How do you store you logging/tow chain?
/ How do you store you logging/tow chain? #241
If you look around there are some industrial sized/lenght stainless steel hose clamps that would hold the PVC to the posts and the tightening assembly could be hid behind the posts. No drilling required....
You can also get super duty zip ties that would likely work. I use them for securing things that really should be bolted or clamped and they have held up surprisingly well. I'm not sure where I got the last ones but I think it was at Home Depot or Lowes. USA made. Maybe they might work?
/ How do you store you logging/tow chain? #242
Thomas,
Here's an idea; below your FEL post you have a hole that runs under your tractor, below where I had attached my PVC pipe. Could you use that to store your logging chain? You may even be able to use the same red caps I used to keep the chain contained. You wouldn't have to drill any holes, or figure out how to attach something new.
/ How do you store you logging/tow chain? #243
Had to build another chain holder for the new tractor, really liked the PVC tube so that's what I did again.
/ How do you store you logging/tow chain? #244
Speaking of chains,
I wanted to show off what I found at my local scrap iron place. At 20 cents a pound I got for less than $10. So I think I stole it. It has a metal tag on it that I can't read. I guess it belonged to a crane company or something like that and they took it out of service.
/ How do you store you logging/tow chain? #246
Speaking of chains,
I picked some chain from a commercial operation like that years ago and it turned out to be some sort of super strength alloy. Yeah, you stole it for 20 cents a pound.
/ How do you store you logging/tow chain? #247
Looks very nice. I really like your location and the design for the bracket. Will you leave the tube open at the top? What schedule pvc did you use? Are you concerned about the jostling of the chain eventually setting up fractures in the plastic at the bottom of tube and the bolt attachment points?
/ How do you store you logging/tow chain? #248
Thanks, I wanted it out of they way yet easily accessible. I used schedule 40 and drilled a 1/2" hole in the very bottom of the cap so water can drain out if any gets in. I used two 1/4" - 20 bolts with fender washers that I bent to conform to the inside of the pipe and the unistrut supports the back of the PVC really well. The top will stay open so I can hang the hooks on the lip of the tube. Here is one I built last summer for my Kubota. Its one of those things once you do you wonder why you didn't do it when you bought the tractor. :)
/ How do you store you logging/tow chain? #249
I welded some pieces of steel on top of the screen guard with notches, the chain rest in that. The hooks are on two ten inch, 5/8" dia. rods on both sides of the winch frame, not the best way but the chains never fall off, and you can here the chains go Jing-a-ling, Jing-a-ling, all the way through the woods.
/ How do you store you logging/tow chain? #250
/ How do you store you logging/tow chain? #251
That chain method is cool, but I'm fascinated by your folding trailer receiver even more.
/ How do you store you logging/tow chain? #252
Thanks, I'll take that as a compliment, it's another one of my add-ons, I use that hitch all the time, it has a spring loaded pin to lock in straight back or in a folded position to temporarily keep it out of the way so I wont bang my knee in it. When I'm not using the hitch, I pull the pin in the receiver and store it on the loader mount. I looked all over the net for a fold away trailer hitch and couldn't find any.
/ How do you store you logging/tow chain? #253
Question for you guys with the PVC tube chain holders. Many pics I see show 3-4 chains in one tube. I assume varying lengths. Do you have any issues getting a chain out if it is on bottom? Seems like if you put in several chains the first one in would be hard to get out.
I like to carry one 20' chain and a couple 5-10' chains. Wondering if I should make two separate holders one for the long chain and one for two short pieces.
/ How do you store you logging/tow chain? #254
/ How do you store you logging/tow chain? #255
Getting the chains out is not a problem for me. Just figure on putting the 20 footer in first and the two lighter, shorter ones in second. Just figure if you want to use the long one, you take the two shorter ones out to get to em. Just takes another couple minutes. I don't have a twenty footer in mine. I have a 5/16, 3/8 and a1/4 inch chain in there. I guess the longest is twelve or fourteen feet. Really it all depends on what chain you are going to need the most I guess. I set my up a couple years ago and still really like it.
/ How do you store you logging/tow chain? #256
I carry one 20' as well. You have me thinking though... ideally two compartments, one for the 20ft guy and another for the 2 10s... that would be ideal for me. Gotta get on a design for that for my BX. Kinda like Batman and having a 'tool' belt with an accessory for every occasion. :laughing:
/ How do you store you logging/tow chain? #257
Well today I built my chain holder. Two 4" square tubes 18" long welded together. I think they were 14ga. I welded a cap across the bottom and drilled 5 holes in each side for drainage. I am pleased with it. The front tube has a 20' 5/16" chain and is full and the back tube has two 5/16" chains about 8-10' long and is also full. I mounted them on to the side of my loader with six small welds.
/ How do you store you logging/tow chain? #258
awesome! Exactly what I want to do!
/ How do you store you logging/tow chain? #260
You did good. Very nice looking, and very functional.
2012 FORD F-250 (INOPERABLE) (A60736)
2012 FORD F-250...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
John Deere RO764 (A60463)
John Deere RO764...
2005 International 5900i T/A Flammable Liquid Transport Truck (A60352)
2005 International...
2012 GENIE GTH844 TELESCOPIC FORKLIFT (A62129)
2012 GENIE GTH844...
More info coming soon! (A56858)
More info coming...
