Check out this homemade tracked rig!
/ Check out this homemade tracked rig! #1
NS Gearhead
Nova Scotia, Canada
Deere X350
https://www.youtube.com/watch?v=VEOrQKvIMLc
https://www.youtube.com/watch?v=bwpeNDp7VAQ
https://www.youtube.com/watch?v=0HdAOZBM2rg
Another;
https://www.youtube.com/watch?v=1rfuggVQMuw
I've always loved all things with tracks.... someday I may build something like this... but I don't fully understand how it works. So, it's an engine, transmission, driveshaft, and rear end mounted backwards. He steers by braking. Does he drive forward by putting it in reverse?... or am I missing something? With this setup (open differential) would it be difficult to drive in low traction situation without one side loosing power? Would applying the brake to the one spinning give some power to the one that's stopped in that situation?
I know modern day tracked vehicles use a hydraulic pump and motors... I'm guessing the pump could be mounted to the end of a transmission and motors used to power each track... allowing the tracks to get 50/50 power, or turn opposite. Right? Obviously an expensive way to go unless you've got a source for cheap used parts.
I've got visions of a 1/4T truck cab with a 7.3 ford or 5.9 Cummins... 14 bolt axle... oh yeah baby! :)
/ Check out this homemade tracked rig! #5
I always understood that you were better off driving your tracks from the rear of the vehicle......If you can locate a drivetrain out of another tracked vehicle then you would be able to turn in your own length by reversing one side while driving the other. Simply braking one side will turn you if your traction is right, but not as sharp....
I would think so too. I'd rather the top of the track get loose under forward load then the bottom.... although running a truck's drivetrain backwards would be harder.... UNLESS you ran a transfer case and only sent power to the front axle... being in the rear! :) The gear reduction would be a bonus!
/ Check out this homemade tracked rig! #7
That first rig is incredible! I saved the vids in hopes of building my own someday.
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
2014 Chevy Malibu Sedan (A59231)
2014 Chevy Malibu...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
