3 point lift not working
/ 3 point lift not working #1
jhnpldng
missouri
Mitsubishi MT180
Just bought a little mitsubishi MT180 and the lift don't lift. When I pull the lever back, I can hear the pump drag the engine down and kind of a screachy/whiny noise back at the cylinder under the seat area. I changed the fliud and cleaned the screen but no difference. Control lever is hard to work but does move. First tractor and new to hydraulics so I don't have a clue what to do next aside from disassembling things. I don't think the lift arms are all the way up but I can't get them to go down by standing on them and moving the lever to down. Of course I weigh all of 130lbs. I can lift them by hand 6-8" or so. The outer end of the lower arms are about 20" off the ground right now. That's at the pivots where an implement would attach. Might just be something gummed up or sticking. I don't have any way to check the pump pressure. What should I start with?
/ 3 point lift not working #2
I am unfamiliar with the MT180. Does the 3ph have a control valve that regulates the speed the 3ph drops? Make sure it is open so the 3ph can go down.
The noise concerns me if it is not just the hyd. pressure relief valve.
Hopefully others on here with more knowledge can help.
/ 3 point lift not working #3
Is the adjuster on lift cylinder piston head screwed in?. If so back it out some.
Yes it has the flow control and wide open doesn't help. Hard to explain the noise. Not quite a screech. Sounds like fluid being sqeezed through a tiny hole kind of like letting a hyd jack down makes sometimes.
/ 3 point lift not working #5
There is a restriction. When you changed hyd. oil what did it look like? was it dark or black? What was trapped in the screen? Did you replace the hyd. filter?
Also. look to see if a hyd. hose is pinched or a pipe smashed.
Are you talking about the adjustment on the flow control valve knob for the lowering speed?
Slightly green and opaque rather than clear but not dark. Smelled like gear oil which is actually one of the recommended fluids for this thing I guess. Tranny and hydraulic share one fluid. I put 303 back in. Also recommended. No obvious visual damage to anything. I'll go through all the adjustments in the book tomorrow aside from pressure since I lack a gauge. The screen had mostly normal thick gunk. 10 seconds with a tooth brush and some diesel and it was clean. No metal chunks came out when draining. I'm pretty sure the screen is the only filter on these things.
/ 3 point lift not working #8
Thick gunk is not the normal. That is a sign it has not been changed on the regular schedule. The gunk may be blocking a return line which will require some time to clean out. Check the manual for a second filter. Screens are usually course mesh not the fine mesh of a filter.
Good luck.
The filter is a screen and is very fine mesh and it's the only one. This thing's got 2000 hours on it and is almost 30 years old. The hyd oil/fluid is supposed to be changed every 200 hours but I doubt the previous owner(s) did that so in this case thick gunk would be normal though not proper. Normal as in not burnt or full of metallic dust. Just old and in need of change.
Thanks for your help.
Had a thought. I have a mechanics stethoscope so I'll try to pinpoint the noise and maybe that will tell me what to take apart first.
Spent a couple of hours searching the mitsu forum for "hydraulics" and noticed a common issue being a stuck piston so I pulled the piston head off last night and sure enough, it was stuck. Kind of makes sense considering the lift was stuck at half way and wouldn't go up or down. I propped up the arms and beat on the piston for a while with a drift and it finally came loose. Some day I need to tear it down and hone the cylinder walls. Need to find a rebuild/seal kit for it. But for now, it's working fine and I've got a driveway to finish so we can get electric in here.
(and upon further thought, I should have said typical gunk, not normal)
/ 3 point lift not working #13
When you state stuck piston head can you be more specific? Have a MT250D and 3ph arms will only go up a few inches? Need advice please! allen@tennesseeland.com
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2016 Dodge Grand Caravan Van (A61574)
2016 Dodge Grand...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
