Hydraulic top link length?
/ Hydraulic top link length? #1
UncleBuck1
Baton Rouge, LA
2011 MF 2660HD; 1964 JD 4020 (may she rest in peace)
I would like to purchase a hydraulic top link, primarily for use with a box blade. When my box blade is level the top link is 28" center-to- center; how much retraction and extension from level do I need?
/ Hydraulic top link length? #2
My recommendation would be for a 22"-32" working length. Gets you a little bit more retraction than extension and that can work in your favor when you have conditions-situations when you need the implement raised up higher.
/ Hydraulic top link length? #3
You can use your mechanical top link to find the feasible min and max lengths and use that as rough guidance. Hydraulic top links I see that would work have ranges of 22-30", 24-32", and 26-34".
/ Hydraulic top link length? #4
I can't add anything more than has already been said, but I will put a plug in for Brian at Fit Rite....great hydraulic top link setups! The one he built for my LS was perfect, and it simply toyed with a 1,400lb implement.
/ Hydraulic top link length? #5
Same here, happy with my gear from MtnViewRanch (same guy).
/ Hydraulic top link length? #6
Are you ever planning to buy a 3ph Quick Hitch? That would change things a little...
2016 John Deer 5075E (A60462)
2016 John Deer...
Timpte Hopper Bottom (A63688)
Timpte Hopper...
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
