Loader john deere loader joystick problems
/ john deere loader joystick problems #1
jkb7810
Member
denison,ia
john deere 455, 2720, 4020, 7810
OK when I push the joystick all the way ahead it does not go into float. Any thoughts would be appreciated.
/ john deere loader joystick problems #2
Try with bucket couple inches off ground and snap the lever forward into the float detent should feel it set.
/ john deere loader joystick problems #3
Which Deere are you talking about, not going into float?
Sorry about not getting back to you. My phone never told me that i had some else reply to this and i have not looked at my old posts for awhile .It is a John Deere 7810 with a factory joystick. It seems like it actually skips the detent. I do feel it jump and it kinda acts like it is putting pressure on both sides. I'm thinking that the joystick is wore out or needs adjusted. I just hope its not in the valving.
/ john deere loader joystick problems #5
Just a thought. Start with it a foot or two off the ground. Push it all the way forward hard and hold it there. When it hits the ground give it a 15 or so seconds. Does it start raising the front of the tractor--it's exerting down pressure and not in the float position. If however it just sit there, it's likely in float position. You can further test if it's in float at this time by moving the bucket to dump which as the front tips down will lift the loader arms if it's indeed in the float position. As you rotate the bucket back the loader arms will go down. Now given you find it's in float when your holding the lever all the way forward but when you release the lever the lever returns to neutral then the detent is not holding it in float but float does work.
/ john deere loader joystick problems #6
The detent is actually at the valve not the joystick. But it is repairable, there is a kit that can be bought for about $60, assuming all other aspects are working properly.
Thanks for the quick response. I will try this when I start it again. If the problem is in the linkage I will try to tackle it myself. Really hope it is. Every time it goes to JD its at least a grand or two. The one time I brought it there for a couple of oil seeps it was 12 grand later and a rebuilt tranny.
Thanks for the feed back. I do realize that it is in the valving. And $60 seems really cheap for JD. It cost around a thousand for my 67 4020 but the boxes are under the dash not stack type ( if I remember right).
All other functions work fine. I can pick up big rounds 5x6 all day long frozen together ( yes sometimes two come together kinda annoying lol) . I have a Westendorf ta 46 on it.
Edit
The joystick seems loose to me. The loader was new two years ago and hasn't had much use. I've had the tractor for around 5 years( early version.).
/ john deere loader joystick problems #9
My tractor might as well be a new-born baby to yours but it has a loader and probably functions the same way as yours. The control has lots of play in every direction before it operates anything but it still goes into a detented float position. My posted advise to you was intended to find out: 1. is your float position not working. OR 2. is it just not holding itself in that position.
If just not holding itself in that position it's most likely a worn detent which, yes, is probably in the valve but surely fixable.
If it isn't working. Well, is the lever simply unable to push the control far enough to engage the float position? Is it for some reason it requiring excessive force to enter that position? Is the valving for this position "broke"?
Good luck.
Good luck.
Yes, it is my baby. But all the joystick cables must be good . because the loader will still hydro down.
Although they could be worn out 1997 model I think.
/ john deere loader joystick problems #12
Nope, I'm saying my tractor is a baby to yours. Mine is only 20 hp but should still operate the same.
Ok, so it hydros down. So your saying if you push the lever all the way forward and hold it there the loader lowers and then starts to lift the front end of the tractor? Yes or No?
/ john deere loader joystick problems #14
For pics, have them on your computer. Then click on the "Go Advanced" button and use the "Manage Attachments" feature. Should then walk you through it pretty easy.
/ john deere loader joystick problems #15
I'm guessing you have a JD joystick. I'd suggest to remove cover(parts key 20) and check all clamps & attaching parts for tightness. Again I guessed a control valve as there are a couple of valve brands. Parts key 40 is the lift spool detent repair kit.
OK I see what u are saying but it is not working for me.
1. It could be the tablet I'm using.
2. I had to email myself from my phone because my tablet has no pictures on it and it is the wrong format for TBN because it would b a download of a down load.
I will mess with it and see if I can get it to work. This is by far not ms outlook. Lol
No will try it next week thanks for the trouble shooting idea.
Think I figured out the picture thing. Thanks for all your help
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2000 FREIGHTLINER FL80 WATER TRUCK (A67714)
2000 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A67714)
2013 ORTEQ ENERGY...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
