long chains. Can still have problems, but IMO, correct oil (SAE) grade, viscosity, and change interval matter even more now, on these new long chain designs.
Rgds, D.
Oil of Olay, for timing belts ? ;) Neat.
Hard to imagine a 5' long belt on that engine displacement, but looks like the target is good lifespan/mileage + low (?) cost + quiet. Attractive, for the small car market.
Will be interesting to price those belts.
Rgds, D.
2004 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2004 PETERBILT 379...
Caterpillar D6H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D6H...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
2016 John Deer 5075E (A60462)
2016 John Deer...
2025 58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
2025 58in Padfoot...
